Samsung Galaxy S9/S9+ display 'dead spots' and camera issues
AndroidPIT Samsung Galaxy S9 0938
© nextpit by Irina Efremova
The Samsung Galaxy S9 and S9 Plus are among the best smartphones on the market right now, but as with all new devices, the cracks begin to show. These high-end devices are not without faults, so we'll compile all the problems and solutions in this article. Among the first to arise are issues with the functionality of the screen, as well as some camera faults.
Jump to
Display 'dead zones'
Among the first reported problems with the S9 are 'dead spots' towards the lower end of its display, and it seems that the S9 Plus is mainly a victim of this. On Samsung's community forum, the question "does anyone else have issues with the Galaxy S9 touchscreen?" arose. It seems that this problem is predominantly along the bottom panel, although other reports have mentioned faults in different areas of the screen.
AndroidPIT Samsung Galaxy S9 0708
The curved display is causing problems for some / © NextPit
On Reddit, a user reported issues in the Snapdragon 845 version of the S9 Plus, including 'phantom' touch registrations, issues with swiping on the keyboard, and again 'dead spots' where various areas of the screen stopped functioning completely. Could this be a common issue with the curved displays?
Is there a way to fix this?
In the forums, some reported that after doing a factory reset, the problem was resolved. However, this hasn't worked for everyone. Increasing the sensitivity has been suggested as another solution. If neither of these have worked, the best option would be to contact Samsung directly and request a repair or replacement device.
Lighting issues in the camera
Darkness when filming in Slow Motion
In a Reddit thread, users have been debating whether the darkness of videos recorded with Super Slow Motion is as a result of a defect in the phone, with users complaining of the quality of the video even when lighting conditions should be satisfactory.
AndroidPIT Samsung Galaxy S9 tips tricks 04
We had no issues using Slow Motion outdoors with lots of light. / © NextPit
For now, the only solution unforunately is to only use this feature outdoors in the daytime, as it needs a lot of light to work properly. It may be that the feature will only work well in these conditions, although according to one user, Samsung have stated that they are aware of the problem, and are 'working on it'.
Light in the wrong places
You might be familiar with this problem if you checked out our S9 camera review. We noticed an unusual light reflection, and in some photos this was very visible. We assumed this could be software problem, as it happens on both the front-facing and rear camera, ruling out an issue with the aperture.
This may only be present in the pre-series version, but if you've had a similar experience, we would recommend you get in touch with Samsung to request a new phone.
20180228 064312
The light has been reflected in error / © NextPit
Once we know more fixes and solutions, we'll update this article and keep you in the loop. Have you had any problems with the S9 or the S9 Plus that we haven't mentioned here? Leave a comment and let us know.
Go to comment (7)
7 comments
  • Reina Rodriguez 1
    Reina Rodriguez Apr 8, 2018 Link to comment
    My s9 has turned off on me twice with charge on the battery. The first time it had 80 percent charge and second time it had about 45 percent charge. Its turned off for no reason and won't turn on even with a reset until I get home and connect it to the charger. Getting a replacement at a t mobile store on monday.
    D E Apr 1, 2018 Link to comment
    My wife got the s9 plus on 3/22. By the 24th, her front camera would not work. I went through all the steps to fix it but it appears to have been a hardware issue. When I went to the tmobile store to return it, there was another lady who had the exact same issue.
  • Dusan V. 12
    Dusan V. Mar 23, 2018 Link to comment
    I'm using preorder edition of S9 plus (Europe unlocked version) and I don't have any of mentioned issues.
    sam pack
  • 28
    itprolonden Mar 22, 2018 Link to comment
    Take it to the Samsung store...oh wait....
  • 21
    Peter Harwood Mar 22, 2018 Link to comment
    Expensive overated phones nothing but trouble slow with software updates and lacking original ideas.
    • 28
      Who in the Android sphere has original ideas outside Samsung?
    Latest mobiles Mar 22, 2018 Link to comment
    Great Article and thanks for sharing with us,
    Being the top Products in the market from Samsung (S9) These kind small issues were never expected. As Samsung brand itself has a good Value. Samsung should immediately look into the issues and come up with a Solution. I too was a big Fan of Samsung products.
    Sorin
