Want larger battery charge level display
JustSomeUser
  • Forum posts: 5
Apr 3, 2021, 8:48:22 PM via Website
I have a Samsung A20 running Android A205USQS8BTL2 (applied Jan 21 2021).
The battery level icon in the upper right of the home screen is tiny and I often can't read it, depending on the external light level.
I would like a larger battery charge display somehow. I don't care whether the current icon is made larger, or I install a battery level app that displays realtime charge % in its app icon (even when the app is not open), or some other method that is a lot more convenient than navigating to Settings->Device Care->Battery.
I suspect that this is a FAQ that was solved long ago, but I can't seem to find a solution by internet search.
I'm probably a nitwit, but I can't find a search function on this forum.
Thanks in advance for any suggestions!
James Watson
  • Forum posts: 1,586
Apr 4, 2021, 9:14:39 AM via Website
Check some battery apps on the Google Play Store for your purpose. For example: Accu Battery, Battery, etc.
Download size < 0.15 MB. But also accurate enough, ad-free & free.
Blog: https://okblackcafe.blogspot.com Your 5-star is appreciated.
Helpful?
JustSomeUser
JustSomeUser
  • Forum posts: 5
Apr 4, 2021, 8:30:34 PM via Website
James, thank you very much for the suggestion.
I installed those two apps as well as a 3rd (these apps' Play Store images appeared to show battery level on the app icon, so I can see why you would suggest trying them), but none of them display the battery data on the icon.
Helpful?
Chris Jordan
  • Forum posts: 4
Apr 4, 2021, 9:38:19 PM via Website
For your needs, look into some battery applications on the Google Play Store. For instance, Accu Battery, Battery, and so on.
Helpful?
JustSomeUser
  • Forum posts: 5
Apr 4, 2021, 10:28:01 PM via Website
ChrisJordan, thank you very much for the reply.
Helpful?
wextio
  • Forum posts: 124
Apr 5, 2021, 11:21:08 AM via Website
You should try out different battery apps in the Google Play Store if you're interested in taking a larger variety of applications with long battery life.
Helpful?
JustSomeUser
  • Forum posts: 5
Apr 5, 2021, 5:54:06 PM via Website
wextio, longer battery life is not the objective, actually.
Thanks for replying, though.
Helpful?
JustSomeUser
  • Forum posts: 5
Apr 18, 2021, 6:44:29 PM via Website
I'm still searching for a larger battery charge display on the Home screen.
Maybe it doesn't exist....
Helpful?
