Facebook Messenger problems and solutions
shutterstock 2082773545
© Diego Thomazini/Shutterstock
For some time now, Facebook Messenger has been a standalone app, separate from the Facebook application. This has made it a more powerful messaging service capable of competing with its cousin, WhatsApp. Its independence also makes it hungry for battery and memory, however, and it now comes with its own set of concerns. Here's what to do when Facebook Messenger is not working on your Android phone.
Jump to
Is Facebook Messenger down?
Facebook Messenget screens
Before you troubleshoot, make sure the problem isn't with your phone! / © NextPit
Before you start pulling your hair because Facebook Messenger isn't working, it would be a good idea to check if the issue is being caused due to an outage. It is not uncommon for Facebook services to go offline at times, and there have been several instances of this happening in the past.
One of the ways you can check for outages is to visit the Platform Status page for Facebook. This page usually lists ongoing outages. There are third-party services like IsItDown and Downhunter that can help you check the status of Facebook Messenger. If the issue is on Facebook's end, the only option is to wait or use an alternative messaging service.
Check the status of Facebook Messenger using a web browser
Before you start troubleshooting Facebook Messenger issues on your smartphone, it would be a good idea to check if you can access the service using a web browser.
Access Facebook Messenger via your browser:
  1. Simply open your web browser and go to https://www.messenger.com/.
  2. Log in with your username and password.
  3. You should be able to access your messages within the Facebook website, old-school style.
Try Facebook Messenger Lite
Another way to go about this is to install a pared-down, less resource-intensive version of Facebook Messenger called Messenger Lite for Android devices. Some people actually prefer using Messenger Lite over its bloated cousin because it uses fewer resources (especially RAM and storage) and was generally thought to be less buggy.
  1. Get Messenger Lite from the Google Play Store.
  2. Download, open, and log in with your credentials.
  3. Enjoy messaging as usual, with a streamlined appearance and just the essential features.
Fix Facebook Messenger errors on Android
Let us now take a look at some of the more common errors that you may encounter with the Facebook Messenger app for Android smartphones.
Facebook Messenger: 'Please check your internet connection and try again' error
This is among the most common errors that you may come across while using Facebook Messenger on your Android phone. Many people have complained about an error message that says, "Please check your internet connection and try again" when trying to use Facebook Messenger. Please follow these steps to try and fix the issue.
  1. Open the Settings menu on your Android phone.
  2. Go to System and then tap on Date & time (the menu options may change depending on the Android skin your phone has).
  3. In the Date and time menu, ensure that the options Set time automatically and Set time zone automatically are selected.
  4. Once this is done, go back to the Settings menu.
  5. Open the Apps menu.
  6. Select All apps.
  7. Look for Messenger in the list of apps and tap the option that says Force stop.
  8. Once this is done, go back to the home screen and try opening Facebook Messenger again, and the issue should be fixed.
Android time settings
Changing the time and date settings can be a possible solution to Facebook Messenger errors / © NextPit
The steps for iPhone users are a bit simpler:
  1. Open the Settings app.
  2. Choose General.
  3. Tap Date & Time.
  4. Activate the Set Automatically option.
Time synchronization settings
Time synchronization issues can be fixed with a single option / © NextPit
Fix the 'Unfortunately, Facebook Messenger has stopped' error
This is another (relatively) common issue that many people face with Facebook Messenger on Android. A possible fix for this issue can be achieved by taking the following steps:
  1. Open Settings.
  2. Select the Apps or Apps & notifications option.
  3. Tap See all Apps.
  4. In the app list, select Messenger.
  5. Select Storage & cache.
  6. Tap Clear cache.
    • On older Android versions, the Clear cache option will be shown on the previous screen.
Clear Facebook Messenger cache
Clearing the cache and data should help clear up most problems / © NextPit
If this doesn't solve your issue, it might be a good idea to uninstall and reinstall Facebook Messenger. But before you do that, open the Google Play Store on your phone and check if there is an update available for Facebook Messenger. If yes, install the update and check if the issue is resolved.
In fact, the same solution can be used for issues like the one described below. Although, we have suggested a slightly different method.
I can't send or receive messages on Facebook Messenger
If you're trying to send a sticker to your friend and Facebook Messenger is not delivering your vital correspondence, do not despair. Although the situation may seem desperate beyond all comprehension, the solution could well be simple. Ensure, firstly, that the app is up-to-date:
  1. Open the Google Play Store app.
  2. Tap on your profile picture.
  3. Select the Manage apps & device option.
  4. Tap Update all to update every installed application or See details to choose which ones to update.
App update from the Play Store
Visit the Google Play Store to check Messenger is up-to-date / © NextPit
For iPhone users, open the App Store app, tap your profile icon at the top of the screen, and then tap on the Update button next to the Messenger app.
Alternatively, you can update the Messenger app directly via the app stores pages:
All (or some) of my messages have disappeared
If you've accidentally deleted your messages, which is not easily done, then you're out of luck; they're gone. But maybe you just archived them, in which case you are in luck. Open the Messenger app and follow these steps:
  1. Tap on your profile picture at the top of the screen.
  2. Choose Archived chats.
Facebook Messenger archived chats
Archived chats are moved to a separated list / © NextPit
On the desktop site, click on the "..." button at the top of the contact list and then select the Archived chats option.
Let us know in the comments if there are any Facebook Messenger problems you're struggling with, and we'll do our best to address them.
Go to comment (110)
Rubens Eishima
Rubens Eishima
Writer
110 comments
    Barbara Young May 9, 2023 Link to comment
    Google told me to clear cache and data, but I lost my Facebook messenger. Can I get the same messenger back
    Stm263 Jun 13, 2022 Link to comment
    I done everything it say to do I even removed messenger and reload messenger and still doesn't work please help
      Chantel Smith Jun 15, 2022 Link to comment
      I have the same problem on my android phone. I've called Verizon & Samsung. I've read all the help screens. Uninstalled & Reinstalled twice. Still can't get on messenger.
    sham May 8, 2022 Link to comment
    There is no checkmarks in my messenger. Im using an iphone
    Tracey Ridley Apr 21, 2022 Link to comment
    I run a group and we use the @everyone tag for a while which was really helpful, now it is not working for some reason. Been trying to find out why but no answer to it. We are an Australian based group. Any help would be greatly appreciated.
    • Matss Gaming 1
      Matss Gaming May 24, 2022 Link to comment
      Is this already fixed? Im having the same trouble
    MLUTEMAN82 Mar 27, 2022 Link to comment
    Only on my iPad I cannot go directly to the person I am try to message on fb. It takes me to messenger but then I have to type in the persons name.
      Nicole Jul 27, 2022 Link to comment
      Did you ever find a solution? I just got a new iPhone and this is happening to me
  • Jacqelyn Lambert 1
    Jacqelyn Lambert Mar 17, 2022 Link to comment
    Just installed messenger on my Windows 11 laptop why can’t I see any messages that I receive
  • MiSs BriDgeT HILL 1
    MiSs BriDgeT HILL Jan 29, 2022 Link to comment
    For too long now : MESSENGER is logging me out. 'ERROR VALIDATING ACCESS TOKEN....'
    Has Anyone Seen This? But it hasn't logged me out. I can't do a thing and that thing just keeps spinning n spinning!!
    H E L P ! ! ! ! ?
  • Goshgar Muradkhanov 1
    Goshgar Muradkhanov Jan 20, 2022 Link to comment
    Sometimes the messages that newly comes are not bold black colour when I logging in messenger. Can be it read before me? Or it is the generally messenger false? If the first one assumption is correct, how can I solve it?
    Sam87 Jan 18, 2022 Link to comment
    Messenger will not let me send anything other than a basic message. The second I click on the sticker button the app disconnects and I can no longer send even a message and the screen reads connecting. Nothing will load. I then have to clear cashe or clear all data and start from scratch.
    Zois Bekios Zannikos
    • Zois Bekios Zannikos 9
      Zois Bekios Zannikos Jan 18, 2022 Link to comment
      You can try a clean install of the app, if that does not work either try downloading the Light version of messenger. I hope this helps.
        Sam87 Jan 19, 2022 Link to comment
        I have un installed and re installed the app to many times to count unfortunately and still have the same issue. I have switched to messenger light for now but it just is not the same. I appreciate your response though. Thank you.
        I tried this, but I'm only got a new messenger site. I want the messenger that Google made me delete
  • Tabitha Morris 1
    Tabitha Morris Dec 18, 2021 Link to comment
    I have a Facebook page in english but when i go to settings its in German
    • Fabien Röhlinger 72
      Fabien Röhlinger
      • Staff
      That sounds weird. Are your browser settings maybe in German?
  • Tabitha Morris 1
    My facebook messenger is only searching Instagram accounts when i search nothing else will come up help please
  • Camila Rinaldi 67
    Camila Rinaldi
    • Staff
    Dec 14, 2021 Link to comment
    This article was last updated in December 2021. Older comments have been retained. Enjoy it!
    Piet S. Nov 19, 2021 Link to comment
    Messenger JOIN is always green in our Family chat room and if we click it,it does not work.
    But it is always green and we can't get rid of it or use it !! HELP
Show all comments
