Galaxy S4 Lollipop problems and how to fix them
samsung galaxy s4 hero 1
The update to Android Lollipop on the Galaxy S4 brought a bunch of new features as well as a couple of new issues. The good news is that these Galaxy S4 Lollipop problems are not actually so hard to fix. So if you've been suffering from bugs on the S4, read on. We'll show you how to fix the most common problems with Android Lollipop on the Galaxy S4.
AndroidPIT samsung galaxy s4 lollipop
It's time to fix Galaxy S4 Lollipop problems once and for all. / © ANDROIDPIT
Shortcut to problem:
  1. Camera lag
  2. Samsung keyboard hack
  3. Contacts app crash
  4. com.android.phone freeze
  5. Battery drain
  6. Slow app launches
  7. Disappearing keyboard
  8. Wi-Fi connection problems
  9. Bluetooth problems
  10. Overheating
  11. S4 won't even start
1. Galaxy S4 Camera crashes or lags
The Galaxy S4 camera can be a temperamental old beastie, sometimes painfully slow to start and occasionally crashing like a drunken baby in a stolen car. But this problem is actually pretty easy to solve. All you need to do is hide the keys.
Seriously though, one of the longest-running camera solutions is to simply turn off image stabilization in the S4 camera app. Just open the app, tap the Settings icon (it looks like a cog) and turn off Anti-Shake.
If you're suffering from camera app crashes or the S4 can't access the camera, try going to Settings > Application Manager > Camera and clearing the app's cache. If that doesn't work, try a reboot (or just pull the battery for 30 seconds) and, if all else fails, you can try a new camera app. Check out our list of the best Android camera apps at the link.
AndroidPIT Galaxy S4 Lollipop camera settings anti shake off
If your camera app keeps crashing, try turning off Anti-Shake in the settings. / © ANDROIDPIT
2. Galaxy S4 keyboard hack
You may have heard about the Samsung keyboard hack scandal, which potentially exposes 600 million Galaxy owners to some pretty nasty stuff. The chance of being affected is quite low, but there doesn't seem to be a perfect fix from the user side. Disabling the app or using another one won't help, and you can't uninstall it.
Fortunately Samsung is on the case and is working with SwiftKey to patch the vulnerability, with a promise that the fix will roll out very soon. Until then just hold your breath and hope for the best.
3. Galaxy S4 Contacts app keeps crashing
This is probably the most common problem affecting Galaxy S4 owners after the update. The Contacts app keeps crashing or freezing with the error message 'Unfortunately Contacts has stopped'.
The best approach to fix this is to go to Settings > App Manager and swipe to the All tab, scroll down to Contacts and clear the cache. If this doesn't fix the problem you can also clear the app's data and then re-sync it.
AndroidPIT Galaxy S4 Android 5 0 1 Lollipop App Manager Contacst
Clear the cache for the Contacts app to stop it crashing. / © ANDROIDPIT
4. Galaxy S4 com.android.phone freezes
First try to fix this issue by going to Settings > App Manager and resetting your app preferences. You can also try to restart your phone and hope for the best but there aren't any surefire fixes. If this issue is widespread enough Samsung will issue a patch to fix it. You can also boot into Safe Mode and see if the same error message appears.
To boot into Safe Mode, turn your S4 off and then repeatedly tap the menu soft key when you restart. Once you've booted up you'll see a Safe Mode banner on the bottom left of your screen. Safe Mode just runs Samsung's pre-loaded apps, so you can tell if it's a system issue or something else entirely.
If the problem doesn't happen in Safe Mode, it might be a third party app that's causing the problem. In the past we've found that this could be down to anything from security apps to mobile network toggle apps, so trial and error is your best bet. Start with the apps that you installed most recently. Just uninstall or disable them one at a time and see if the problem persists.
AndroidPIT Galaxy S4 Android 5 0 1 Lollipop Reset App Preferences
Resetting app preferences might fix the com.android.phone crash. / © ANDROIDPIT
5. Galaxy S4 battery drain
This is another super common update problem. The good news is battery drain usually calms down after a few days, but if it doesn't, the best way to treat it is with the usual trio of escalating force: turn your phone off for about a minute and restart.
You can also check Settings > App Manager to see which apps are chewing through RAM, and Settings > Battery to see what's eating the battery. This helps you identify whether it's an app-related issue or a system issue.
If that doesn’t work, restart in Recovery Mode (press and hold Power, Volume Up and Home button, using the volume buttons to navigate and Power button to confirm) and clear the cache partition.
If this still doesn't clear things up, you'll have to backup everything on the Galaxy S4 and factory reset your phone, either through the settings menu or Recovery Mode (see tip 10 below). Check out our Galaxy S4 battery tips for more power-saving mojo.
androidpit samsung galaxy s4 cache 1
Recovery Mode on the Galaxy S4 lets you clear the cache partition. / © ANDROIDPIT
Once your phone restarts you will be able to restore your apps and data and the Galaxy S4 battery drain issue will be resolved. I remind you that going nuclear with a factory reset should only be done once you have backed up.
In future the easiest way to avoid battery drain is to do a backup before updating, then update and factory reset immediately afterward. That way you start off on the right foot.
6. Galaxy S4 lag and slow app starts
Laggy performance after an Android update is quite common and nothing too severe. A simple restart (or battery pull for 30 seconds) usually clears things up, but if the lag problem persists, the easiest solution is to clear the Galaxy S4 cache.
Turn your Galaxy S4 off, press and hold Power, Volume Up and Home button until you enter Recovery Mode like in the picture above. From here use the volume keys to scroll and Power button to confirm.
If you want to minimize other lag on your Galaxy S4, you can go to Developer Options (if you don't have this enabled already, go to Settings > About Phone and tap Build Number seven times. You'll now have Developer Options in Settings) and turn off all animations: window animation scale, transition animation scale and animator duration scale.
AndroidPIT Galaxy S4 Android 5 0 1 Lollipop Developer Options window animation scale
In Developer Options on the Galaxy S4 you can turn off animations and transitions. / © ANDROIDPIT
You can also disable the S Voice shortcut with the Home button (because the Galaxy S4 'waits' for the second press before taking you back to the home screen). Simply, enter S Voice, hit the settings menu and uncheck the box for 'Open via the home key'. This will make navigating just that little bit faster on the Galaxy S4. Check out our other tips to speed up the Galaxy S4.
AndroidPIT Galaxy S4 Android 5 0 1 Lollipop S Voice settings
Turning off the S Voice shortcut speeds up your Galaxy S4 when using the home button. / © ANDROIDPIT
7. Galaxy S4 keyboard keeps disappearing
We've heard a couple of people complaining that the stock Samsung keyboard keeps vanishing as they're writing a message. This is not only irritating, but seriously affects the usability of your phone too.
The solution for this is to go to Settings > App Manager > switch to running tab and scroll down to Samsung Keyboard to see if there's any error messages.
Another simple solution is to download an alternative keyboard app and change your default keyboard to that.
AndroidPIT Galaxy S4 Android 5 0 1 Lollipop Samsung Keyboard
Check App Manager to see if there are any error messages from the Samsung Keyboard. If there are, replace it. / © ANDROIDPIT
8. Galaxy S4 Wi-Fi connection problems
This is another common update problem and another one with a variety of simple, if not exactly fail-safe solutions: toggle Wi-Fi on and off, enter Airplane Mode momentarily, modify your Wi-Fi connection settings (from 2.4 GHz to 5 GHz), forget and re-add Wi-Fi connections, restart your router, toggle the Smart network switch in Wi-Fi settings and just generally messing around with your options until things go away.
AndroidPIT Galaxy S4 Android 5 0 1 Lollipop Wi Fi settings advanced
Turn off Smart Network Switch and fiddle around with your Wi-Fi settings. / © ANDROIDPIT
9. Galaxy S4 Bluetooth problems
Bluetooth problems are another super-common update issue. The easiest way to treat Bluetooth problems is to toggle Bluetooth on and off. If that doesn't work, forget and re-pair your Bluetooth devices.
10. Galaxy S4 overheating problems
Apparently the Galaxy S4 is even more prone to overheating following the Android 5.0.1 update. We've not experienced this ourselves but we’ve heard that for some reason, removing the battery and microSD card and then leaving out the microSD card when you replace the battery can alleviate the problem. Super weird and not very helpful if you rely on your microSD card, but this is the only solution we've heard of for this problem.
11. Galaxy S4 behaves wildly or won't even start
If you've got the Lollipop update and things start getting erratic, you might have to resort to a factory reset. This is also the easiest way to clear up the usual bugs that follow an update.
Don't worry, a factory reset is actually not a big deal, assuming you've got a backup of all your important data. Copy things to your computer with a USB cable, download an app or follow our guide on how to back up everything on the Galaxy S4 for options including rooted and non-rooted phones.
AndroidPIT Galaxy S4 Lollipop settings factory data reset
Factory resets are nothing to be afraid of if you have a backup. / © ANDROIDPIT
Once you have a backup, go to Settings > Backup and Reset and tap Factory Data reset and confirm on the next screen. Your phone will wipe all data and reboot with factory settings. It will keep the latest version of Android you installed though. Once it has rebooted, simply restore your apps and data and continue bug-free.
Let us know what other Galaxy S4 Lollipop problems you're suffering from and we'll look for more solutions to help get it fixed.
Are you liking Android 5.0.1 on the Galaxy S4? Have you experienced any of these problems?
Go to comment (273)
Kris Carlon
Kris Carlon
273 comments
  • Inayat ullah Khan 1
    Inayat ullah Khan Jan 14, 2019 Link to comment
    I updated my samsung s4 with lollipop 5.0.1ofter updating the soft keys not working I also tried *#2663# but it says IC'a f/w is higher than bin's f/w. How to fix this problem.
  • Ahm AD 5
    Ahm AD Jul 4, 2016 Link to comment
    Got no effect. :(
    Nice tips.
  • steve 16
    steve Jun 30, 2016 Link to comment
    Best fix is the bin fix, the problems are recurring. Get a N and be do with it. It was the best I've done.
    Karen Aying May 21, 2016 Link to comment
    i have a problem with my samsung s4, its 5.0 lollipop. it cant connect to wifi and the smart network switch cannot turn off and its not clickable. the battery drains so fast and its over heating i cant click the settings on my wifi.. i have already did the factory settings many times and its still the same. i can no longer use it because the battery will stay up to 1 hour only.
  • Abdullah Amin 1
    Abdullah Amin May 3, 2016 Link to comment
    Yeah i am tired of this version and waiting for marshmallow
    Erica Snow Apr 4, 2016 Link to comment
    Has anyone else had this problem... I am recently unable to turn my phone off, no matter how long I hold the button.... So, I tried a hard reset to which my phone mocked me by not turning back on! This very same thing happened a few months ago and when I took it to Verizon I was told I'd have to take it to an authorized tech since they no longer have in store techs, on my own penny of course, or buy a new phone. I opted to find a tech and was informed its a hardware issue within the phone, not a software issue like Verizon claimed in order to get me out their door and rid of me. Its now started doing it again, any help...?
  • Troy Starkey 1
    Troy Starkey Feb 14, 2016 Link to comment
    Fixed mine yesterday afternoon!!!!
    Download Odin
    Download TWRP
    Flash TWRP with Odin to you phone (Recovery mode)
    Remove battery for 30 seconds, go back to recovery mode, it flashes TWRP permenently.
    Download crDroid 6.0.1 and gapps-slim or mini and copy to your phone SD Card
    Reboot phone, holding up and home button, load into TWRP and clear the caches, system, dalvik and data.
    Install crDroid
    Install gapps-slim
    Wipe cache and dalvic again
    Reboot, done.
    Your phone is now Samdung free, and the battery life has increased. No more overheating issues for me, no more random reboots. Lots faster now too. Enjoy.
  • Benco Swanepoel 1
    Benco Swanepoel Feb 13, 2016 Link to comment
    Hi my Samsung S4 GT-9500 is updated with version 5.0.2 (12-20120216-UNOFFICIAL-i9500) everything works well. Its only when i make a call, the phone is calling out but makes a screeching noise the whole time and I cant hear the other party which I called. Can you help me fix it please.
  • Troy Starkey 1
    Troy Starkey Jan 19, 2016 Link to comment
    Thanks for the tips, however my 3 issues remain. SIM not detected, restart phone.. My hotspot wont route data to any device now and the Services dont stay enabled after a reboot, so my Pebble watch and other apps don work. I want to rollback or flash this crap rom off here. Will never buy another Samsung phone after this piece of trash.
    Robert Boys Jan 18, 2016 Link to comment
    So far so good! Ive been on the Lollipop update since xmas (i9505), and i must say it has been running superb! This article has been great aswell, there were so many settings i didnt know existed or could find, so two thumbs up for this article : ) however, i have been experiencing overheating issues (prior to the new update) but like this article says "it will work itself out in a week" has fixed this issue for me (touch wood). Highly recommend the Lollipop update!
    Lauren M Jan 15, 2016 Link to comment
    I am apparently very lucky not to be experiencing these problems. I just noticed that when I enter my pass code correctly I very briefly see the incorrect pass code message AS my phone is unlocking. Strange but so far no problems actually unlocking my phone.
    Katt V. Dec 23, 2015 Link to comment
    I am glad I came across this article on the update, I won't be updating.
    Troy Starkey
  • Hannah 1
    Hannah Dec 22, 2015 Link to comment
    This 5.0.1 update deleted everything from my phone, contacts, media and games all gone! Now it won't let me open setting or the play store.
    Please someone help.
    dave rendall Dec 19, 2015 Link to comment
    yea, phone updated to 5.0.1 this morning, now my phone is pretty much useless to me. back button and menu button no longer work. tried all the hints i can find through google, i'm not flashing it or pissing about as i'm a normal guy, not a phone geek. so i take it i must bin my phone and buy a new one now?
    • James rafferty 2
      James rafferty Dec 21, 2015 Link to comment
      My fiancee's S4 did the same thing, updated to 5.0.1 and now useless, bad part was it updated through verizons ugrade Assistant. and now it won't boot or even go to safe mode but every once in while. any ideas people? i can use odin to reflash it but not sure if that can be done and still not lose the files on the phone. Help
      UPDATED:
      Found out my power button was stuck. I found this online at another forum and
      tapped the power button side a couple times on my table and wow, started working. although, it hasn't been permanent, it has rebooted back in to android. It was just a coincidence that the button and update happened at the same time. i hope everyone else gets there's fixed. thanks for being here, guys!
      Łukasz First
      Łukasz First Jan 12, 2016 Link to comment
      Hi have you found a solution to fix the menu and back buttons? thank you
      Bradley Atchison
    Jessa Danielle Dec 4, 2015 Link to comment
    My s4 does almost if not all of this since lollipop. It constantly restarts and gets stuck on boot. I've done every step nesessary to try to fix the problem but I don't know what to do to fix it permanently, I really like this phone but I can't call out or receive I can't get two minutes out of it with out it lagging out. Randomly vibrating no sound no video camera crashes only thing that works is sms. Help!!!!
    Łukasz First
  • Matthew Hayden 2
    Matthew Hayden Nov 28, 2015 Link to comment
    My soft touch buttons have stopped working since the update and I have tried a factory reset when are you releasing a fix for this??
    Łukasz First
    Lish Lash Nov 25, 2015 Link to comment
    The mandatory Lollipop 5 downgrade to the Samsung Galaxy S4 is unquestionably one of the most hated software updates ever released by a major corporation. The candy-colored interface is not only childish and unsightly, its low-contrast fonts provoke eyestrain and are nearly illegible in dim lighting. What's even more aggravating are the increased power drain and degraded video playback performance, not to mention the frequent need to manually clear OS caches and restart the phone. Check out the poll below to see what an utter failure Google has wrought with this travesty:
    www cnet com /products/google-android-5-0-lollipop/user-reviews/
Show all comments
