How to recover deleted text messages on Android and iOS
Androidpit on the smartphone 5732
Looking for a way to recover deleted text messages you accidentally deleted?  Don't panic! You can actually retrieve deleted messages if you have the right software and tools at your disposal. And that is what we will show you in this article.
Do note, however, that recovering anything that has been deleted is always tricky and the success rate could vary based on a lot of factors. For example, if the portion of the memory where the old text message resided has been overwritten by a new set of data, recovery becomes exponentially more difficult.
Nevertheless, let's dive right in and see how to recover deleted texts on android and iOS smartphones.
Jump to:
MobiKin Doctor for Android or iOS (Rooting Required on Android)
There are several programs that you can use to retrieve deleted text messages or anything on your phone for that matter. We tried out the software MobiKin Doctor for you, which is our recommended method thanks to its speed and features. As of the latest update (4.2.41) MobiKin Doctor's interface got a new user-friendly redesign, a home page toolbox and optimizations to ensure a smoother connection. The software can be used to recover deleted items but will also display undeleted Android contacts, SMS,  and call logs in case you want to find them.
We'll walk you through the process with the software below, but you can go directly to the website if you want to see the company’s step-by-step guide.
For Android phones or tablets
For iPhones and iPads
Which phones are compatible with MobiKin for Android?
MobiKin Doctor for Android supports over 2,000 Android device models, check their list of supported Android devices to ensure your phone is compatible (under the Tech Specs tab). The list is extensive, so chances are your smartphone is compatible.
By and large, this software should be compatible with any Android device, including the latest models. If you're not sure about this, it's worth running the free trial to check.
You can use the software without rooting your phone, though MobiKin guarantees you'll still be able to retrieve the full extent of your content if you do. To find out how to root your phone, you can follow the MobiKin method here. Please ensure that you also read our complete guide to rooting.
Which Apple devices are compatible with MobiKin for iOS?
MobiKin Doctor for iOS is compatible with all generations of iOS devices.
homepage
MobiKin Doctor can do more than just recover your data. / © Mobikin
How to retrieve deleted text messages on Android using MobiKin Doctor
Once you have rooted your phone and installed MobiKin on our PC, connect your smartphone to the PC and start MobiKin. You will be prompted to allow MobiKin access to your phone. Within a few seconds, you should see a preview of your text messages on the MobiKin main screen, and recovering the data and backing it up onto your PC should be instantaneous.
  1. Once you plug in your phone, a screen will automatically appear on the monitor. It will detect your device, connect to it and let you know when the process is ready to start. You can also see from the screen that MobiKin can be used for Android SD Card Recovery and as a Super Toolkit.
  2. Once it is connected, your phone's data will be displayed, such as model, system version etc. and you will be given the choice of what kind of data you want to retrieve. As you can see from the screenshot below, you have several options of things to recover: contacts, photos, messages, call logs, photos, videos, audio and documents. Select 'Messages' and click Next.
  3. Your data will be retrieved in a few moments and will be displayed as shown in the screenshot below. Here we have selected all the categories but if you've only selected 'Messages', you will only see that section.
  4. Choose to only display deleted items (in case you have a ton of messages), which is easier for filtering. Either select each individual message or you can select them all by ticking the checkbox in the top bar.  Next, select Recover to retrieve the lost or deleted data.
  5. Once your data is recovered, you will be asked to save it directly onto your PC. Choose or create a folder where you want your messages to be saved.
sms
Recovering your text messages is easy with MobiKin Doctor. / © Mobikin
How to recover deleted text messages using MobiKin Doctor for iOS
This works a little differently depending on whether you're running MobiKin Doctor from your Mac computer or Windows PC.
Mobikin Doctor (Mac version)
  1. You don't actually need to connect your iOS device to the Mac for this to work. Instead, just launch Mobikin Doctor and it will auto-detect and display all iTunes files of your iPad, iPhone or iPod which has ever synced with iTunes on your Mac.
  2. The data in the iTunes backup file will be categorized into specific folders. Click these folders you can preview the detailed contents in the right panel. Text contents will be displayed in list view mode while the media files can be viewed in the Thumbnail view mode.
  3. Find the data you want to extract or restore, and then check them one by one.
  4. Hit the "Recover" button to save the exported files to your Mac computer.
Mobikin Doctor for iOS (Windows version)
  1. Connect your iOS device to the PC, launch Mobikin Doctor and hit 'start scan'.
  2. Wait for the scan to complete.
  3. The data found on the device will be categorized into specific folders. Click these folders you can preview the detailed contents in the right panel. Text contents will be displayed in list view mode while the media files can be viewed in the Thumbnail view mode.
  4. Find the data you want to extract or restore, and then check them one by one.
  5. Hit "Recover" button to save the exported files to your computer.
If you don't have your device in hand, then you can also run Mobikin Doctor on your Windows PC without connecting the device and select "Recover from iTunes Backup File" on the top menu to scan your iTunes backups for the files you want to recover, text messages included.
Another option in Mobikin Doctor is  "Recover from iCloud Backup File". This will require you to log in to iCloud with your Apple ID and password and then you can scan your iCloud backups for the files you want, just as with iTunes.
Backing up text messages on Android
Whether recovering your deleted messages worked or not, it's always best to take preventive measures, so you don't lose them again. Some manufacturers like Samsung offer up to 15 GB of free cloud storage, which you can use to back up various phone data, including text messages. On most Android phones, however, you can simply use your Google account to do this.
  • Go to Settings, then find Google (Services & preferences).
  • Tap it, scroll down and go to Backup.
  • Enable Back up to Google Drive. You will be asked to add an account to back up to. After that simply tap Back up now. This could take a while depending on how large the files are. Afterwards, your call history, contacts and text messages should be safely backed up.
android 10 backup2
This is how your Google back up settings should look on most Android phones. / © NextPit
However, if you specifically want to back up your text messages and nothing else, you could use a third-party app instead. SMS Backup+ is a great way to do so and it's free. The app can back up call logs, SMS and MMS to your Gmail. Of course, you will need to connect your Google account to do so. After doing that you can choose when the back up is performed and what you want to be saved. You will find your messages in a folder usually named SMS in your Gmail - convenient and easy.
You can also play it even safer by regularly backing up everything that's on your phone. Here's our guide on how to do that:
Recovering your messages on iOS
Apple also provides extensive backup tools based on your iCloud or iTunes account. If you have ever made a backup to either of these services, your text messages should also be available to be recovered from the backup.
iTunes backup and restore
  1. By default, you should have created a backup of your phone's data, including messages, every time you synced with your PC or Mac, so you can try recovering deleted text messages via an iTunes backup.
  2. Assuming you didn't disable this, automatic sync, then this is probably the fastest and easiest way to recover your texts. Use the following method to do so.
  3. Connect your iPhone to the PC/Mac with which you normally sync it. iTunes should open automatically (if not, open it manually).
  4. You should see your iPhone appear. Select it.
  5. Now choose Restore backup.
All the data you previously backed up will now overwrite the data on your phone. It will take a few minutes and yes, anything you saved after the backup will be lost. As long as you didn't back up via iTunes after deleting those messages, they should now be back on your phone.
iCloud backup and restore
If iTunes didn't work, then there's always iCloud, though specifically trying to restore text messages can be tricky.
When Apple introduced Messages in iCloud a couple of years ago, you need to be aware that while enabling this syncs your messages across all your devices which use the same Apple ID, there's also a catch. Because if you delete your messages from one device with iCloud sync, those messages also get deleted from the other devices. Furthermore, messages are not included in an iCloud backup.
If you really need to restore your messages via an iCloud backup, you need to factory reset your iPhone and then restore it from an iCloud backup that was made before the text messages were deleted.
This is a drastic step, so first make sure you have such a backup in the first place by checking in Settings > [Your Name] > iCloud > Manage Storage > Backups. Note that the last successful iCloud backup time/date is always displayed right below the Back Up Now button.
If you do, then you need to factory reset your iPhone before restoring it via that iCloud backup. To restore factory settings on the iPhone, follow these steps:
  1. Open the Settings menu
  2. Scroll down to the General menu and tap it.
  3. Scroll all the way down to the bottom and tap the Reset option
  4. At this stage, you'll be presented with a number of reset options, ranging from a simple reset of iPhone's settings to resetting its dictionary or home screen layout. There's nothing specifically called "factory reset." The option you want is Erase All Content and Settings. Select it.
  5. At this stage, you'll be prompted for your passcode if you have one
  6. iOS will warn you one last time. You can still cancel, or go ahead with Erase to proceed
  7. It can take a few minutes to erase everything depending on how much data you have. But at the end of the process, your iPhone should restart just like new.
When it restarts, select to restore via the iCloud backup that contained your deleted texts.
Have you ever deleted or lost your text messages by accident? Did you manage to recover them? Have you got a better way than with Mobikin Doctor? Share your tips and experiences in the comments below.
Go to comment (134)
134 comments
  • DL mobitools 1
    DL mobitools Aug 25, 2022 Link to comment
    Very helpful content.. I have read this informative article and now I am able to recover my deleted messages easily.
    Sarah Wendy Nov 10, 2021 Link to comment
    hello
    David Jan 27, 2021 Link to comment
    Well, iMobie PhoneRescue worked for me.
    ZoeDenver Jan 23, 2021 Link to comment
    Is it really possible?
    gadha Dec 18, 2019 Link to comment
    I tried Mobikin, it was useless on Galaxy S9, didn't show any deleted messages nor did it recover. I tried it immediately after deletion and was forced to buy a subscription before I could undelete (which it never did). Mobikin software is useless and uses mycommerce which will subscribe you to the product automatically, and charges your credit card info. Beware before you download anything from mycommerce including mobikin. It seems a scam to me.
    Also, their mobikin support is horrible, they do not have a 800 number to call. They don't respond to your questions.
      Alice Smith Sep 10, 2020 Link to comment
      You're not the only one. I used Mobikin and ran into the same problem you encountered. When I scanned the phone, it didn't show any deleted messages, even with multiple attempts. After that I did further research and found the solution. Those software all require the phone to be rooted, so you will need to do that first to your device. With root access, it can scan and recover files that would normally be inaccessible. BTW, I have successfully recovered the messages.
      Tips: Have patience and do a little research and reading. The product is easy and simple to use.
    JillianHarris Sep 11, 2019 Link to comment
    I don't know how to recover deleted messages I lost I lost before I found this method.
    ow.ly/wlqp3025cU7
  • 25
    Deactivated Account Feb 11, 2019 Link to comment
    Thank you for the informative article.
    Hare Krishna ??
    R2D2 Oct 1, 2018 Link to comment
    Hi, is this application support Huawei Nova 2i? Or should I need to root also my phone before using it? Please advise. Thanks in advance
    • Nicholas Montegriffo 11
      Nicholas Montegriffo Nov 6, 2018 Link to comment
      In theory it should support all the Huawei phones. If you want to recover deleted contacts, call logs and messages, you need to root the phone first. But if you want to recover photos,music, videos and documents, it should be possible just by turning on usb mass storage and running the program. If you have issues with it, try the support page (https://www.mobikin.com/support/android-doctor-faq.html) or email MobiKin at support@mobikin.com to get more help.
    jill brahams Sep 22, 2018 Link to comment
    After installing Mobikin Doctor and following the instructions found that it was unable to recover any deleted files. As such it is difficult to recommend Mobikin Doctor because it just doesn't function in the way advertised, a complete waste of time.
      We checked with Mobikin about this and they asked to make sure that you didn't write new files to your phone after you deleted the files, or the deleted ones may be overwritten by the new data and may not be able to recovered again. If you still have any problems, try emailing support@mobikin.com and they can help you out.
    dane Jul 30, 2018 Link to comment
    hi..i just want to ask if this is for free or is it a paid app for recovering messages?thanks
      Nicholas Montegriffo Sep 11, 2018 Link to comment
      Hi Dane, the software isn't a mobile app, it works from your PC or Mac. There's both a free trial download and a paid version (with a 90 day money back guarantee). You can check out the prices and conditions here: https://www.mobikin.com/doctor-for-android/
    Kimmi Jun 12, 2018 Link to comment
    Will this app to recover text messages cost me anything?
      Hi Kimmi, the software isn't a mobile app, it works from your PC or Mac. There's both a free trial download and a paid version (with a 90 day money back guarantee). You can check out the prices and conditions here: https://www.mobikin.com/doctor-for-android/
  • 27
    Sorin Apr 28, 2018 Link to comment
    The easiest way is to use a microSD card reader...
  • Charnay Haarhoff 1
    Charnay Haarhoff Nov 10, 2017 Link to comment
    I have downloaded the Mobikin Doctor on PC and Huawei phone, it connects but, then asks me to scan the barcode which does not show on my PC? Please assist
    • Loie Favre 33
      Loie Favre Jan 17, 2018 Link to comment
      Hi Charnay, your problem is one that we have not yet encountered yet in our experience with the program. There is a link here that talks about your phone not being recognized https://www.mobikin.com/android-backup/what-to-do-if-the-program-does-not-recognize-android-device.html however if you don't find the answer here, you should contact MobiKin directly as they will be able to provide you with catered help. You can write them at support@mobikin.com and their customer service expert will be able to assist you.
      Sorin
  • Paul Mercado 1
    Paul Mercado Oct 18, 2017 Link to comment
    Hi I want to print a conversation to .pdf which I normally do in SMS Backup & Restore but because it is a grouped recipient conversation SMS omits saving it.
    Mark Alan Feb 22, 2017 Link to comment
    Hey,
    Is Samsung Galaxy S7 Edge supported by any of the programs above?
      Nicholas Montegriffo Jul 17, 2018 Link to comment
      Mobikin should work with the S7 Edge, but you could always do a free trial to check if the phone is compatible.
    Stephen Bradley Jan 26, 2017 Link to comment
    Are the programs compatible with Samsung S7 edge? I need to find a cheaper alternative, a free one would be even better.
  • 9
    golaok Dec 9, 2016 Link to comment
    I tried this tool. First it did not work, then I checked their guide I understood why. I didn't root my Android phone, I followed the steps and rooted my phone, then it works. Thank you so much for your sharing.
      Tracy Dy Feb 12, 2018 Link to comment
      how to root???
    JennaJameson Dec 8, 2016 Link to comment
    They all don't work.
      Loffea Dec 9, 2016 Link to comment
      I downloaded the mobikin app, but which didn't detect my phone, I have an LG G4, and then I realized that it wasn't rooted. They told me the recovery function only works on rooted phone. Ok, after it was rooted, finally the phone was recognized. The process sometimes can be long, but you need to wait for a moment. Then, everything seemed well, the phone was detected and all the data were displayed on the left. I guess I have a lot of files in my phone, so it took a long time to display them all. Like it is introduced, the lost texts were in red, and they were listed at the top. There is one thing I am not satisfied with, the recovered data can be only saved to pc.
    Ian Dacey Nov 11, 2016 Link to comment
    I downloaded wondershare Dr. fone and for some reason even though I followed all the steps, the download stops at 90% and continually restarts my phone. Is this normal? Am I doing something wrong? Please help!
    • Aureanna Busko 1
      Aureanna Busko Apr 27, 2017 Link to comment
      My s7 did the same thing, did you ever get it to work?
  • Jay Dempsey 1
    Jay Dempsey Oct 5, 2016 Link to comment
    When recovering deleted SMS texts from Galaxy S3, does it show on PC, or put back on phone?
      Loffea Oct 17, 2016 Link to comment
      Hi, the recovered data will be showed on PC.
  • Albin Foro 30
    Albin Foro Sep 21, 2016 Link to comment
    I've long been using free little "SMS to Text" which saves selected threads as a *.txt or *.csv file that can be opened with columns in a spreadsheet. I don't need / want to restore them to the message app but to have available for future reference. Having all those saves in sequence in a single spreadsheet - to be searched or sorted by any column - works well for my purposes.
    Sorin
    Rweethy Jul 15, 2016 Link to comment
    Recover messages from Android phone .You need to download and install it on your computer. All you need to do connect your Android phone to the computer through USB cable.
  • Ayesha Asghar 1
    Ayesha Asghar Jul 11, 2016 Link to comment
    Both apps asked to register for a paid account to retrieve texts
  • Alfred Gilbert 5
    Alfred Gilbert Jul 5, 2016 Link to comment
    The FonePaw is nice. How is the MobiKin Doctor?
      Werf Abb Jul 6, 2016 Link to comment
      I tried MobiKin, works well on recovering sms
  • WickedSweetDreamz 10
    WickedSweetDreamz Jul 4, 2016 Link to comment
    I downloaded Mobikin but my phone wouldn't let me open it and I can't afford to get the other one right now so I guess I can't get back my lost messages. I seem to be losing messages a lot that I am not deleting. So I don't know why this is happening.
  • Isaac Edidiong 2
    Isaac Edidiong Jul 4, 2016 Link to comment
    nice and great
    Good share.
  • 11
    chayusiro Jul 1, 2016 Link to comment
    When we lost texe messages by accidently, we’ll be unable to find the chat record, especially those from important people, such as our friends, important customers, and even the boss. I bet we won’t want to see this happen. Then we need to do something to restore your deleted text messages just like the article wrote.
    lucyll Jun 28, 2016 Link to comment
    Recover lost text messages from android phone
  • Agatha Alice 5
    Agatha Alice Jun 27, 2016 Link to comment
    Thanks for sharing, the text messagtes are not really deleted, in case you don't save many new data to your phone overwritten them.
    zxcv qwer Jun 23, 2016 Link to comment
    Thanks for sharing, yes, we can still recover lost mobile phone text messages with a android phone sms recovery app.
  • Lacy Craig 1
    Lacy Craig Jun 21, 2016 Link to comment
    I only have internet on my phone, do I need to have it on my laptop to do this?
  • Menka K. 11
    Menka K. Jun 4, 2016 Link to comment
    So many suggestions from everyone so I'm sure the one who are landing here would be confused which one to choose.
    Sorin
  • Menka K. 11
    Menka K. Jun 3, 2016 Link to comment
    Root your device and you can easily get your deleted text messages back.
    Sorin
  • Menka K. 11
    Menka K. Jun 2, 2016 Link to comment
    This topic gets about 10 new comments everyday. Cool, isn't it?
    Sorin
  • Menka K. 11
    Menka K. May 29, 2016 Link to comment
    I'm sorry I posted same messages twice.
    Sorin
  • Menka K. 11
    Menka K. May 28, 2016 Link to comment
    It's high time guys start backing up your devices.
    Sorin
    Jesson Black May 9, 2016 Link to comment
    ninice ad here
  • Menka K. 11
    Menka K. Apr 28, 2016 Link to comment
    Stop advertising folks!
    Sorin
  • Alex 17
    Nice article
    Shilpi Agarwal Apr 1, 2016 Link to comment
    Very informative.
  • vineela bolla 1
    vineela bolla Mar 29, 2016 Link to comment
    Why Nexus 4 not updated 6.0 version
    meredithchris Mar 23, 2016 Link to comment
    Good sharing. I have lost my text messages on my Samsung Galaxy S6 and using recovery to recover it too. When i mistaken deleted my data I think I will lost them forever, but FonePaw help me get them back. So thankful.
    Alice Young Mar 2, 2016 Link to comment
    Thank you. But you missed an important reminder: Don't send more messages or make any other operations to y our Android if you want to recover lost data. Because new data will overwrite the old data in your phone, which means the deleted data.
  • pie app 1
    pie app Feb 19, 2016 Link to comment
    i cant enable developer on my phone.
    Bernie A Feb 17, 2016 Link to comment
    Stuck on # 1 step. Won't do anything else.
    checked USB cable, tried reconnecting.. no luck.
    notification bar tells me, USB debugging connected;
    and connected as a media device.
    yet, cant move forward. Please help!
    Schmoopy Head Feb 10, 2016 Link to comment
    Wondershare Dr. Phone is the program that DESTROYED my computer. I had to temporarily disable Chrome's security settings to even install it so it was sketchy AF, but I was desperate to recover deleted info on my phone. IMMEDIATELY after I installed it my computer was unrecognizable. Wondershare Dr. Phone installed several undeletable viruses like Hades that kept downloading new programs. I tried to get rid of them but they wouldn't even show up in the Control Panel. I also couldn't make a single click without opening a new advertisement in my browser. My PC which I'd had for less than a year was completely unusable. DO NOT INSTALL IT NO MATTER WHAT YOU DO. Kris Carlon is an IDIOT who doesn't know what he's talking about and all these commenters making identical posts about Wondershare Dr. Phone in monkey English are shills and trolls. If you download this crap you WILL be throwing away your computer.
  • 12
    lianne john Feb 5, 2016 Link to comment
    Good write up!
  • Menka K. 11
    Menka K. Jan 20, 2016 Link to comment
    The programs these guys are suggesting are completely useless.
    Sorin
  • Confused Person 1
    Confused Person Jan 14, 2016 Link to comment
    I used the Dr Fone program and all it did was make my phone keep restarting and it installed a malware app onto my phone...
  • Menka K. 11
    Menka K. Jan 7, 2016 Link to comment
    This is how we roll guys.
    Sorin
    Andrew Giordano Jan 6, 2016 Link to comment
    is there anyway possible to retrieve a message from over a year ago? Or is it too late.
    zxcv qwer Dec 30, 2015 Link to comment
    Thanks for sharing, yes, we can still recover lost mobile phone text messages with a mobile phone sms recovery app.
    Emi Chang Dec 21, 2015 Link to comment
    Thanks for sharing, yes, we can still recover lost mobile phone text messages with some data recovery app, and most of them are very easy to use.
    Agatha Alicezxcv qwerDeactivated Account
    Deactivated Account Dec 18, 2015 Link to comment
    Check it if you have backup phone data to computer or google account .If you can not find , then use some apps to recover lost text messages is a simple task.
    Deactivated Account Dec 16, 2015 Link to comment
    Good article !
    Deactivated Account Dec 14, 2015 Link to comment
    Thank you for your professional suggestion! i think it is very good!!!
    Zephyr7 Dec 11, 2015 Link to comment
    I backed up my SMS through Chomp to my email. Saving it as a txt. file. Is there anyway to get it back onto my android? I have tried converting the txt. file to xml, but SMS backup & restore does not recognize it
    Deactivated Account Dec 7, 2015 Link to comment
    Well, thank you for your professional suggestion!
  • Agatha Alice 5
    Agatha Alice Dec 7, 2015 Link to comment
    Jeff Wentz Dec 5, 2015 Link to comment
    Any FREE text retrieval tools??
  • Menka K. 11
    Menka K. Dec 2, 2015 Link to comment
    All these software work after a root.
    Sorin
  • Menka K. 11
    Menka K. Nov 27, 2015 Link to comment
    Don't try any software/app to recover your deleted data you might loose your existing data as well.
    Sorin
  • Menka K. 11
    Menka K. Nov 26, 2015 Link to comment
    Once the data is gone there are around 30% chances of getting your data back.
    Sorin
  • Menka K. 11
    Menka K. Nov 9, 2015 Link to comment
    Some links are gone. Good news.
    Sorin
    Glenn Nov 6, 2015 Link to comment
    The software recommended here is a scam. They are the same under different names. Your phone must be rooted for it to work and the settings do not exist on all Android phones.
  • Menka K. 11
    Menka K. Nov 5, 2015 Link to comment
    It's getting on my nerves too. Some people are literally recommending anything.
    Sorin
  • lingLi 2
    lingLi Nov 5, 2015 Link to comment
    Although the text messages lost, you can use some great tool recover deleted text messages from Android phone easily. I have a recommendation for you get text messages back. Have a try MobiKin Doctor for Android. I find it on softonic website. It work fine.
  • Menka K. 11
    Menka K. Oct 29, 2015 Link to comment
    Start backup up your devices peeps.
    Sorin
  • Menka K. 11
    Menka K. Oct 24, 2015 Link to comment
    They are talking about the same tools with different names.
    Sorin
  • Menka K. 11
    Menka K. Oct 21, 2015 Link to comment
    Don't get carried over by these comments. These folks just trying to help.
    Sorin
    Iron Man Oct 18, 2015 Link to comment
    Well i have a Samsung Core SM-386W but it seem's that there's no prog to recovering my erased messages anyone know's some way to get it ?
  • Menka K. 11
    Menka K. Oct 16, 2015 Link to comment
    It's so good to see that everyone is helping each other.
    Sorin
  • Menka K. 11
    Menka K. Oct 10, 2015 Link to comment
    Most of the times you have to root your device before using anything to un-delete any type of file.
    Sorin
  • Menka K. 11
    Menka K. Oct 3, 2015 Link to comment
    Backing up text messages is much more easier than recovering them.
    Sorin
    Alisa Nancy Sep 28, 2015 Link to comment
    Hey Kris,
    Great article. Thank you very much for sharing this.
    I just purchased my first Android phone Samsung Galaxy S 6. And I have been using iPhone for more than 5 years. So I am not that familiar with Android. I always operate my Android phone thinking I am using an iPhone. So the yesterday, I deleted my text messages with my friends and I really want to get back the text messages. Then I searched on google and find your article and many others. I just get back my text messages. Thank you very much.
    Jose P Sep 25, 2015 Link to comment
    Whether you deleted or lost text messages from your phone, you're recommended to try not to use your phone for SMS receiving and sending to avoid data overwriting. That's a pain to have some of my messages lost forever. Go to find a professional recovery tool for help.
  • Menka K. 11
    Menka K. Sep 22, 2015 Link to comment
    Stop using your Android wouldn't going to increase your chances of data recovery.
    Sorin
  • Menka K. 11
    Menka K. Sep 19, 2015 Link to comment
    Please guys stop sending me messages in my inbox for the software key. I can't share/sell it.
    Lily Heye Sep 18, 2015 Link to comment
    There are also more easy solution to recover your deleted SMS messages on the internet.
  • Menka K. 11
    Menka K. Sep 12, 2015 Link to comment
    Recovering deleted text messages isn't that easy especially if you keep using your device.
    Sorin
    Haru Chan Sep 8, 2015 Link to comment
    well, the wonderfoneshare contains malware..
  • Menka K. 11
    Menka K. Sep 1, 2015 Link to comment
    I've used Bitdefender Internet Security 2015 and Anti Malwarebytes to scan Wondershare but they couldn't found any malware or virus in these programs.
    Sorin
  • Vivian Lee 1
    Vivian Lee Sep 1, 2015 Link to comment
    Thanks for sharing. It really helps.
    I think it is always wise to regularly backup your android phone to avoid the data loss.
  • Little Stacy 6
    Little Stacy Aug 28, 2015 Link to comment
    Why not make backups regularly or automatically? All my data can be synced to my Onedrive. So I will never lost my data.
    Chloe Moretz Aug 21, 2015 Link to comment
    To be honest, it isn't a nice idea to recover deleted text messages by this way. I recover my SMS from IPhone 5S successfully by following this guide.
  • Menka K. 11
    Menka K. Aug 20, 2015 Link to comment
    This is certainly the hottest topic of Android Pit.
    Sorin
  • Ann Doris 3
    Ann Doris Aug 14, 2015 Link to comment
    I've had the bad experience of deleting important text messages by accident. I'm so pissed off... Now I use Apowersoft Phone Manager to backup all my important data to PC so that I can recover them if they are lost, again.
  • Menka K. 11
    Menka K. Aug 11, 2015 Link to comment
    Now they started giving their email addresses too. Height of spamming.
    Sorin
    Lily Aldridge Jul 31, 2015 Link to comment
    Android users are getting annoyed by losing personal data on the phone. However, the lost data are still in our phone memory, just use professional recovery tool, we can get them back.
  • Menka K. 11
    Menka K. Jul 29, 2015 Link to comment
    This topic is attracting lot's of spammers. :P
    SorinDeactivated Account
  • Menka K. 11
    Menka K. Jul 19, 2015 Link to comment
    It's almost impossible to find that one app/software that can recover every single file from your Android device.
    Sorin
    Daniel Bissell Jul 9, 2015 Link to comment
    I loaded this trial version on the PC and was liking how it easily found my dads old Motorola Atrix. It took awhile but it finally finished. No text messages were found from a phone that had them 3 hours before a factory refresh. It did say that it found 1,187 pictures. Some had been deleted for over a year when he ran out of room the 2nd time. He has since then had to do this 3 more times, so I am pretty sure those pictures are crap or in just name only. Since you can only see what it could do with what it found and not retrieve anything without paying, I uninstalled the software from the PC. I then called AT&T and had my dad answer a few questions for them to prove he is who he is and they sent him his texts. Don't go to the store to do this. They are Sales and not Techs.
    Next I had to setup AT&T Address Book and verify that his contacts were there via the web browser on his computer. You can also see your text messages there as well. I then copied all the had-to-have messages to a word document.
    After doing this I had to do another hard Factory Reset. Why? Because when I installed wondercrap onto the PC and let it detect the phone, it installed malware the form of some memory manager thing that would popup after 2 browsing attempts. I screamed DON'T CLICK IT! and grabbed the phone. Said oh crap. Clicked the X and handed it back to him. A day later he said it is still doing that so I did what I did in the previous paragraph.
    Don't waste your time
  • Menka K. 11
    Menka K. Jul 6, 2015 Link to comment
    Why don't use guys use the the apps like SMS Backup and Restore to backup your text messages?
    SorinDaniel Bissell
    noahrobert Jul 5, 2015 Link to comment
    It is good to know that you can use FonePaw Android Recovery tool to get back the messages that yo have deleted by mistake.
  • Lar fious 4
    Lar fious Jun 30, 2015 Link to comment
    When it comes to file recovery, the first thing to bear in mind is that there are no guarantees. Data that's gone may very well be gone for good, especially if the device has been used since the file or files were deleted and new data has overwritten it. However, nothing ventured, nothing gained (or lost).
    Mary Colins Jun 3, 2015 Link to comment
    good news to share here. if you are worried about some Android files recovery tool unable to support your Android 5.0 or newer, you can turn to a more professional and versatile one.
  • Menka K. 11
    Menka K. May 3, 2015 Link to comment
    With the new Android 5.0 Lollipop it's more harder to recover deleted data from Android device as most of the Android recovery tools doesn't support this latest Android.
    Sorin
    Ashraf Morsal Feb 27, 2015 Link to comment
    Thanks alot ANDROIDPIT
    RBell Feb 15, 2015 Link to comment
    This was a very interesting and useful article I discovered having accidentally deleted a text message conversation thread on my new phone (SM-G357FZ).
    However, following it and other similar articles, I discovered that for the vast majority of stock Android phones (ie. not rooted), it is not possible to recover deleted normal SMS/text messages. This being due to SMS messages being stored in the phone's flash memory, which is largely inaccessible to analysis from stock Android.
    Obviously, if any one can point out a tool that can reliably recover deleted SMS messages held in the phone's normal message store without requiring either a specific device or a device to be root'ed, I would be interested...
    So to emphasis the second part of the article it is better to install as standard an SMS Backup tool such as SMS B&R which effectively reads the SMS message store and stores a copy on to the SDcard or elsewhere (user configurable location) and set it to perform a regular backup/export.
    Lar fious
    • Neelesh Patel 4
      Neelesh Patel Mar 24, 2015 Link to comment
      The same thing happened to me last week on my Droid 4. I was replying to a text, the phone locked up, I rebooted, and all my texts were gone, then I search it on the web and I found this guide would be useful, people should not miss is
      PS: I also found other solution, but I'm not sure if it works for you.
      Go to the contact in your contact book press the menu button and then hit history and all your deleted messages and threads should be there..
      Lar fious
    Michael Marchbanks Jan 20, 2015 Link to comment
    Is it possible to retrieve text that were deleted over a year ago?
      Deactivated Account Mar 17, 2015 Link to comment
      It is hardly to recover text messages deleted over a year ago, as the messages probably be overwritten by new content.
    Michael P Nov 10, 2014 Link to comment
    WARNING! I used SMS Backup and Restore several times to back up my Android text messages for a court case, and in several cases it DELETED several dozen emails. It appears to happen when the app crashes while creating the backup database. I got in the habit of running the app every few months, and sometimes it worked fine (no crash and no deleted messages) while other times it crashed, and when I checked both the phone itself and the backup file there were dozens of messages missing. Hopefully there is another app out there which is more reliable?
  • Sam496 1
    Sam496 Nov 8, 2014 Link to comment
    There are loads of website, which claim to be able to recover lost and deleted text messages from Androids, such as and others, like this Wondershare, etc. but I've heard they're not that good? I'm a bit confused as to whom to trust. Which one is the most trustworthy one? Thanks in advance.
    Bj isa Oct 29, 2014 Link to comment
    I lost videos on my S3 and cannot Recover the lost data because the computer is not seeing the phone memory as a drive. I downloaded recuva but won't see the phone as a drive. It is not assigning a drive letter. Any help please??
    Marwa Mohammed Oct 29, 2014 Link to comment
    I tried those steps but it doesn't work :( am so disappointed. coz i lose my SMS history that i rested my Mobile before take a backup :( what should i do any help plz???
    lingZhang Oct 29, 2014 Link to comment
    It is possible to recover deleted text message from android phones, but you should make sure have backup files somewhere.
    1. Google account, if you have a google account for your android phone and open the automaticalli sync, you can try to recover from google account.
    2. Offical PC software, generally speaking, an android phone need to upgrade in computer via a official PC software, such as Samsung PC studio, and this applicaiton have a automatically backup function, when you connect the phone to computer and launch the application, it will make a backup for your phone data, thus you can try to find the backup from PC studio.
    3. The 3rd-party "MobiKin Doctor for Android", which is similar with PC studio, and it is more convenient, and the backup is more obvious
    Deactivated AccountDeactivated AccountHimyNio
  • Barry H. 2
    Barry H. Sep 30, 2014 Link to comment
    And for those of us who prefer not to be beholden to Apple or Microsoft, but use open source for all our computing - with Linux - is there an equivalent to these commercial programs in the free world?
    I mean, what's the point of having an open-source phone if I have to rely on a commercial operating system to work on it?
    lockmanjcir Jul 10, 2014 Link to comment
    I finally found these three Android Recovery tools all seems to be useful because I have simplely restore deleted SMS from Samsung. So is there anyone tried successfully restoring lost data with other program?
    Mavish98 Jun 25, 2014 Link to comment
    Actually i recently updated my galaxy grand quotrro to 4.1.2 and when i returned i saw my phone empty(means all contacts and messages on PHONE were lost).All i was left wa the memory in sd card .
    Please help
    • Kris Carlon 35
      Kris Carlon Jun 25, 2014 Link to comment
      As mentioned above, act quickly! Turn off your data so nothing new gets written over the top of what is already saved on your memory card and get some recovery software and follow the steps. This tutorial is a good start!
      Sorin
    Deactivated Account Jun 24, 2014 Link to comment
    If you deleted them then recover them straight away then you'll 100% get them back, but if you've been using your phone a lot and over writing those deleted data... then your chance of getting all of them back will be slimmer. Try to recover your data, you'll need one software.
    Bur Vice Jun 18, 2014 Link to comment
    i hope Apple finds a solution to this problem, which is becoming more common as the iPhone users increase. The good news is, you can get your messages back, but the not-so-good news is, there’s no free method available. I can’t speak for other websites, but this one have I personally used and it’s quite a good user guide. I accidentally lost some irreplaceable messages, and because it's a lifetime licence they gave me, I can always re-cover – that is, as long as I have my iPhone.
    There are some others,so do your research and I hope you get your stuff back (if you haven't already).
  • Kris Carlon 35
    Kris Carlon May 31, 2014 Link to comment
    Just to clarify, SMS Backup and Restore is not going to help you RECOVER lost messages, just back them up when they are safe on your phone and then restore them (but only if you've saved them first!). If you haven't backed them up SMS B&R won't be any use.
    Sorin
    Ngozi Nwoke Mar 25, 2014 Link to comment
    Hello,guy! I suffered from the same problem last month. In fact, it is possible to recover deleted text messages from Samsung Galaxy S3, after the trouble I searched for solution for text messages recovery on the web. Finally, I learned that I can use an software called Tenorshare Android Data Recovery software to get back deleted data from Android phone.
    Good luck!
    Robert Dell Jan 15, 2014 Link to comment
    SMS B&R works great also if you have to do a factory reset, or move to another phone. Just backup your messages to your SD card, then restore from there when the reset is done or put it into the new phone. Now you don't have to lose all your messages.
    • Menka K. 11
      Menka K. Oct 1, 2014 Link to comment
      Agree. It's a great app if you're switching from one device to the another and want to transfer your text messages from your old device to the new one.
    Dipro Sarkar Jan 13, 2014 Link to comment
    You can even schedule it on an archive basis.
    JonesW
    Megha megha Jan 10, 2014 Link to comment
    Its time to download this SMS Backup & Restore free app.As it suggests,hope its not time consuming.Well it seems to be.
    • Kris Carlon 35
      Kris Carlon Jan 10, 2014 Link to comment
      Not time consuming at all! From installing to backing up it'll take you less than a minute. But do spent another minute to export your backup and set a backup schedule. That way you'll never lose another SMS again!
      SorinScott
