What Is Matter? The Smart Home Standard That Changes Everything
What is Matter smart home standard and thread
With support from Apple, Amazon, Google, and Samsung, Matter promises to become the standard to rule them all in the smart home category. What is Matter, what is Thread, what is in it for you, and what types of products does it support? nextpit introduces you to this new standard and answers the most pressing questions.
Table of contents:
What is Matter?
Matter was launched in late 2019 by the Connectivity Standards Alliance (CSA), an organization formed by major brands including Apple, Amazon, Google, and the Zigbee Alliance, with additional industry support. It’s a royalty-free connectivity standard designed to improve compatibility across smart home products. Originally known as Connected Home over IP (CHIP), Matter uses Internet Protocol (IP) to link devices, ecosystems, and apps across platforms.
The following four communication protocols are supported by Matter.
  • Ethernet / LAN cable (IEEE 802.3)
  • Wi-Fi / WLAN (IEEE 802.11)
  • Thread (IEEE 802.15.4)
  • Bluetooth Low Energy
Think of Matter as the USB of smart home devices. Just as the now-universal connector replaced legacy plugs like serial, game port, and DisplayPort, Matter is designed to simplify compatibility across smart home ecosystems. Instead of choosing between Siri, Alexa, or Gemini for control—or between Z-Wave, Wi-Fi, or Zigbee for communication—Matter offers a unified standard. Thread acts as its primary communication protocol, streamlining how devices connect and interact.
Of course, that leads to the classic situation best exemplified by xkcd’s famous comic. But the sheer clout of all companies involved leads us to believe that Matter will become the market standard.
Matter promoter group
Most major smart home companies are behind Matter.  / © Matter
The picture above looks very impressive because big names like Apple, Google, and Amazon are there. We also see the smart lighting experts par excellence with Signify (Philips Hue), and Samsung also represented by SmartThings. But that's only a fraction of what you can expect. If you were to take a look at the CSA (Connectivity Standards Alliance) page, you'll see that there are now over 200 names there, and that includes a list of who's who in the smart home sector.
What is Thread?
The key difference between Thread and standards like Wi-Fi or Bluetooth is that Thread creates a mesh network. That means any device permanently connected to power and compatible with Thread can help extend your smart home’s coverage. For instance, if a door lock isn’t within direct range of your alarm system, it can still communicate with it through a Matter-enabled light bulb.
The good news? You don’t need to manually set up this network. Matter devices automatically coordinate and determine the most efficient way to communicate with one another. To link your Thread network to the outside world, or to your smartphone, you only need one device at home that acts as a Matter “border router.” Devices like the HomePod Mini, the latest Amazon Echo, and the 3rd-generation Apple TV 4K already support this functionality.
What advantages do Matter and Thread offer?
Advantage 1: Interoperability
What does this mean for you specifically in the event Matter establishes itself as the primary standard? First of all, it won't matter (heh!) whether you use the Apple HomeKit, Samsung SmartThings, or any other ecosystem under the Matter umbrella. You'll be able to control your smart socket, which you've been controlling via Gemini, via Alexa—or simply control both simultaneously.
Imagine living in a household that uses both Android and iOS. Under Matter, it does not matter which smartphone you use, which ecosystem, and which smart assistant. This way, every family member can use their preferred operating system or favorite assistant in the future.
Advantage 2: Acquisition and selection
Buying smart products will be much easier for you in the future. You will have a huge selection of smart products to choose from and will no longer have to spend hours searching between different smart home solutions to find the one that fits the platform in your home. All you have to do is make sure that the Matter or Thread symbol is printed on the box.
Here is another plus point for you: The companies themselves no longer have to certify their products for several ecosystems at once. This saves both time and money in production and thus also helps to provide even more choice.
Advantage 3: Installation
Another advantage is that it will be easier for you to set up new hardware. As is currently the case with Apple Homekit, a QR code will suffice for installation in the future, saving you both time and frazzled nerves. However, that's not all by a long shot, no sir!
More importantly, the mesh principle behind Thread means you won't need any bridges or repeaters to expand your existing home network. Virtually any Thread device with a permanent power connection will be able to do it for you. This makes building your smart home network much (far more!) easier and hopefully, cheaper.
Advantage 4: Independence
You'll also become more independent: if you've already sunk a lot of money into one manufacturer's smart home ecosystem, for example, switching to another company is an unattractive proposition. This is set to be a thing of the past with Matter, because in the future, you should be able to mix light switches from Xiaomi and Bosch, for instance. We are extremely excited to see how this will change smart home ecosystems in the future.
This doesn't just apply to hardware, by the way, but also to the apps you use to operate your smart home. For example, if Signify wants to, they could integrate Matter-compatible vacuum cleaner robots into their Philips Hue app down the road. In this case, however, the full range of functions may not be available as in the native manufacturer app of Roborock and other manufacturers, simply because Matter only specifies one hull functionality per product category, which manufacturers must make available to the Matter universe.
Advantage 5: Security
For hardware to be certified as Matter-ready, it must meet the minimum security standards. You might assume this is already a given with the major players in the first place. But now, you get such a degree of security even with lesser-known low-cost brands, as long as they have the certificate. Thanks to blockchain technology, Matter ensures that software changes are stored decentrally and transparently and can be verified by anyone. Matter products are encrypted and hack-proof.
In addition, connected devices will communicate locally, so you don't have to control your smart home over the Internet. Of course, the manufacturers will continue to offer their cloud services, so that you can access your heating control or your vacuum cleaner robot while you're on the road in the future.
verschiedene farbige Leuchten von Philips Hue
Smart bulbs are one of the first product categories supported. / © nextpit
What kind of devices does Matter support?
Officially launched in October 2022 after multiple delays, Matter introduced a range of product categories or classes. However, not all categories were supported from the start, some devices were available at launch, while others were scheduled for future integration.
The first major expansion came one year later with Matter 1.2, which added several new device classes. In May 2024, Matter 1.3 introduced five additional appliance categories, improved energy management features, and support for electric vehicle chargers and water management systems.
Later that year, Matter 1.4 expanded support to include solar panels and batteries, while also enhancing multi-admin capabilities and energy automation. Smaller updates followed in early and mid-2025 with Matter 1.4.1 and Matter 1.4.2, both focused on streamlining setup and boosting performance.
  Matter 1.0 Matter 1.2 Matter 1.3 Matter 1.4
Bridges
Door locks
Electrical
HVAC controls
Lighting
Media devices
Safety and security sensors
Windows shades
Air purifiers
Air quality sensors
Dishwashers
Fans
Refrigerators
Robotic vacuum cleaners
Room air conditioners
Smoke and carbon monoxide alarms
Washing machines
Laundry dryers
Microwave ovens
Ovens
Cooktops
Extractor hoods
Electric car chargers
Water leak, rain, and freeze sensors
Water valves
Water heaters
Heat pumps
Batteries
Solar panels
So Matter covers a lot of smart home technology right out of the gate. But you'll have noticed that many product categories aren't mentioned there yet either, so many categories like video doorbells, weather stations, and others will only be integrated into Matter over time.
Security cameras, energy products like EV home chargers, and "white goods" like refrigerators were also absent from the initial rollout, but the latter two were added in newer revisions.
However, upcoming Matter 1.5, which is expected to be announced at the end of 2025 could finally bring support to security cameras, speakers, and garden irrigation systems.
Matter Ecosystems: apps and bridges
Soon after the 1.0 standard became official, a number of companies announced their compatible devices, and just as important, smartphone apps to control them. The release also kickstarted the initial release of system updates to old products, but don't take firmware updates for granted, as we can expect companies to try to push new sales.
Company Bridges / Hubs Phone app
Amazon
  • Amazon Echo (2nd gen)
  • Amazon Echo (3rd gen)
  • Amazon Echo (4th gen) ^
  • Amazon Echo Plus (2nd gen)
  • Amazon Echo Dot (2nd gen)
  • Amazon Echo Dot (3rd gen)
  • Amazon Echo Dot (4th gen)
  • Amazon Echo Dot (5th gen)
  • Amazon Echo Flex
  • Amazon Echo Hub
  • Amazon Echo Input
  • Amazon Echo Studio
  • Amazon Echo Show 5
  • Amazon Echo Show 5 (2nd gen)
  • Amazon Echo Show 5 (3rd gen)
  • Amazon Echo Show 8 ^
  • Amazon Echo Show 8 (2nd gen)
  • Amazon Echo Show 8 (3rd gen)
  • Amazon Echo Show 10 (3rd gen)
  • Amazon Echo Show 15
  • Amazon eero Pro 6, 6 Plus, 6 Pro, 6E, PoE 6 ^
  • Amazon eero Max 7 ^
Apple
  • Apple HomePod mini ^
  • Apple HomePod (2nd gen) ^
  • Apple TV 4K (2021) ^
  • Apple TV 4K (2022)
  • Apple TV 4K Wi-Fi + Ethernet (2022) ^
  • Apple Home (iOS)
Aqara
  • Aqara Camera Hub G2H Pro *
  • Aqara Camera Hub G3
  • Aqara Hub E1
  • Aqara Hub M1S *
  • Aqara Hub M1S Gen 2
  • Aqara Hub M2
  • Aqara Hub M3 ^
Google
  • Google Home
  • Google Home mini
  • Google Nest Audio
  • Google Nest Hub
  • Google Nest Hub (2nd gen) ^
  • Google Next Hub Max ^
  • Google Nest Mini
  • Google Nest WiFi Pro ^
  • Google Nest WiFi Router ^
  • Google TV Streamer 4K
Ikea
  • Ikea Dirigera *^
LG
  • LG 2023 smart TVs via ThinQ
Samsung
  • 2022 & 2023 Smart TVs *
  • 2022 Family Hub fridges *
  • Aeotec Smart Home hub ^
  • Samsung SmartThings Hub (2nd gen)
  • Samsung SmartThings Hub (3rd gen) ^
  • Samsung SmartThings Station ^
  • Samsung Soundbar HW-Q990C ^
Signify
  • Philips Hue Bridge
  • Philips Hue Brid Pro (2025)
Other
  • AVM FritzBox
  • Bosch Smart Home Controller II
  • Brilliant smart home panel
  • Eria AduroSmart Zigbee Hub
  • Homey Pro Hub ^
  • Hoobs Pro
  • Hubitat Elevation Model C-8 ^
  • Mui Board 2.0
  • Nabu Casa Home Assistant Yellow ^
  • Schneider Electric Wiser Gateway *
  • SwitchBot Hub 2
  • Tp-Link Tapo H900 Homebase
  • Ubisys Gateway G1
  • * = Update pending
  • ^ = Supports Thread
With the interoperability promised by Matter, other companies are expected to release compatible bridges and apps in the future.
Transition hiccups
Although heralded as the "one true standard", we will probably have to live with the existing ecosystems for quite a while, especially for those with their smart home already set. With some devices not slated to be upgraded, companies like Samsung already said that their proprietary standard, including certification, won't go away anytime soon.
Because of that, even after updating the Samsung SmartThings Hub, existing non-Matter devices won't magically be available to apps made by other brands, and will require using the current branded apps. Similar hiccups can be expected from other product families, but at least current devices should continue working as before, for better or worse.
Does Matter support older devices?
Not necessarily. Products need to be certified for the new standard and some of them will require a firmware update. Both Amazon and Google, together with device makers eWeLink, Ledvance, Sengled, TP-Link, Tuya, and Lifx announced that many devices will receive updated firmware to be compatible with Matter. The provisional list includes many EchoNest, and SmartThings devices and of course, Alexa and Assistant.
In some cases, the firmware upgrade will be required for a single device in the home, as the Matter upgrade Signify announced for its Philips Hue Bridge, which will integrate existing lamps into the new ecosystem. Similarly, Samsung announced that some of its smart TVs/monitors and even refrigerators will work as Matter hubs to control compatible devices.
Just like in the Android ecosystem, we expect manufacturers to slowly distribute firmware updates now that the standard has been ratified. Just don't go on a buying spree without checking whether the device supports Matter to avoid any future incompatibilities.
Samsung Smart fridge
I am still skeptical about smart fridges, but Samsung seems to be all-in. / © Samsung
What are your thoughts on Matter and Thread? Do you already own smart home devices supported by the new standard, or are you planning to upgrade soon? Tell us in the comments.
Article updated on August 2025 with the new product categories supported by Matter 1.4.
The best portable power stations by price category
  Sponsored Best power station below $500 Best power station below $1,000 Best power station up to $1,500 Best power station over $1,500
Product Jackery Explorer 2000 Plus
Price (without solar) $2,799 $299 $649 $999 $1,980
Price (with solar) $3,499 from $499 from $1,248 from $1,649 from $2,970
Oukitel P5000
Bluetti EB3A
Ecoflow River 2 Pro
Ecoflow Delta 2
Read the Oukitel P5000 review
Coming soon
Read the Ecoflow River 2 Pro review
Read the Ecoflow Delta 2 review
Coming soon
Check offer* (without solar)
Check offer (with solar)
  Buying Guide: Those are the Best Portable Power Stations with Solar Option
Go to comment (1)
Carsten Drees
Carsten Drees
1 Comment
    storm Sep 24, 2022 Link to comment
    This is why iot things must be upgradeable. Considering the life of a light or power socket, it will probably be in place for decades. You can't maintain infinite backward compatibility because of the security holes. You also can't replace everything in your home every two or three upgrade cycles. They need modularity and flashability and LONGTERM support. Read the support guarantee of the device closely.
    Rubens Eishima
