Huawei P30 Pro camera first impressions: more zoom, more fun
AndroidPIT huawei p30 pro front camera l3tg2
Huawei let the cat out of the bag and finally introduced the P30 Pro. The P-series traditionally focuses on the camera, and Huawei has indeed taken a deep dive into its box of tricks with this one. The Huawei P30 contains a total of five cameras, and as this first camera test shows, they have it all.
The points that Huawei particularly emphasizes in the new smartphone camera are the enormous zoom range and the improved performance in poor light. Even in the dark, the Huawei P30 Pro is supposed to deliver good photos. In order to always have the right settings at hand, the Chinese manufacturer has further extended the Master AI, which uses the dual-NPU in the Kirin 980 processor. Finally, this AI helper can also be switched on and off with a single tap, without having to dig through the menu.
Zoom range of the Huawei P30 Pro
The Huawei P30 Pro has an ultra wide-angle camera on the back, a standard focal length and a horizontally mounted telephoto lens with 5x optical magnification. Thanks to the high resolution 40 MP sensor in the standard camera, Huawei can even make a tenfold hybrid zoom possible, which can actually bring a subject extremely close to you. And the quality and sharpness hardly suffer.
IMG 20190327 141137
The ultra-wide angle lens of the P30 Pro in use. / © NextPit
IMG 20190327 141546
The normal focal length of the Huawei P30 Pro. / © NextPit
IMG 20190327 141549
The P30 Pro creates a fivefold zoom with its tele-optics. / © NextPit
IMG 20190327 141551
The tenfold hybrid zoom of the Huawei P30 Pro in action. / © NextPit
IMG 20190327 141602
With pure digital zoom, even 50x magnification is possible. / © NextPit
This enormous zoom range - even if one disregards the pure digital zoom - makes the camera of the Huawei P30 Pro extremely versatile and ensures that the photographer has a suitable focal length available in almost every situation. In this respect, no other smartphone offers as much as the Huawei P30 Pro (click here for the complete review).
IMG 20190327 144018
This picture was also taken with the tenfold zoom. / © NextPit
The camera of the P30 Pro in a low light test
Huawei has been especially hard at work on the low-light capabilities of the P30 Pro. The sensors are quite large for a smartphone at 1/2.5 inches, and the Chinese manufacturer has replaced the green parts in the Bayer matrix with yellow. They're supposed to let in 40 percent more light. In fact, the P30 Pro takes excellent pictures in low light, even in situations in which almost all smartphone cameras have long since given up, showing only a black display. You don't really need the night mode at all, the automatic mode is completely sufficient.
IMG 20190327 144657
The Huawei P30 Pro likes it atmospheric. / © NextPit
IMG 20190326 233205
A good photo in every situation. / © NextPit
IMG 20190327 000719
Night shots in the city are no problem with the P30 Pro. / © NextPit
IMG 20190327 065850
Little light, but still a good photo with the Huawei P30 Pro in our camera test. / © NextPit
For comparison, here's the picture the Mate 20 Pro took of the same place with identical settings. The difference is striking.
IMG 20190327 070009
Same situation, but hardly anything to recognize by the Mate 20 Pro. / © NextPit
Even if the comparison with other current top smartphones is still pending, The Huawei P30 Pro will be very difficult to beat in low-light shots.
Portraits and close-ups
For modern smartphones, portraits and photos with a good depth of field are part of the package. Huawei has been a pioneer in this field since the P9, and has added an additional TOF camera (Time of Flight) to the P30 Pro. The creation of a depth map of the entire scenery creates a more natural look than before, which is especially useful for portraits. The portrait mode of the camera app in the Huawei P30 Pro can be safely forgotten, as the aperture mode is preferable - it doesn't have any automatic beauty effects that unnecessarily distort the picture.
IMG 20190327 122144
The TOF camera helps the bokeh effect tremendously. / © NextPit
Since the Mate 20 Pro, Huawei has also offered a Super Macro mode in which you can approach the subject with the camera up to 2.5 centimeters. The wide-angle camera is used for this purpose. With the Master-AI activated, the P30 Pro switches on the Super Macro mode reliably and automatically during the test.
IMG 20190327 095743
The Super Macro mode gets up close and personal. / © NextPit
Action shooting with the Huawei P30 Pro
With all the zoom and the chic backgrounds, you shouldn't forget the action photos, because the P30 Pro is also quite good at them. Here the telephoto lens is rarely helpful, but the wide-angle lens can provide exciting effects.
IMG 20190327 110733 2
Spectacular effects can be achieved with the wide angle. / © NextPit
IMG 20190327 121139 3
The Huawei P30 Pro can also catch fast action. / © NextPit
IMG 20190327 111700 3
Backlight? No problem! / © NextPit
IMG 20190327 112657 2
This picture was taken with the tele-camera of the P30 Pro. / © NextPit
If there is a lot of movement in a game, it is recommended to use the manual mode of the Huawei P30 Pro camera and keep the shutter speed low, at about 1/1000 second. The disadvantage: in the Pro-mode, the serial image trigger does not work, thus one has to trigger each image individually. This increases the chance of missing the right snapshot.
The selfie camera of the P30 Pro
The selfies, which the Huawei P30 Pro delivers in this camera test, have a whopping 32 megapixels. The first step should be to switch off the beauty mode, because even without it, the Huawei P30 Pro displays people naturally and nicely with the front camera. In low light, however, the front camera can't quite keep up with the rear camera.
IMG 20190327 143737
The selfie camera has a resolution of 32 megapixels. / © NextPit
There is also room for several people on a selfie with the Huawei P30 Pro, if you can extend your arm long enough:
IMG 20190327 143748
Selfies with four people are possible with the Huawei P30 Pro. / © NextPit
The bottom line
If you'd like to see these and many more photos taken with the Huawei P30 Pro in full size, you can find them at the following link:
  • View test images in full size
Already, after the first day and the first night with the Huawei P30 Pro it becomes clear: this camera has a lot to offer. It offers enormous creative possibilities and delivers excellent photos in every conceivable situation. The big camera comparison with the other luxury smartphones like the Apple iPhone XS or the Samsung Galaxy S10 should be really exciting!
What do you think of the P30 Pro photos? Let us know in the comments below.
Go to comment (3)
3 comments
  • N_ R 2
    N_ R Apr 11, 2019 Link to comment
    I just ordered a P30 Pro in Breathing Crystal :)
  • 27
    Sorin Apr 1, 2019 Link to comment
    The P30 Pro is more like a camera, a very compact "camera" with exceptional picture quality. However, it is called "smartphone". Because that's what it is!
    And let's not forget the price, which is one that can be attractive for a top phone.
    That's why I can say: Bravo Huawei!
  • 25
    Deactivated Account Mar 31, 2019 Link to comment
    Thank you Steffen Sir ?
    Really, it seems cameras on Huawei P30 Pro are both a great toy and a very powerful tool.
    Sorin
