Honor 400 Pro Review: Between a mid-range and flagship
honor 400 pro im test np
© Timo Brauer / Nextpit
A $999.99 price tag for a top-of-the-range smartphone is now the norm. Apple, Samsung, and Xiaomi often charge $1,200 or more for their flagship models. Honor, on the other hand, is sending out a clear signal with the Honor 400 Pro: top performance does not necessarily translate to a high price. With an entry-level price of $999.99, the question arises as to what compromises have been made to achieve this device. We reviewed the smartphone to find out more.
Honor 400 Pro
  • Decent price point
  • High-quality workmanship
  • First-class display
  • Many software personalization options
  • Good update support
  • Camera with many AI functions
  • Pre-installed bloatware
Honor 400 Pro
Honor 400 Pro
Honor 400 Pro: All deals
Honor 400 Pro design and build quality
  Design and build quality
Display
  • 6.7-inch display
  • 1280 x 2800 pixels
  • 120 Hz refresh rate
Dimensions and weight
  • 160 x 76 x 8.1 millimeters
  • 205 grams
Resistance
  • IP68
The Honor 400 Pro comes with a comprehensive range of accessories: A charging cable, pre-installed screen protector, a protective case, and SIM tool were included in the package, although the power adapter was conspicuously missing. In terms of color, the selection remains conservative with black and gray, although a little more courage to use color accents would be desirable. Nevertheless, the review unit in grey impressed us with its elegant and high-quality exterior. The matte back effectively reduced fingerprints, and the matte metal frame with subtly rounded corners was comfortable to hold in one's hand. The device also features the IP68 standard and is therefore protected against dust and water.
Honor 400 Pro display
Just like the back, the display is also slightly curved at all four edges. However, the curvature ends exactly where the actual screen begins. This design ensures a slim feel and a pleasant grip without compromising the image quality.
Featuring a pixel count of 1,224 x 2,700, Honor's display exceeds the classic Full HD resolution. The resolution is a good compromise between high image sharpness without draining the battery unnecessarily. Honor relies on AMOLED technology for the panel with correspondingly vibrant colors, high contrasts, and good viewing angles. The 120 hertz refresh rate ensures a smooth display, but this is now par for the course in this price range.
The extremely high peak brightness of 5,000 nits should never be taken for granted at this price point. However, this is only on paper; in everyday use, there is no difference compared to other flagship models such as the Galaxy S25 Ultra (review) with 2,400 nits. Both devices were easy to read in direct sunlight. One positive aspect in everyday life is the automatic brightness adjustment, which reliably reacted to changing light conditions. Regardless of whether it is dark or under the bright sun, the device adjusts the display brightness so precisely that manual readjustment is hardly necessary.
Honor 400 Pro software
  Software
Operating system
  • Android 15, MagicOS 9
  • 6 years of security updates
  • 6 years of version updates
The Honor 400 Pro comes with Android 15 and the latest security update. The system is complemented by Honor's own MagicOS 9 user interface, which offers a wide range of customization options. In addition to the visual design, numerous settings can be customized here. Additional functions that go beyond what the standard Android offers were also integrated — including the multi-window dock, making it easier to use two apps simultaneously.
As with many other smartphones, there were also a number of pre-installed third-party apps, including Facebook and WPS Office. These so-called bloatware applications are a way for manufacturers to reduce the device cost. However, as most apps can be easily uninstalled, this aspect is of little importance.
Update supply & long-term support
Honor promises to deliver a six-year update guarantee for the 400 Pro, which includes both major Android versions and security updates. Experience from the past year showed the manufacturer delivered its promised updates regularly and quickly. Although the update duration is one year shorter than the more expensive Honor Magic7 Pro, six years should be more than adequate for most users.
Processor & connectivity: Differences between flagships
  Performance
Processor
  • Snapdragon 8 Gen 3
Memory
  • 12 GB LPDDRY RAM
  • 256 / 512 GB memory
  • No memory expansion
Connectivity
  • 5G, eSIM, Wi-Fi 7, Bluetooth 5.4, NFC
The clearest difference compared to more expensive flagships would be the processor. While many top smartphones currently use the Snapdragon 8 Elite SoC, Honor uses the Snapdragon 8 Gen 3, which is one year older, in the 400 Pro. This saves the manufacturer considerable cost, as the current high-end chip costs close to $200 based on unofficial figures.
In reality, however, this hardware difference is negligible. Although the newer chip offers around a third more performance, this has no noticeable effect on everyday applications. Last year's generation was already powerful enough to handle everyday tasks without any lag. There were also no serious limitations when it comes to software support: Honor promises six years of Android and security updates for the 400 Pro — one year less than the manufacturer's significantly more expensive top model, but more than enough for most users.
Diverse wireless interfaces & a fingerprint sensor
The Honor 400 Pro is equipped with modern wireless standards. Wi-Fi 7, Bluetooth 5.4, NFC for contactless payments, and even an infrared port for controlling analog devices are included. The smartphone, therefore, offers a wide range of connectivity options that do not differ significantly from much more expensive flagships.
There is a small difference to the Honor Magic7 Pro in the fingerprint sensor. Instead of an ultrasonic sensor, Honor relies on an optical model, which is slightly slower and does not work reliably with wet fingers, but still delivers solid performance in everyday use. Other manufacturers, including Google, rely on optical sensors even in their premium models, so this minor detail is hardly a disadvantage.
  Galaxy S25 Ultra
(Snapdragon 8 Elite)
Honor 400 Pro
(Snapdragon 8 Gen 3)
AnTuTu 2.207.680 1.889.643
3DMark Wild Life Extreme
Stress test
Best run: 23,195
Stability: 51.1 %
Best run: 16,139
Stability: 73.2 %
Honor 400 Pro camera
With the 400 Pro, Honor relies on a powerful camera configuration combined with a range of AI-supported functions. First, let's take a look at the hardware:
  Camera
Main camera
  • 200 MP, f/1.9, OIS
Ultra wide-angle camera
  • 12 MP, f/2.2
Telephoto camera
  • 50 MP, f/2.4 OIS, 3x zoom
Selfie camera
  • 50 MP, f/2.0
Max. Video resolution
  • 4K
Compared to the Honor Magic7 Pro, the Honor 400 Pro makes do without the variable aperture of the main camera and relies on simpler features for the ultra wide-angle camera. Nevertheless, the device offers solid performance for its price. The test showed the camera delivered sharp images reliably even with fast-moving subjects. The telephoto camera also produced sharp photos. However, the color balance left a little to be desired.
AI support & digital editing
All the AI functions that the Honor 400 Pro offers when taking photos are exciting to check out. One of these is the AI zoom. Users can digitally zoom up to 50x, with AI support being enabled at a certain level. The photo is analyzed and optimized in an AI-supported version based on available data.
Images can also be further processed using AI after they have been taken. The software makes it possible to subsequently remove distracting elements, reduce blurring, change the background, or even touch up missing areas in the image. These functions further expand the creative possibilities when taking photos.
Battery life & charging speed
  Battery capacity
Battery capacity
  • 5,300 mAh
Charging speed (via cable)
  • 100 W
Charging speed (wireless)
  • 50 W
The Honor 400 Pro sports a 5,300 mAh battery in Europe, which is slightly more than the usual 5,000 mAh for this smartphone size. Globally, the smartphone is even available with a 6,000 mAh battery. The higher capacity is made possible by silicon-carbon technology, which, in contrast to conventional lithium-ion batteries, allows a higher energy density with the same battery size. In everyday use, this was reflected in a convincing battery life: in the benchmark test, the device lasted 15 hours and 36 minutes, and even with intensive use, one full charge was easily enough for a long day. As expected, the runtime only decreased noticeably when the AI functions were used excessively, which placed a heavy demand on the processor.
Charging power & power supply issue
The device supports a charging capacity of up to 100 watts, but only with the appropriate Honor power adapter, which is not included in the packaging. In the review, a standard 240-watt PD power supply was used instead, where the smartphone did not achieve the promised charging speed. A full charge took around 85 minutes. According to the manufacturer, the official power supply should bring the battery back to 50 percent from zero within 15 minutes, a significant saving of time that users can only achieve with the official and separately available power adapter.
Prices for high-end smartphones have risen significantly in recent years, and $1,200 to $1,300 is now the norm. With the 400 Pro, Honor is offering a flagship experience at a significantly lower price of $999.99. To achieve this price point, some sacrificed had to be made, such as using last year's flagship processor and using less-than-stellar camera sensors, for instance. However, these measures hardly affected the overall performance. The high-quality workmanship was just as impressive as the MagicOS user interface, which scored points with its numerous customization options and long update support.
Of course, the Honor 400 Pro cannot quite keep up with the best of the best on the market. With its price, the Honor 400 Pro is positioned exactly between the Magic7 Pro for $1,399.00 and the Honor Magic7 Lite for $400, and should therefore be an interesting option for many users who want something that straddles the mid-range and premium segments.
  • $799
  • $799
  • $999
  • $599
  • $999
  • $499
Review: Samsung Galaxy S24
Review: Apple iPhone 15
Review: Nothing Phone (2)
Timo Brauer
Timo Brauer
Timo has always had a fascination with technology. Starting with his own blog at the age of 14, followed by spending some time as a freelancer, he joined the beebuzz media team in 2019. He is a smartphone expert and regularly tests the latest mobile phones and smart home gadgets. He can also be found at countless events and trade fairs. When he is not busy testing new gadgets, he travels around the world. His favorite place to be is anywhere in Europe, and he enjoys the adventure of getting there by train, no matter how long it takes.
