androidpit Nexus 6P speed up
How do I speed up my 3G data?
  7. Reboot the device.
androidpit speed up 3g one
androidpit speed up 3g two
Go to comment (28)
28 comments
  • Joaquin Breslin 1
  • nt196140 2
  • 10
  • Jinka Varalakshmi 1
    its working :)
    • 12
      Corey Dorsey
    Before:
    Upload: 1.86
    Ping: 669
    After:
    Upload: 0.02
    Ping 282
    • 12
      Remove and reboot the phone.
      Corey Dorsey
  • Junaid Q. 17
    will it work on 2G network ?
Show all comments
