What is NFC? Everything you need to know about NFC technology
AndroidPIT best ways to use nfc 5
NFC is a fairly common feature on most mid-range and high-end smartphones of today. It has seen an increase in uptake as the online payment ecosystems proliferate across the globe. However, many of you still have several questions surrounding it. What is NFC? What is an NFC tag? In this article, we attempt to answer most of these queries.
Shortcuts
What is NFC?
NFC is short for Near Field Communication.
Essentially, it's a way for your phone to interact with something in close proximity. It operates within a radius of about 4 cm and provides a wireless connection between your device and another. This allows for two-way communication, with both devices involved being able to send and receive information.
AndroidPIT best ways to use nfc 2
What is NFC? Find out here. / © NextPit
NFC is widely used across the US, and Europe and chances are you have probably been using NFC for years now without even realizing it.
Do you know those three curved lines on your credit or debit card that allow you to make contactless payments just about everywhere these days? Well, that's NFC. The first high street retail chain to introduce NFC was Eat, way back in 2008. Now, the same technology is available on most Android smartphones. This essentially means you can use NFC-based services for many practical, day-to-day applications.
GPay 1
NFC card payments, known as contactless payments, have been available for over a decade. / © Google
How does NFC work?
NFC transmits or receives data via radio waves. It's an established standard of wireless communication.  It differs from Bluetooth in that it functions through electromagnetic induction. This means there can be a passive device, such as a poster or sticker, requiring no power source of its own that can transmit data when an active device, like your smartphone, comes into contact with it.
As an active NFC device, a smartphone can send and receive data over NFC. It encompasses the full range - three modes - of NFC:
  • Reader/writer (e.g. for reading tags in NFC posters).
  • Card emulation (e.g., for making payments).
  • Peer-to-peer (e.g., for file transfers which is no longer used as of 2021).
How to use the NFC feature on your smartphone
If you happen to own a mid-range or high-end smartphone, chances are high it comes with the NFC feature. You will, however, need to make sure you have turned the feature on for it to work seamlessly. Once NFC is turned on, the manner in which you use it will depend on what you intend to do with it.
For example, if you wanted to connect your NFC-enabled smartphone to an NFC-enabled wireless speaker, all you need to do is tap your phone to a specific area on the speaker, and the connection is automatically established. That brings us to the various real-world use cases of NFC.
Let's take a quick look at some of those.
What is NFC used for?
NFC has been around for more than a decade now, and for the same reason, some of the things which it could do aren't relevant anymore.
For example, file transfers used to be a thing with NFC when it was new. In 2021, however, there are faster, simpler ways of peer-to-peer file transfers, and no one really uses NFC for that purpose anymore. Here are some areas where NFC continues to be used in 2021.
Cashless payments
The most common way consumers use NFC is while making tap-to-go payments. Leading payment services, including Google Play, Apple Pay, and Samsung Pay, use NFC for cashless payments in several countries across the globe. In all of these payment services, all the user needs to do is to add their card number(s) to the app.
The next time you want to make a quick payment, all you need to do is to tap the NFC tag, and the payment should be done almost immediately.NFC payments are secure, and most of these services require that you add a PIN to complete a transaction.
Connecting with NFC tags
NFC tags are small physical “tags” or “stickers” containing NFC chips that can be programmed to provide any kind of information to your smartphone. Typically, an NFC tag contains links to a web address, but it can also be set to perform certain actions with your smartphone, like turn on the Wi-Fi or turn down the ringer. Where NFC presents an advantage over current QR technology is that there is no need for a “scanner app”: the information is immediately available.
In theory, these tags could be embedded into just about anything. For example, an NFC tag could be used in a restaurant menu to make the most up-to-date version of it available immediately on your phone. All you would need to do is bring your smartphone into the proximity of the physical menu, and you could potentially browse more detailed information of certain menu items, like nutritional values or ingredients.
For personal use, NFC tags can also be set up to control devices from your phone, for example, scanning a tag with your phone could boot up your PC, or you could have a tag on your bedside table that switches your phone to night mode automatically.
If you'd like to experiment with NFC tags, there's nothing to stop you from buying some NFC stickers and playing with the possibilities.
SmartTags NT3 sony w628
NFC tags can trigger predetermined actions on your smartphone. / © Sony
Connect with devices, wearables, and accessories
The past few years have seen a huge increase in the number of people using accessories that frequently connect to your smartphone for various purposes. For example, you might have a Bluetooth speaker and a smartwatch at home. You might be already aware how annoying it is sometimes to connect these devices to your smartphone using Bluetooth.
This is where NFC can come in handy. In case both the devices (your smartphone and the peripheral) support NFC, the connection can be established in seconds by a single tap. Some smartwatch and fitness ban models also support NFC for quick, hassle-free pairing.
Unlock car doors, and homes
A new use case for NFC, which saw its debut in 2020, lets users unlock car doors using just an NFC-enabled smartphone. The technology was announced by Apple in collaboration with BMW, and it made its debut with the 2021 BMW 5 series.
As you might have guessed, once this is set up and enabled, all you need to do to unlock your car would be to simply tap the door handle (which will have an embedded NFC chip), and the door will be unlocked without the need of a key.
The same principle can be used to unlock the doors of your home using just your smartphone or an NFC-enabled key.
Does my smartphone support NFC?
Most high-end and upper mid-range smartphones come with NFC support. However, several Asian manufacturers like Xiaomi, Oppo, and Huawei have stopped shipping smartphones with NFC capabilities because the market dynamics in countries where these brands are popular have seen an increased preference to QR codes over  NFC.
To find if your phone does support NFC, go to Settings > Connected devices > Connection Preferences (on Stock Android) and see if there's an NFC option hiding in there.
Some older devices have a small NFC logo on their rear panels, but this is very uncommon to see in 2021. You can also type in NFC in the search bar within the settings menu and see if there are entries related to NFC on your phone.
androidpit sony xperia Z3 9
Older smartphones used to proudly tout their NFC capabilities. This is not the case anymore / © NextPit
Is NFC safe, are there any disadvantages?
NFC communication happens over the air, and there is no real protection against eavesdropping and what is often referred to as man-in-the-middle attacks. However, due to the very close proximity required for NFC to work, these vulnerabilities are not such a big issue.
After all, a thief would have to be within centimeters of your device to skim your data via NFC. If you are using services like Google Pay, and Apple Pay, you can rest assured that your credit card number is never transmitted. Instead, an individual digital account number is used to identify your payment details.
There you have it. NFC provides the quickest way to set up connections between electronic devices. It is great for when you’re out of credit and need to make quick payments. It’s quick, easy, and bumping two phones together is fun (maybe not so much during a pandemic!)
But there are several drawbacks as well. We have listed a few below:
  • Not all smartphones support NFC.
  • NFC has not found widespread usage in Asian markets where QR codes are still popular.
  • NFC chips are not all located in the same place, resulting in some exploratory rubbing between devices.
  • NFC is too slow for peer to peer file transfers, and newer, faster methods are now available.
Do you use NFC on your smartphone? What uses have you found for it? Let us know!
This article was last updated in May 2021. Older comments have been retained.
Go to comment (31)
31 comments
  • RFID and NFC inventor 1
    RFID and NFC inventor Jun 11, 2021 Link to comment
    NFC is a subset within the HF band of RFID. Within the next few years, NFC will be on every physical thing. A simple tap of your NFC-enabled device (smartphone, watch, etc.) will confirm whether or not the product is counterfeit (product provenance) and provide information about that individual item's production history. It will also allow for instant payments/checkout, establish a paid or unpaid non-invasive relationship with your brand and retailer, and many other features.
    RowanRosh Dec 21, 2020 Link to comment
    We should encourage NFC app for more secure
    storm Dec 9, 2020 Link to comment
    Pretty sure Android Beam is dead now. You should update that section.
    I wish NFC was implemented much more widely than in premium phones and was given more attention. It's an intensely powerful tool, particularly with Tasker, IFTT and tags.
    Rome Oct 14, 2020 Link to comment
    Does the person who is scanning. Have to have the Facebook Messenger app on their cellphones?
    cymnwink May 2, 2020 Link to comment
    use my NFC to load my Beep card (Samsung a7 2017)
  • nathan chisholm 6
    nathan chisholm Sep 25, 2018 Link to comment
    I have it but I'm not that stupid to active it! You have a card in your wallet how hard is it to pull it out
    • 28
      itprolonden Sep 25, 2018 Link to comment
      Clearly you don't understand how it operates.
      Deactivated AccountSorin
    YossiD Jul 9, 2018 Link to comment
    A phone that interests me has pretty much all the features I want except NFC. I have seen mention of adding NFC functionality via a specialty microSD card in a spare SIM slot or using some kind of sticker. Can anyone comment on this? I am mostly interested in NFC for reading tags and public transportation cards.
  • jugi 10
    jugi May 20, 2018 Link to comment
    my both devices have nfc but still it doesn't work?? for me it's completely useless
  • Kathy Goodson 1
    Kathy Goodson Apr 8, 2018 Link to comment
    I turned on my NFC so I could just say ok Google when my phone is off...but I forgot to turn it off and I was not able to get any incoming calls....will this cause that when it is turned on?
  • Dean Lewis 2
    Dean Lewis Dec 3, 2016 Link to comment
    I thought this was awesome... years ago! Lumia's had NFC and Qi so long ago.
    Just need these technologies to be built into more so people see the point of using them.
    Richard Fernandez
  • Gary Funk 5
    Gary Funk May 8, 2016 Link to comment
    I use NFC to allow access to my security system and unlock doors.
    SorinKaren Liston
    Rishabh Ryber May 3, 2016 Link to comment
    Thanks Buddy, nice information
    Rishabh Kumar
  • Alfred Gilbert 5
    Alfred Gilbert Apr 29, 2016 Link to comment
    We should have more and more apps with NFC.
    Karen Liston
    storm Apr 28, 2016 Link to comment
    Tasker and various NFC task apps make NFC incredibly useful.
    SorinKaren Liston
  • Mark G. 28
    Mark G. Apr 28, 2016 Link to comment
    I use my NFC to transfer files between devices & to make payments via the EE cash on tap service which is relatively secure.
    *edit #
    I now have Android Pay set up to my bank account, the process of using tokens instead of my actual card details makes it again relatively safe. Obviously if my phone is stolen the thief can spend my money in £30 stages, but I would treat losing my phone in similar way as if I lost my bank card. I would immediately contact my bank and stop transactions. I would also send a factory reset to my device.
    The process of using NFC to make payments is extremely easy and straightforward to use, I've yet to encounter any difficulties using it at various different pay points
    Peace ?
    Peace ✌
    SorinKaren Liston
  • Junaid Q. 17
    Junaid Q. Apr 28, 2016 Link to comment
    NFC good for file transfer but never used for payment
    I doubt its security
    VincejugiSorin
    • 28
      itprolonden May 3, 2016 Link to comment
      It's actually more secure than using a reader.
      SorinMark G.
  • 12
    lianne john Apr 28, 2016 Link to comment
    iNTERESTING!
  • 18
    Deactivated Account Apr 28, 2016 Link to comment
    NFC comes in phone pre-installed or is it possible to get this service with the help of an app.
    • 24
      sadly there isnt an app to get NFC - your phone has to have it built in. If youre not sure if your phone has NFC check out the section in the article which explains how to see the settings or you can always try out an app like this https://play.google.com/store/apps/details?id=com.rexxars.nfcenabled
      • 28
        Yeah, I had an LG G Stylo I really liked but got rid of it for this reason alone, no NFC.
  • Evan 3
    Evan Apr 28, 2016 Link to comment
    I use it sometimes to transfer pics from my cam to my phone.
    CJ Brown
    Deactivated Account Apr 5, 2016 Link to comment
    Yes useful
      Yeah
      Rishabh Kumar
    Andi Oct 30, 2014 Link to comment
    graeat tech. unfortunately in a developing country this kind of thing are still considered to be too risky. especially for paying stuff.
    • Scott Adam Gordon 31
      Scott Adam Gordon Oct 31, 2014 Link to comment
      Ahh interesting. Yeah I think it's still yet to really catch on even in the West but I think it will before long. Especially not that Apple is started to make use of it
      Sorin
    seg@m!n Oct 30, 2014 Link to comment
    I'm using NFC in my car for make a call and turn on Bluetooth. For that doesn't need to search in menu, just bring phone to NFC tags. It's very useful.
    CJ BrownGrimJimCrowleyScott Adam GordonMoni Mihailov
      Scott Adam Gordon Oct 30, 2014 Link to comment
      Awesome idea thank you!
      Dotty H.
      That's cool and useful...
      Rishabh Kumar
