- Forum posts: 297
Feb 6, 2018, 7:33:51 PM via Website
Feb 6, 2018 7:33:51 PM via Website
Hello,
I create that thread to present you Battery Saver 5X a tool letting your to optimize your battery life and fast your battery charging. Battery Saver 5X is available on the Google Play Store in two versions :
- Free supported by Ads : https://play.google.com/store/apps/details?id=com.ssaurel.batterysaver
- Paid to enjoy and Ad-Free experience : https://play.google.com/store/apps/details?id=com.ssaurel.batterysaver.pro
You can discover Battery Saver 5X in action on YouTube :
Battery Saver 5X is the ideal tool to boost your battery life and fasts your charging time.
All you need to do is to launch Battery Saver 5X and the application will le you how to optimize your battery usage to save it thanks to its diagnostic's tool. To save your battery life, Battery Saver 5X will propose you a lot of optimizations like :
- Turn off your Mobile Data
- Turn off your WiFi connection
- Turn off the GPS Location Services
- Enable Airplane mode
- Disable Bluetooth
- Set the silent profile on your smartphone or tablet
- Reduce your screen's brightness
With these precious tips, you will have just to choose the best solution to save your battery life according to your needs. Besides, Battery Saver 5X offers an unique fast charging feature letting you to fast your charging time by reducing all the features consuming your battery.
Don't hesitate to give your feedback or ideas to improve Battery Saver 5X.
Thanks.
Sylvain
