How to enter into recovery mode on Redmi Note 4?
  • Answered
Max Field
  • Forum posts: 32
Jul 2, 2018, 8:25:43 PM via Website
I don't know what happen to my Redmi note 4 it has got stuck at black screen. I have searched the Google that I can fix it by entering into Recovery Mode by myself and perform hard factory reset, but i do not have the complete information how to do that.
Please let me know how to enter into recovery mode on Redmi Note 4 and hard factory reset it?
— modified on Jul 2, 2018, 8:26:05 PM
Best answer
James Watson
  • Forum posts: 1,600
Jul 3, 2018, 3:46:11 AM via Website
Recovery Mode -
1.Turn off the device
2.Press and hold Volume Up key + Power key about 10 seconds
3.Release only Power key when Mi logo appears
4.Keep pressing Volume Up key until Recovery mode appears
Hard factory reset -
1.In Recovery Mode, Select English using Volume keys and press Power key to confirm
2.Use Volume Down key to select Wipe & Reset and Press Power key to confirm
3.Use volume down key to select Wipe all data and Press Power key to confirm
4.Use volume down key to select Yes and press Power key to confirm
Helpful?
Max Field
Max Field
  • Forum posts: 32
Jul 4, 2018, 5:11:01 PM via Website
Thanks.
Problem Solved.
Helpful?
santossimon
  • Forum posts: 12
Jul 7, 2018, 8:22:25 AM via Website
Hey, Thanks!!
Helpful?
santossimon
  • Forum posts: 12
Jul 11, 2018, 6:37:14 AM via Website
It's really helpful. Thanks!!
Helpful?
