- Forum posts: 32
Sep 10, 2018, 9:48:43 AM via Website
Sep 10, 2018 9:48:43 AM via Website
LG Flash tool is designed to help all the LG devices and there won't be any issues while you're trying to flash an LG device with the tool. Sometimes this model error may due to the tool or not compatible with your device, therefore, you can download this tool from the official site by referring all the compatibilities. This tool will ultimately support in flashing your device perfectly and the latest edition is the perfect edition for all the LG Android smartphones and tablets. In some instance the mobile won't execute the programme because of its environment, therefore, you need to download c++ runtime library.
Direct download link:
www.lgflash.com
More download links:
Github Repository
Mediafire.com
Pre Requirement
Prepare a workable Windows computer (Windows 8.1 is under constructions, therefore, use other versions)
Visual c++ you will be needing this to run the program properly. Sometimes the older version will collapse the program, therefore, it is better to download the latest edition from Microsoft official site
Make sure you have installed all the latest LG USB drivers on your PC
Finally, to download your best ever choice LG flash tool click this link
Simple step guide
- Download the compatible version
- LG USB Drivers from the LG Official site.
- Make a network between Windows Computer and the LG handset
- Now copy the downloaded file into KDZ file
- Then disconnect the device from PC and boot into download mode
- Then Run LG G4 Flash Tool
- There is two option like Normal and CSE flashing methods (Normal
Flash - won't delete any data and CSE - Format the entire system
It's suitable for upgrading or downgrading ROM) Then answer all the
questions and fill the relevant spaces - Finally, click OK and you will be able to see a progress bar wait
until it displays 100%
Warning: Do not skip any steps because a single wrong move can brick your beloved device permanently. Make sure you have prepared all the requirements above before you step into the process.
Hope this guide will help you to flash the utility in perfectly. If you have any problem regarding the process feel free to comment or troubleshoot with the help forums.
XDA Developer Forums
Git hub Help
LG Flash Tool Official Host Help Centre
