battery message
shrikant satle
Sep 26, 2018, 4:42:49 PM via Website
WhatsApp_Image_2018 09 25_at_7 08 23_PM
how to remove this message
Sorin
  • Forum posts: 104
Sep 26, 2018, 5:32:01 PM via Website
The message appears to be an advertisement to install another app that contains another ad, and so on. Under no circumstances is it a virus, just to make you install an unwanted application. I guess you used a battery monitoring app, and I recommend you uninstall it. I recommend, however, to check with an installed anti-virus from a safe source.
Helpful?
JosephDrummond
  • Forum posts: 9
Dec 20, 2019, 1:28:26 PM via Website
i dont know
Helpful?
  • Forum posts: 1,011
Dec 21, 2019, 1:30:00 AM via Website
Very useful comment.It is clearly a message from an installed app
Helpful?
Victorious Notorious
  • Forum posts: 16
Aug 27, 2020, 12:06:33 PM via Website
I would reset to factory settings!
Helpful?
