- Forum posts: 35
Jan 24, 2019, 7:31:06 AM via Website
Jan 24, 2019 7:31:06 AM via Website
Xiaomi corporation one of well- recognized Chinese electronics company which is headquartered in Beijing. They produce smartphones, laptops, mobile apps, and consumer electronics. Not only manufacturing but also invest in those products. Currently, Xiaomi corporation is recognized as the world fourth -largest smartphone manufacturer among smartphone manufacturers. Xiami flash tool is the official flashing tool which is developed by Xiaomi corporation to flash Xiaomi devices which are powered by Qualcomm chipsets.
Xiaomi Flash Tool
Xiaomi users can flash stock firmware/Upgrade or Downgrade device firmware using this application. Also, users can flash Stock ROMs directly using Xiaomi flash tool. Xiaomi stock firmware only can be flashed in fastboot mode or EDL Mode. If you have installed a Custom ROM and looking forward to getting back to the original MIUI Xiaomi flash tool is the best option.
What Should You Know Before Using Xiaomi Flash Tool
- Currently, Xiaomi Flash Tool 20180528 is the latest version of the
tool - The tool only supports Xiaomi devices with Qualcomm chipsets
- Uninstall old Xiaomi tool before installing the latest version
- Tool only support devices higher than Mi 3
- This is a Windows-based tool and supports Windows 7/8/10 ( 32 Bit &
64 Bit) - Windows XP does not support
- Needs Unlock Bootloader to flash fast boot files
- The latest Mi flash tool is coming with built-in drivers
How To Flash Xiaomi Fastboot ROM Using Xiaomi Flash Tool
- Visit www.xiaomiflash.com download latest Xiaomi flash tool
- Install Xiaomi flash tool on your Windows computer
- Download MIUI fastboot ROM file for your Xiaomi device
- Extract the downloaded firmware in your computer
- Install Xiaomi USB drivers on your computer
- Boot your device into fastboot mode switching off the device and
pressing Power On button + Volume Down button for few seconds - You will see MIUI bunny when it is in fastboot mode
- Now, connect your smartphone to the computer using a USB cable
- Windows will install all the necessary USB drivers
- Open Xiaomi Mi Flash tool
- Go to"Select" option and locate the fastboot ROM file
- Press the “Refresh” button
- Select one of desired option from "Clean All, Save User Data, Clean
All & Lock" at the right bottom of Window - List item
Clean All - clear all data & Internal storage
Save User Data - Save internal storage data
Clean All & Lock - Clean all the data & also lock your unlocked bootloader
- Press the Flash button to Flash MIUI Fastboot ROM on your Xiaomi
device - You will get "Sucess" message in flash tool windows when the process
is completed
— modified on Jan 24, 2019, 7:33:45 AM
