- Forum posts: 11
Aug 10, 2019, 9:01:03 AM via Website
Aug 10, 2019 9:01:03 AM via Website
i want to root my korian lg phone im unable to root
Aug 14, 2019, 9:07:03 AM via Website
Aug 14, 2019 9:07:03 AM via Website
There are two ways of doing this: using a PC and without one, using just your phone. Since we’ve already talked about the USB Debugging, we’ll start with the first, through a cable connected to your PC. Also, depending on your Android version, you’ll need various tools.
Rooting LG phones with Android 5.0 and higher
For this version, you will need iRoot, free software which is actually very easy to use.
https://www.unlockunit.com/blog/root-lg-phones-complete-guide/
eSparkBiz Technologies
Mar 26, 2020, 9:41:18 PM via Website
Mar 26, 2020 9:41:18 PM via Website
o no plese service iphone
Apr 3, 2023, 8:09:49 AM via Website
Apr 3, 2023 8:09:49 AM via Website
Step 1 Download APK file and install on your LG. Then you need to open it. Step 2 You just need to choose "Get Root access" to begin to root your phone. After your phone is rooted, it will reboot automatically.
Regards,
Rachel Gomez
