WhatsApp Web Problems? Fixes for the Most Common Issues
NextPit Whats App Web login
You just want to write a quick message, but WhatsApp Web no longer works? We have summarized solutions for the most common problems associated with WhatsApp Web below. It doesn't matter whether you use the web-based app on a browser or a tablet, as these solutions work on both platforms.
Did you know you can use the extremely popular instant messenger, WhatsApp, in a browser? To do so, you head to WhatsApp Web, which connects your notebook or tablet (Best Of list) to your smartphone via the internet. In theory, this works very well, but in reality, there are times when WhatsApp Web simply refuses to work.
Table of Contents:
  1. Requirements
  2. Setting up WhatsApp Web
  3. No QR code is displayed
  4. Scanning the QR code does not work
  5. Receiving and sending messages do not work
  6. Notifications do not show up
  7. Deactivate notifications from WhatsApp Web
  8. Sending pictures, videos, and more
  9. Downloading images and data to your PC
This article deals with the above problems. Of course, we'll begin with the basic setup of WhatsApp Web so you can see if you've done everything right.
Requirements: What do I need for WhatsApp Web?
  • First of all, you need a compatible browser. These include Google Chrome, Microsoft Edge, Firefox, Opera, and Safari.
  • Alternatively, you can also download the Windows or Mac app for WhatsApp Web.
  • Both your smartphone and computer must be connected to the internet. A WLAN connection is recommended for smartphones.
  • If you want to use WhatsApp Web on your tablet, you can do that too! You can find detailed information for iPadOS and Android in the linked instructions.
How to set up WhatsApp Web
To use WhatsApp Web, you need to synchronize your smartphone and your computer by performing the following:
  1. Go to the website web.whatsapp.com in the Chrome browser.
  2. Launch WhatsApp on your smartphone.
  3. Open the menu via the three dots (Android) or go to Settings (iPhone).
  4. Click on the QR code next to your profile picture.
  5. Use your smartphone to scan the QR code that is displayed on the website.
The QR code can be found beside your profile picture.
You will find the QR code next to your profile picture. / © nextpit
To use WhatsApp in another browser or on another device, go to the WhatsApp Web menu again and tap on the plus symbol in the top-right corner. If you want to log out again, tap on the corresponding device in the WhatsApp Web menu and select Log out.
No QR code is displayed in WhatsApp Web
The first hurdle when setting up oftentimes happens when scanning the QR code. This is only valid for a certain period before it times out and therefore, no QR code might be displayed when you launch WhatsApp Web. If you encounter this problem, you can generate a new code with a single mouse click.
You will have to refresh the QR code after some time.
You will have to refresh the QR code after a while. / © WhatsApp / nextpit
If you do not see the required button, simply reload the page if you are on a browser. You should then be able to see a new QR code. If it still doesn't work, try the entire process in incognito mode. This is because an ad blocker or other extension for your browser may be blocking the QR code.
Another mistake is, of course, scanning the QR code using your smartphone. First, make sure that the entire code is visible in your smartphone's viewfinder. If you don't see a preview image in the WhatsApp app, you should check the permission settings for your camera.
Do you see the QR code, but it is simply not being read? If so, tap the screen once to engage the autofocus. It may also help to enlarge the QR code using your browser's zoom function. To complete this, hold down the “Ctrl” key and press the plus button simultaneously. Alternatively, you can also scroll up with the mouse's scroll button while holding down the “Ctrl” key.
Receiving and sending messages/pictures/videos does not work
Unlike many WhatsApp alternatives, Facebook's web solution is only a remote version of the actual app. Messages you enter on the PC are sent to your smartphone followed by Facebook's servers. This has a clear disadvantage since your smartphone must have a permanent connection to the Internet and, of course, remain switched on.
WhatsApp outage?
Maybe the problem is not on your end! To find out, you should google the term “WhatsApp outage” and see what sites like Downdetector have to say about the matter. These services constantly check the availability of servers and display disruptions fairly fast.
Alternatively, you can simply write a quick message on your smartphone and send it to someone. If only a single gray tick appears, the connection is currently down. It is best to try again later.
Check the connection on your smartphone
First, check whether your smartphone is connected to the Internet. From there, you should check whether a pending update could be preventing the connection. If necessary, update WhatsApp and turn the internet connection completely off and on again if there are further issues.
Check the connection on your computer
Of course, your notebook, tablet, or PC must also be connected to the internet. The easiest way to find out quickly is to reload the page. To do this, press the “F5” key or press “Ctrl + R” or “Cmd + R” on macOS. If WhatsApp Web cannot be refreshed, chances are your connection is disrupted.
If WhatsApp Web is refreshed, you can also reconnect to the web app once. To do this, you can log out using the three dots at the top right of the screen and log in again.
Desktop notifications in WhatsApp Web do not work
You can be notified on your computer via WhatsApp Web when WhatsApp messages arrive. This also works when WhatsApp Web is running in the background. To do this, proceed as follows:
  1. Tap Notify me of new messages when you use WhatsApp Web for the first time.
  2. Confirm the question from the browser regarding desktop notifications.
Close the tab with WhatsApp Web, or the entire browser if you wish. The notification service will now continue to run in the background.
It does not matter whether the browser is minimized, desktop notifications will still show up.
Desktop notifications always appear in the foreground, even if the browser is currently minimized or even closed. / © nextpit
Disable notifications from WhatsApp Web
If you want to change the notifications settings, open the WhatsApp Web menu (three dots) and select Settings followed by Notifications. You can decide whether incoming messages…
  • … should play a notification sound;
  • … will synchronize content in the background; or
  • … will not show up by deactivating desktop notifications.
You can also mute all notifications for an hour, a day, or a week.
Send pictures, videos, and more with WhatsApp Web
You can send files from your computer with WhatsApp Web. The limit is 16 MB for photos and 100 MB for other file types. This operation is based on the client for smartphones:
  1. Select the paperclip icon in the top-right corner.
  2. Determine whether you want to send a photo, video, webcam image, document, or contact.
  3. Pick the appropriate file.
  4. Add a caption if you wish, and tap the arrow to send.
Alternatively, you can simply drag and drop the files (also in groups) from your file manager (Explorer/Finder) into the window and onto the person in the contact list to whom you want to send to.
Downloading pictures and more from WhatsApp Web to your PC
Downloading images, videos and other files to your PC is also effortless. To download a single image or video, move the mouse pointer over the image and open the menu via the small arrow that appears in the top-right corner. From there, simply tap Download. Alternatively, click on the image to enlarge it and then select the download symbol in the top-right corner.
If you want to download several pictures from a chat to your computer via WhatsApp Web, select (Contact / Group) Info in the three-dot menu at the top right and then Media, Links, and Documents. Select the first image, hold Shift down and select the last image or video. If you then tap the download arrow at the top right, all media in between will be downloaded to the directory of your choice.
Do you still have questions about WhatsApp Web or WhatsApp in general? If so, take a look at our forum, where various problems and solutions to WhatsApp and other instant messengers are discussed.
This article was updated in August 2024, and we kept the comments from before.
Review: Google Pixel 6a
Review: Samsung Galaxy A53
Price (MSRP)
  • $449.00
  • $429.00
  • $299.00
  • $399.00
Go to comment (333)
Antoine Engels
Antoine Engels
333 comments
    M Motahar Hossain Jun 23, 2023 Link to comment
    I updated whatsapp. Now I can't open a chat, reply to a chat or create a new chat. I can receive messages only.
  • Asya Karapetyan 2
    Asya Karapetyan Apr 11, 2023 Link to comment
    When I had problems with whatsapp, reinstalling the app and updating the system helped me to resolve the issue
    kuldeep thosare Apr 3, 2023 Link to comment
    My whatsapp acount banned please unban mu acount
    Ken Kaneki Nov 12, 2022 Link to comment
    I did also face the same problem with downloading fmwhatsapp from gbwamod.com
  • Camila Rinaldi 67
    Camila Rinaldi
    • Staff
    Oct 25, 2022 Link to comment
    This article has been updated with information about the WhatsApp crash on October 25. Share here in the comments what problems you are experiencing.
  • sophial loecarla 2
    sophial loecarla Oct 8, 2022 Link to comment
    Hello how do I hack it to my husband's WhatsApp I no his cheating on me with his ex-girlfriend
    Kely Walker
    • Kely Walker 1
      Kely Walker Oct 9, 2022 Link to comment
      You can reach out @dionysius_helios on Instagram he's the best handling all kind of cracking/recovering & hacked accounts rest assured of a good results,I have tried him and that's why I am recommending him today
    Hello
    Im so lucky to have a kind hearted professional like @dionysius_helios on Instagram you who cares for us so much.thank you for your service in recovery my disabled WhatsApp account
    to be honest, I don't know how he manage to do such a great job every single time.will done The time and efforts he had put into this work that is beyond excellence. Take my cordial thanks! You are really an efficient, organized and result-oriented team
    Thank you for all the extra hours and extra effort you had to put on for getting this job done. I appreciate every bit of your effort. Thank you for pulling this off so smoothly.
    Joe D Sep 19, 2022 Link to comment
    Hi
    This problem is new on my phone.
    Here are the symptoms:
    When trying to add new contact from my whatsapp, the control moves to my texting app???
    I reinstalled Whatsapp and this problem was gone.
    On my contact app all references to whatsapp are gone. All contacts show phone, text, email references, but no whatsapp
    My whatsapp communications with previous people who were in my whatsapp circle work just fine .
    But I can't add new people to my whatsapp contacts.
    My phone: samsung galaxy a50
    I talked to Samsung tech support, 800-726-7864, after long investigation, using S,art Tutor, they came up with suggestion that this is a bug in Samsung latest Android release.
    I doubt it.
    BTW I found that Samsung tech support is pretty good.
    Can anybody help?
    Thanks Joe
    Mary Sep 7, 2022 Link to comment
    Funny I can message on what’s app no prob but when I try phone or video, notice tells me I phone already in use.
    Fiezta Aug 18, 2022 Link to comment
    Hello,
    Please any advice, assistance and help will greatly appreciated.
    I recently noticed that my whatsapp video calls and pictures are no longer full the screen. Please how can I reset my device so taking videos and pictures through whasapp will full my screen. The whasapp itself is full screen because I adjusted it to full screen under custom app aspect ratio. I just want to be able to take videos and pictures through whasapp but want it to full my screen instead of the two black screen on each sides.
    Thank you
    My phone is Samsung galaxy Fold 3.
    Please I'm new here, just in case I post this on the wrong platform, admin can kindly help forward it to the right platform?
    Jessica Carl Jul 18, 2022 Link to comment
    Have you tried external support out yet. When my account got haacked Dionysus helios on Instagram was some cyber specialist that was able to get me my account back. I suggest you look him up bet he gets your account recovered back to normal
    sophial loecarlaoffical_AllenTremblay White
      Tremblay White Jul 18, 2022 Link to comment
      Can someone plz tell me what happened to my WhatsApp? I downloaded the business WhatsApp and then my personal WhatsApp got deleted and I actually got freaked out and I deleted the business WhatsApp and tried to log in to my personal but there was no data whatsoever. Even when I changed my phone I never lost my account but does anyone know how I can get my data back?.. thanks for your recommendation
      offical_Allen
    • offical_Allen 1
      offical_Allen Jul 18, 2022 Link to comment
      Scrolling Through the Comments filled with bots and I was lucky to come across Dionysius helioshe helped me retreiving my account without any delay he's a life saver
  • Christine Hawksworth 1
    Christine Hawksworth Jun 16, 2022 Link to comment
    when i try to update whatsapp on my mobile I get a page that has 2 windows set at an angle and a filing cabinet in between and it says try again and when i do it won't budge i keep pressing the try again button and nothing. Please help. 0::))
  • jamshid kiani 2
    jamshid kiani Jun 1, 2022 Link to comment
    Why it is not possible to line break in the new version of WhatsApp?
    Tremblay White
  • Sujith C 1
    Sujith C May 26, 2022 Link to comment
    I have uninstalled whatsapp business and changed to normal whatsapp and now images already downloaded isn't showing in my file manager (filename showing with 0 size) kindly help
  • Beth Hall 1
    Beth Hall Apr 21, 2022 Link to comment
    When I download Whatsapp to my Kindle, it
    asks to register my phone which drops it from my phone. I want to link phone and Kindle but can't find QR code the directions reference. Whatsapp support won't help.
    • Rubens Eishima 30
      Rubens Eishima
      • Staff
      Apr 22, 2022 Link to comment
      At the moment it is not possible to have two "full fledged" WhatsApp installations in different devices, unless the second device is a PC (or Facebook portal).
      There are a couple of alternatives to use it on a tablet though, but they are merely workarounds:
      https://www.nextpit.com/get-whatsapp-on-your-tablet#web
    Hawkins Bradshaw Mar 27, 2022 Link to comment
    Please I can’t use my WhatsApp since cuz it’s just hanging since for like 24hours now help me out
    Opanka Dec 9, 2021 Link to comment
    I’ve also reached them on their help center line yet no response.
    Zois Bekios Zannikos
    • Camila Rinaldi 67
      Camila Rinaldi
      • Staff
      Dec 10, 2021 Link to comment
      Yeah, Opanka, this is the way t go. The thing is that if you changed devices too many times in a short period of time, WhatsApp does it too. Is this your case?
    I can’t remember violating any rules in WhatsApp yet my contact has been banned and I’m not able to use it on WhatsApp anymore. How do I go about this?
    Kort Oct 3, 2021 Link to comment
    How it's possible a contact of mine while we are talking until late it seems that it was connected hours ago and does not even appear online when we talk?
    Elaine De Clercq Sep 21, 2021 Link to comment
    I have whatsapp business my catalog stopped working and I can't add at all. I select catalog option and then gets a error on screen stating "Item can't be displayed please try again later" and it's got like a glitch like if it's scrolling but no content visible and it's glitching with speed.
    I have actually trying to view the catalog from my personal number and I can see last items that was added but that was a few months back so for 7 months I can't view, edit or add anything to my catalog. It's quite irritating and I needed to turn back to the old fashion way of posting everything on my group. My clients was very impressed and happy with the idea of a catalog that's available to view at anytime from any phone and that even if you are not on the actual group you can still have access to the catalog and what's available. Now it's back to posting literally 100's of updates every few seconds. Clients are leaving my group due to the irritating notifications that they get seconds apart from each other. New clients can't see what's their to offer and must now join to stay updated. The comfort behind the catalog was amazing because I work until late to prepare marketing posts and then I normally load them on the catalog and tomorrow morning when clients open whatsapp they get a updated store every day. And adding to inventory was also awesome.
    Now I am loosing clients loosing income and I can't spend quality time with having actually a client relations refer to interactions with my old clients, new clients or regular clients. Please I really need help because soon I am going to burn out I have a whole shop with daily updates daily sales daily charges.
      Arun Arora Sep 29, 2021 Link to comment
      I can't get verification code
    Jaiganesh Aug 20, 2021 Link to comment
    Whatsapp group are not show. But I opened whatsapp business app it will show here (group only) how I can clear this issues... Any ideal or solution please
    Betty jay Aug 12, 2021 Link to comment
    I can't get my verification code and the more I request for a call or retext it only add more waiting duration to it
    Vishnu das 123 Jul 22, 2021 Link to comment
    Using clone app and sometimes I see mishappening chats.. Like some sentence written over chats and even i can't take pics from that whats app and can't send images and can't change dp.. Can anyone tell me ??
      Shankar 112 Jul 22, 2021 Link to comment
      Yes dear
      It's happening with many people this is due to network issues or software bug as clone app does not get full access..
      Solution to this is you can deactivate the account and reinstall the app and then use it again or you can clear cache that might also help you..
      Yes dear
      This is the Only possible way.
    ttucjacks123 Jul 22, 2021 Link to comment
    My iPhone's WhatsApp once kept crashing. I tried all regular ways such closing, reinstalling, and updating. But finally it was TunesKit that resolved the issue.
    Petatron88 Jul 7, 2021 Link to comment
    I’ve gone from an IPhone XR to a 12 mini. I used to be able to download images sent to me whilst on a WhatsApp audio call but since I’ve changed phones I’m not able to. I’ve tried updating the app, restarting my phone, deleting WhatsApp and reinstalling it (losing a days worth of chat history which has annoyed me no end) and I’ve reset my network data. The option to save to camera roll is on, mobile data and WiFi data is on and WhatsApp has all the permissions under the sun. WHAT IS WRONG WITH THIS? Why can I not see pictures whilst on a call??? It’s bugging the hell out of me.
    • anjali sharma 1
      anjali sharma Jul 14, 2021 Link to comment
      legit have the same problem.. was ur problem solved?
    • Mariyam Rabecca 1
      Mariyam Rabecca Jul 16, 2021 Link to comment
      Hey, I was stuck on the phone with some problems. It was really helpful thanks for sharing...
  • Anesu Johane Kadzirange 1
    Anesu Johane Kadzirange May 22, 2021 Link to comment
    I hava a problem with 2 of my whatsapp contacts.Their profiles just disappear and when i try send messages they only get 1 tick.At times it lasts for a whole day or a few hours.When this happens the same contacta also complain that they are unable to see my profile and all their messages only make 1 tick.What could be the problem? please help.
    Cirillo1234 May 14, 2021 Link to comment
    I continue to see messages from a blocked contact.
    Darren Soewargo Apr 28, 2021 Link to comment
    I am connected to my internet, but WhatsApp just won't connect, why is that?
    John Chapman Feb 28, 2021 Link to comment
    Hello, Photos sent to my Wattsapp will not fully open, when I click on the photo a message displayed reads, This download was unable to complete, please try again.
    I do, but to no effect. Any suggestions, Thank you.
    dollysmiles72 Dec 30, 2020 Link to comment
    Hello. I need help. My old phone got broken and I wasn't able to log out on WhatsApp. I took my sim and moved it to another phone and redownloaded the app again. I had it before but I uninstalled it. After I downloaded the app, I can't log in anymore. It just said WhatsApp service is operating normally. I don't get the verification code either. Can't log in on my Mac because it's asking for a QR. What to do now?
    Jwj Dec 4, 2020 Link to comment
    I have a android phone and what apps works fine but if the phone goes into standby mode and someone tried to phone me on whats app the phone does not notify me a call is coming in the caller just hears it riinging. But if a caller calls me direct not via whats app the calls come through. any ideas??
    TokDalang Macho Nov 1, 2020 Link to comment
    I have blocked 1 number from my WhatsApp, the problem is when the number I blocked suddenly is in my outgoing call list.
    is that a system problem?
    julia Aug 12, 2020 Link to comment
    Reinstalled Whats App on my phone but most recent messages are 3 months ago, why
    Wallis Jul 9, 2020 Link to comment
    When I click on the + to add a photo to a message the screen that appears is covered in black icons and is unreadable
    rocky23 Jun 24, 2020 Link to comment
    Thank you for sharing your thoughts. I really appreciate your efforts and I will be waiting for your next write. thank you once again<br />
    Hannalie Barnard Jun 23, 2020 Link to comment
    I keep on getting this message when I try and add someone to a group. "You've added too many contacts to groups too quickly. Try again later." I use this groups for business purposes and need to fix it.
    Miriam Williams Jun 5, 2020 Link to comment
    My WhatsApp account is saying it expired yesterday but won’t upload new one ‘as not currently available in your region’
    Linda Skinner Jun 3, 2020 Link to comment
    after I receive a call when I hang up the number of calls increases on my app logo ie I have just rung off from paul and that was call number 6 then peter rings and when I have finished my call to him my logo now shows 7. how can I stop this.
    richard Jun 1, 2020 Link to comment
    when doing a video call the recipient gets a picture from me all broken up
    imus May 27, 2020 Link to comment
    Hi, I cannot open PDF files on my phone WhatsApp. I can open images, audio or vidro files on whatsapp no problem. Only problem is with PDF files. But I can open PDF files on my email in the phone, problem only with WhatsApp. It says, "The download was unable to complete. Please try again later."
    Mary Soo May 25, 2020 Link to comment
    cant open received videos or photos
      why it takes forever to open a video or photo received
    • marco sarli 39
      You may have run out of space. Delete something or move large files to card
      Sorin
    take a long time to open incoming videos or photos
    Gloria May 17, 2020 Link to comment
    My lists of people I contact on Whatsapp have started increasing themselves
    i.e. my family group now appears 7 times and all other contacts are same. Please explain how to to decrease back to individual as before.
    Sanjana Chahal Apr 30, 2020 Link to comment
    Sir sometimes i put my status on my whatsp...but I selected all my contact and only one person can't see my status why? And she already save my number in her mobile.....please give me reply
    Tony Apr 18, 2020 Link to comment
    I have no problem when doing voice call, but when I switch the call to Video, I can see and hear the other party, the other party can only see me, but cannot hear me. Please help!
    Alan Lewis Apr 1, 2020 Link to comment
    i want to install on a pc but cant use the qr code becahse my android phone watsapp menu does not have an entry watsappweb.
    Maranda Quantrill Mar 22, 2020 Link to comment
    I always use WA on my laptop but in the last few days I cannot open my laptop WA. Please help?
    AMC Feb 24, 2020 Link to comment
    I have been using Whatsapp video calls for over a year now to keep in contact with my wife in Australia, It is usually over wifi at both ends but on some occasions if one of us is away from the house it is over the 4g network, this has worked fine up until lately when my wife on the Australia end cant make or receive video calls on the 4g system, so we have to use messenger instead, so any help to remedy this on Whatsapp would be appreciated
      Uptofast Mar 9, 2020 Link to comment
      Great and useful article I have downloaded and used for my device.
    ZETVOD@GMAIL.COM Feb 5, 2020 Link to comment
    i HAVE DELETED MY WHATSAPP ACCOUNT , WITHOUT ENTERING MY PHONE NUMBER AS REQUESTED IN A STEP OF A PROCEDURE. THE RESULT IS THAT MY ACCOUNT IS STILL VISIBLE IN ALL MY CONTACTS ON THEIR LISTS, ALTOGETHER WITH CONTENTS OF OUR DIALOGUES. i WOULD LIKE TO DELETE IT COMPLETELY FROM ALL MY CONTATS AS WELL AS THE CONTENT AS IT IS SUPPOSED TO RESULT IN A REGULAR PROCEDURE.pLEASE HELP , i HAVEN'T GOT ANY IDEA WHAT TO DO
    David W Feb 2, 2020 Link to comment
    Hi. I have run into a WhatsApp voice call problem on my Galaxy S6 that I have narrowed down to a problem with the proximity sensor. If this is covered (e.g phone in its cover) an incoming call will ring for about a second then stop. It seems that the call screen tries to display but the proximity sensor prevents it until the phone is opened up and unlocked. How do I get round this please as the s6 proximity sensor cannot be disabled.
    John Jan 6, 2020 Link to comment
    I installed Whatsapp on my Samsung S10e and transferred my messages using dr.fone from my iphone. It worked fine for more than 24 hours and then stopped working all in sudden. Whatsapp can't connect to internet anymore but all other apps on my phone are connected via WIFI or data. Even Whatsapp web can't connect to my phone. I don't see anything in the app settings or another app that can stop the connection of whatsapp to internet! And I have not made any changes to my phone or apps when it stopped working this morning.
    Anyone to help? Thanks!
    sree Jan 4, 2020 Link to comment
    I have a database of jpg images uploaded in my Google Drive account. Here Image size and format is fixed, only content will change as per database information in all the images.
    Further I am using bitly to shorten URL of my Google Drive stored JPG image for sharing in my WhatsApp Group. In this process I have the following problems.
    1. URL preview alignment (top/center/bottom justified) will keep changing in WhatsApp. Left/center/right justification is fine. It will be always center justified. How to fix the alignment as top justified only.
    2. Most of the time updated/overwritten image will not get on preview. If I open the link then I can see the updated version only, but not on preview.
    Experts please guide me how to resolve the problem.
      Ricky Ng Jun 18, 2020 Link to comment
      I cant open my Whatsapp messages and cannot scroll despite received message notifications
    suggestionbuddy Dec 12, 2019 Link to comment
    thank u
    Patrick Crabtree Nov 13, 2019 Link to comment
    Having changed from iOS to Android, I want to transfer my chat groups and history across. Is that possible?
    I've just changed from iPhone to Galaxy A40. I've downloaded Whatsapp but when I enter my name it says Unable To Connect, Please Try Later. Any help would be appreciated.
    KyraKrakos Oct 28, 2019 Link to comment
    I got a new phone, pixel 3a, and my international contacts I suddenly can't send messages to. All other contacts working fine. How to fix?
    Phoenix Oct 27, 2019 Link to comment
    The blue tick is not abled for many users
    SOLOMON Oct 24, 2019 Link to comment
    I just got a used (honor ) and in esch time i want to activate whatsapp, i always see in the screen "your number is banned from using whatsapp. I do not know whst to do
  • marco sarli 39
    Oct 23, 2019 Link to comment
    at least Android 2.3 ?
    Sorin
    THANGAPANDIYAN Oct 14, 2019 Link to comment
    Watsapp automatically gets logged out from my phone. And all the watsapp images, videos were deleted
    Couldn't found in internal storage too
    Why does it happened?
    Sudha Oct 7, 2019 Link to comment
    I am using whatsapp for five years. But since the last two years I noticed that I can't send messages to some of my contacts even they haven't blocked me. I need a solution for this.
      Same problem. Have you found a solution?
    Malik usman Sep 29, 2019 Link to comment
    I am using fmwhatsapp 2.
    I always show a notification " checking for new messages " and the messages which my friends sent to me are not reaching on time the are always late. What is this problem.
    princeSMART Sep 28, 2019 Link to comment
    My whatsapp is saying
    Sorry cant load this audio now .pls try again later 😥
    Roaa Sep 26, 2019 Link to comment
    My WhatsApp crashes everytime I reinstall the app and get the backup download done! It works fine until the backup finishes downloading and it starts crashing after 2 seconds of opening the app, and I also get the notification of "deleting messages" all the time from WhatsApp. I tried all kind of solutions, nothing worked, any help? I can't lose my backup, so much information there 😢.
    Deepthy Sep 25, 2019 Link to comment
    Same no. Is saved in different names... In new cht... Bt thn only one number is saved in my contact
    mandy Sep 12, 2019 Link to comment
    keeps telling me it's backing up...nothing changes. Help!
    Agweng Lucky Sep 12, 2019 Link to comment
    I have installed whatsapp on my Samsung Tab but it has failed to initialize. All that is showing is status service unavailable.How can I fix this
    Noor khan Aug 31, 2019 Link to comment
    My number is ban form using WhatsApp
      Harmandeep singh Sep 27, 2019 Link to comment
      My WhatsApp number has been beend my nubmer 00971528294304
    Mansi Aug 29, 2019 Link to comment
    Media gets deleted automatically after viewing.Not able to change the settings from anywhere
    Cnu Aug 28, 2019 Link to comment
    Recently I have sent some mesgs to my friend and we both cleared the whole chat history and after to days my friend getting the same mesgs again and again without sending and those mesgs are not opening just they Ra seen notifications please solve the issue
  • Aloi Susan 2
    Aloi Susan Aug 27, 2019 Link to comment
    WhatsApp service status unavailable
  • Aloi Susan 2
    My WhatsApp service status is unavailable
    Justinbizzle519@gmail.com Aug 22, 2019 Link to comment
    I want to deactivate my what's app account it's hacked
  • Ian McCann 1
    Ian McCann Aug 18, 2019 Link to comment
    I voice call a friend, using WharsApp. It cuts me off even before it rings at her end. I can text and recieve from my friend? I just can't call. I used to be able to.
    Other people no problem.
    Dctr Aamir Hussain Aug 14, 2019 Link to comment
    An unauthorized attempt has been stop to your device to restore factory settins
    An unauthorizd attempt has been made to resetyour device to restore factory setting. Please connect Wifi network
      resetyour
  • Adnan Shahid 1
    Adnan Shahid Jul 31, 2019 Link to comment
    Whatsapp Incoming Calls Not Showing When My Phone Is Locked.
  • Ganesh 1
    Ganesh Jul 30, 2019 Link to comment
    My what's app bending
    deola Jul 28, 2019 Link to comment
    My whatsapp won't open
    It shows a green line like it's loading
    I'm using a blackberry passport
  • Faisal 1
    Faisal Jul 24, 2019 Link to comment
    My WhatsApp doesn't open it shows u will get code after 24 hrs or 36 now it shows 48 hrs what should I do 2 open it
    Neha jain Jul 19, 2019 Link to comment
    my internet connection is good n i can receive msg in whatsup but when sending msg it is not going instantly plz solve it now ,needed
    yorkieyours Jul 18, 2019 Link to comment
    I received a text message from area code 213-908-1625 at 6:02 AM 7-18-19 stating this: 157648 (it wants me to tap it to get into it) Someone taken yours photos from Whats App and now they is here. como.po with a vertical line through the o. Of course I see it is Broken English and I deleted my whats app and did not open anything that was texted to me. What else should I do? Reinstall?
    XxAngel xX Jul 15, 2019 Link to comment
    Whenever I try to view someone's status, if the status is a photo it is blurred and I can't view it properly. Also, after a few seconds, my phone exits whatsapp and goes back to the home screen.
    Also, I can't send my own photos on my status. When I try, the phone exits whatsapp and goes back to the home page. When I go back to Whatsapp and look at my status, it says "couldn't send".
    patchmeup Jul 15, 2019 Link to comment
    WhatsApp is deleting my contacts status updates regularly, often before I even have a chance to view them. How do I fix this?
    Md Mehedi Hassan Jun 24, 2019 Link to comment
    I can not log in into my whats app account.when i enter my phone number but i can't get any verification code. It see that my whats app version is not letest..please download the latest version of whats app.but i already download the latest version of whats app.please give me a solution
  • hanakuna 1
    hanakuna Jun 21, 2019 Link to comment
    Why is it my whatsapp status isnt working? I changed from using GB whatsapp because of been banned by your policy and now I downloaded the real WhatsApp and isn't working properly. What happen?
    Eldwe Jun 16, 2019 Link to comment
    WhatsApp not working. Uninstalled and reinstalled twice now but verification process won't complete. Always comes up with the message. No internet connection. But internet is on and can access other applications.
  • Rone 1
    Rone Jun 7, 2019 Link to comment
    whatsapp isn't working properly while on the new NBN internet, incoming calls can be answered and the caller can be heard but they cant hear me, video calls wont connect at all. but as soon as i turn the wifi off the app works perfectly, this issue has only started since upgrading to the NBN internet instead of the ADSL2 internet which is no longer available. the phone being on wifi and making or accepting calls or video calls when in ADSL2 was not an issue, everything worked well. but from the moment NBN became active it does now work.
    any ideas?
    elodge May 24, 2019 Link to comment
    My Galaxy A5 phone is effectively dead. It won't charge (the port needs replacing) and there is no battery power. Data will be wiped before repair. Is there any way of retrieving Whats app messages?
    tzipora May 6, 2019 Link to comment
    Hi, I am having trouble baking up my conversation from whatsapp I have plenty of room on my iCloud Drive so it shouldn’t be a problem.
    Yael Goren May 2, 2019 Link to comment
    Why does the notification sound plays every time I listen to a Whastaap voice message? It overlaps the content of the voicemessage constantly during the entire voice message
  • sabir hussain 1
    sabir hussain Apr 18, 2019 Link to comment
    whatsapp group unlimited members
  • sabir hussain 1
    u r group mambr 257 y whatsapp group unlimited members plz
    Teesha Mar 14, 2019 Link to comment
    I cannot send pictures neither i am able to put on status but all my messages are semt amd delivered!! Please help me to fix this!
    maulana_ludi@yahoo.com Mar 14, 2019 Link to comment
    I cannot send a picture/photo while the text can deliver well. How can I fix this? Thanks
    rbdada Mar 8, 2019 Link to comment
    I am using Beta version and from today mostly sent and received pic and msg not showing in chats only time displayed, whts the problem. Pls guide
  • Sulagna Bishnu 1
    Sulagna Bishnu Feb 10, 2019 Link to comment
    I am not being able to send whatsapp message sometimes and it took couple of hrs. Although network connection is pretty good. When I am trying to change my device even not being able to restore the msg and it's getting stuck after 24% can you please hep?
    Naman Sharma Feb 5, 2019 Link to comment
    Whatsapp keeps hanging, then glitching and says that messages are lost, will have to restore messages. It proceeds to start the restoring process but it stops midway and now I've lost chats since August 2018. It has happened to me twice in two days and I can't restore cuz I overwrote the data.
  • Omar Saleem 1
    Omar Saleem Feb 4, 2019 Link to comment
    my whatsapp acount is banned . what to do to return it
  • Maria Aziz Chohan 1
    Maria Aziz Chohan Feb 4, 2019 Link to comment
    i am installing whats app but every time it is showing the msg that there is a problem in whats app install it again what to do?
  • Rini Jain 1
    Rini Jain Feb 2, 2019 Link to comment
    Hi I am facing too big problem from watsapp. I have restored the data but still data of some dates in between is missing. pls help
    IanDHarris Jan 27, 2019 Link to comment
    "You Guessed too many times" - locked out for 2 weeks now. Despite un-installing, deleting the Whatsapp folder, re-booting and re-installing, whether on my main Android phone or my standby iPhone, this message appears instantly when I confirm to sms me at my mb number. I have followed the CONTACT SUPPORT route that follows, 21 times, ie 21 emails to Whatsapp. They responded twice to say "Read our FAQ, and it doesn't help, reply to this email". However, just these same 2 replies within the 2 weeks that Ive been locked out.
    It seems that Whatsapp do not offer actual support, just send this standard reply.
    I desperately need Whatsapp for communication with my staff and clients.
  • F.Alam 7
    F.Alam Jan 1, 2019 Link to comment
    Thank you very much for helpful tips
    Mark andrew Dec 30, 2018 Link to comment
    I have 2 separate whatsapp accounts for business and personal but share the same google drive to back up chats .now i want to merge both accounts so i can use just one account for both business and personal use and would like to know if messages from the separate whatsapp accounts that had backed up in google drive account would synchronize and appear chronologically.
  • Shubhranshu Dubey 1
    Shubhranshu Dubey Dec 16, 2018 Link to comment
    I am unable to upload my status with caption...it gets uploaded otherwise i.e. when i do not add a caption?
  • Mudasir Ahmad 1
    Mudasir Ahmad Dec 4, 2018 Link to comment
    Hi. My WhatsApp is not sending neither text nor voice messages??😥😥
    Jan Crooks Dec 1, 2018 Link to comment
    Hi, my WhatsApp will not send my messages
  • Patricia Steward 1
    Patricia Steward Nov 30, 2018 Link to comment
    I love my whatsapp and have been using it for years. Suddenly though, each time I want to use it on my computer, I need to open both the Android phone AND my computer, and then have to scan the QR code....just annoying too many times a day. Thanks!
  • Basab Barman 1
    Basab Barman Nov 29, 2018 Link to comment
    Hi... I have installed Whatsapp in a new android phone. When I try to access it, it pops up with a message something like ' your phone's date and time are not correct. please adjust and open again'. But my phone's date and time are absolutely set accurate to my time zone. How do I rectify this issue?
      unlemma Dec 4, 2018 Link to comment
      i have the same challenge right now
    Md Faizan Siddiqui Nov 15, 2018 Link to comment
    Someone sent me a message in whatsapp but it is not showing it,instead its showning as "This message can't be viewed because you are using a cheap mobile."
    So plz say me whats the problem
  • Shweta Adurkar 1
    Shweta Adurkar Nov 11, 2018 Link to comment
    Why my WhatsApp status is not visible to me after updating it?
  • Keshri Nandan 1
    Keshri Nandan Nov 8, 2018 Link to comment
    Together, many people can not be selected to send SMS to 5%, which is a big problem, then what is the time of the user to use the user. I suggest that all the contacts list should be selected together.
  • Nermo 1
    Nermo Nov 3, 2018 Link to comment
    Someone left the WhatsApp group and am the admin and can't add her . Got a message that she left the group recently and should try again later . Take in consideration that am not blocked from her side.
    • Krass Kevin 1
      Krass Kevin Nov 17, 2018 Link to comment
      Im also have the same message what the problem how we solve it?
    Falak Ashfaq Oct 30, 2018 Link to comment
    Hi, so basically I can’t send msgs to one particular number whereas I’m receiving msgs from that number but my msgs are not getting delivered. Neither of us have blocked the numbers or so . Tried deleting and reinstalling WhatsApp . Tried reset phone to factory reset. Please is there any one who can help???? It’s urgent and I would really appreciate your help.
    Thank you
    shalini jain Oct 27, 2018 Link to comment
    My whatsapp made a false video call suddenly..why is it so? i am using iphone 7
  • Amritashya Saikia 1
    Amritashya Saikia Oct 4, 2018 Link to comment
    My WhatsApp msgs get deleted automatically why? I tried every possible steps right from.force stop clear cache , reinstall to reset of my phone but in vain. Help me
    Shady Botros Sep 30, 2018 Link to comment
    Have a problem in whatsapp businiss which chats are automattically deleted
  • Nicole Yoeman 1
    Nicole Yoeman Sep 19, 2018 Link to comment
    I noticed my significant other’s profile pic changed on what’sapp. They said they didn’t change it and that the new update did it. It’s An android phone. This haberpened just a couple days ago. I have an iPhone and didn’t get an update. Is this scenario true for android users with WhatsApp?
    Johan Jansen Sep 17, 2018 Link to comment
    I don't receive notifications of new messages when the whatsapp app is closed. When I open the app, all messages since the last time I used the app are received which means that at times I receive the messages long after it had been sent. How do I change the settings to fix that?
    Megha Unnikrishnan Sep 15, 2018 Link to comment
    In my WhatsApp, one contact is unable to open bt I can view the contact, and also can view thee status. Bt Iam unable. To open the chat. What should I do??
    yyaasshh1 Sep 13, 2018 Link to comment
    My.mobile number is banned by WhatsApp please tell me the solution
  • aadil khan 1
    aadil khan Sep 5, 2018 Link to comment
    my whatsapp is not work
    I'm uninstalled but I'm not going to send messages to any of Whatsapp.
  • RANGA RAJAN 1
    RANGA RAJAN Sep 4, 2018 Link to comment
    My whatsapp status not showing some person..but they are in my contact list
    mahendra singh Sep 1, 2018 Link to comment
    Hii i facing a prblome is that i cannot send a message mare than 5 people at a time
    When i foarward a message and then i select people but with 6 selection the measge came "YOU CAN ONLY SHARE WITH UPTO 5 CHATS" plzzzz help me fr facing this prblme
    Keshri Nandan
    • Keshri Nandan 1
      Right this is big problem, please resolve this problem
  • prasath shrini 1
    prasath shrini Aug 20, 2018 Link to comment
    hi, i used whatsapp in my old Blackberry curve 9380 in the year 2014 - am trying to retrieve the db file for viewing some of the conversations - unfortunately am unable to figure out any ways to view them - can someone help?
  • prasath shrini 1
    Sase Aug 13, 2018 Link to comment
    I am trying to get more whatsapp contacts but without any success, When I open whatsapp, mine shows CHATS,STATUS,CALLS while others are showing CALLS, CHATS, CONTACTS. Therefore, how can I add more contacts to my device. I have tried almost everything but with no success. Can someone please advise me? Thank you
  • paz hefer 1
    paz hefer Aug 9, 2018 Link to comment
    new phone with new number - how can i Restore my old account and then change it to my new number?
    my old one is not working and i used a number that no longer exist
    Sairam Jul 25, 2018 Link to comment
    In my new samsung j8 mobile , when i try to view others status, it opens and that status will be stored in a folder called ".Statuses" ...After few minutes that folder becomes empty and again when i try to open others status from whatsapp it will not open and it says that "Sorry this media file does not exist in your internal storage"
    • Ayesha Aslam 1
      Ayesha Aslam Aug 8, 2018 Link to comment
      I am having the same issue on samsung A6+. Did you find any solution?
  • wendy neil 1
    wendy neil Jul 5, 2018 Link to comment
    I cannot receive WhatsApp messages if I'm not at home
  • Ron Becker 1
    Ron Becker Jul 1, 2018 Link to comment
    I use Whatsapp with my GF who is in the philippines we both have galaxy S9 phone's but all of a sudden when we try to connect by video or voice both phone's are showing connecting. we have made calls previously with out issues. Any help with this problem would be greatly appreciated. Thanks in advance
    June Carter Jun 20, 2018 Link to comment
    My phone keeps telling me I have Whatsapp messages when I dont. Does anyone know how to fix this? It started about a week ago telling me there was one. Now it's saying two. I clear the screen but as soon as I get a message from someone and I read it, it still says I have two messages.
    Karen Ribaul Jun 20, 2018 Link to comment
    I cannot turn off the Whatsapp camera shutter on my new S9+. The app camera never made a sound on my Note. I've tried in the settings on the app itself and in my phone's settings for the app.
    Monique Jun 17, 2018 Link to comment
    So i go in a whatsapp video call then my screen freezes on it i cant do anyting am not able to come off the screen or do anything
      Serena Oct 25, 2018 Link to comment
      Did this get sorted? I have the same issue
    HAROON AAMIR Jun 13, 2018 Link to comment
    I can't see the whatsapp status /stories of others,it was showing sorry this media does not existing in your internal storage
    i changed my phone help please
  • Sai Manepalli 1
    Sai Manepalli May 14, 2018 Link to comment
    I can't see the whatsapp status of others,it was showing sorry this media does not existing in your internal storage.
    Learning Courses May 1, 2018 Link to comment
    Can any one know that how to fix this problem in whats app,
    I am using whats app in Ko Player (Android Emulator) every thing is okay but when i play voice messages whats app automatically restart and cant play voice messages.
  • MikeandArlyne Acero 1
    MikeandArlyne Acero Apr 4, 2018 Link to comment
    Hello. I have been using WhatsApp for a long time now and have never had any problems until recently. This started out of nowhere. I can make/receive phone calls, but he person on the other end can hardly hear me. I hear them fine, but they can not hear me unless I yell into the phone. They say that I sound very far away. Can anybody tell me how to fix this problem? Thanks in advance.
  • A-Jay Colorlab 1
    A-Jay Colorlab Mar 15, 2018 Link to comment
    Can someone who is not in my contact list message me on whatsapp if I give them my phone number?
    • Bastian Siewers 66
      Bastian Siewers Mar 16, 2018 Link to comment
      Hi A-Jay, yes. When they add your number they will see that you are using WhatsApp and they can instantly message you.
      • A-Jay Colorlab 1
        A-Jay Colorlab Mar 19, 2018 Link to comment
        Do you mean once I sign up for Whatsapp using my phone number? I have been using Whatsapp for a long time now and mostly it works fine. Occassionally I will meet someone new (outside of Whats app) and I will give them my phone number and then they cannot contact me with Whatsapp. But once I go in and add them to my contacts then they can contact me. Do they have to be in my contacts to be able to text or call me on What's app? Or do I have a setting set that makes that so?
        Bastian Siewers Mar 27, 2018 Link to comment
        Hey A-Jay,
        sorry for the late reply.
        I have to admit, I haven't really heard from that issue. Anyone who has your number should actually be able to send you messages. They don't need to be in your contacts.
        How exactly are they not able to text you using WhatsApp? Do you just not show up in WhatsApp after they saved your number? Or are they blocked from sending you a message?
        Sorin
  • Sajjad husain 1
    Sajjad husain Mar 14, 2018 Link to comment
    you may have new messages whatsapp plz sir give me solution
    Zeeshan rafique Mar 2, 2018 Link to comment
    I think u r not able to answer my question
    Plz help me
    When i am installed whatsapp on my mobile then my mobile restart dont installed whattsapp why???
    Christine Siddle Feb 26, 2018 Link to comment
    WhatsApp state their app is no longer compatible with Samsung Galaxy phones older than 2.33. My phone is 2.33, but I still can't use the app I recently installed, why?
    Nik Feb 21, 2018 Link to comment
    Keep getting the "Network busy" message whenever calling a particular contact whose number is working.
  • Anupama Ratheesh 1
    Anupama Ratheesh Feb 14, 2018 Link to comment
    I have problem with video calling. Showing that microfone doesn't working
    Matt k Jan 24, 2018 Link to comment
    I created a group for keeping contact with certain people, which works out fine. However, I went to added a new person to the group, then pressed exit to exit the app but it deleted me from my own group. I can't get back in and no one else in the group seems to have the ability to add me. I don't want to create a new group because we have a thread going on. Advice?
  • Qom Ariefal 2
    Qom Ariefal Dec 30, 2017 Link to comment
    some of my friends tell me that the video I sent to them can not play and there is a notification saying 'This video is not available because something wrong with the video file'. most of them using samsung. but other mobile phones can play.
    Selvi karthik
      Selvi karthik Jan 14, 2018 Link to comment
      Same problem persists for me.... My phone model is honor 6x. In my case, my recipients are non Samsung users. Still the problem exists. Is there any solution?
    Danny Haramati Dec 16, 2017 Link to comment
    I have a problem with the proximity sensor, that he is turned on when i hear voice messages on whatsapp when nothing is proximate. he just being turned on automatically' thus I can't hear the messages on speaker.
    john bottomley Nov 28, 2017 Link to comment
    using whatsap video everyday to thailand. my friend can hear me perfectly. the audio from thailand cuts in and out. there are long periods when i can hear nothing thank you.
    jacquelyn ong Nov 16, 2017 Link to comment
    During update Whatsapp latest version which current version obsolete on Nov 16, 2017, prompt out error "A server error has occured. Retry, or cancel and return to the previous screen."
    After click Retry, it prompt out "The requested item could not be found."
    Need help here, thanks.
  • altaf hussain 1
    altaf hussain Nov 15, 2017 Link to comment
    I cant sent audio massages from my whats app kindly help
    Sue Berlasty Nov 5, 2017 Link to comment
    My boyfriend has an Asus Zenfone 3 refurbished. When he messages me on Whatsapp I don't get the message. When I do get the message he doesn't get my reply. Would you know what would be causing this, and how to go about fixing it? Thank you so much.
  • Mahendra Dhimate 1
    Mahendra Dhimate Oct 28, 2017 Link to comment
    my whats app is showing the message UNFORTUNETLY WHATS APP HAS STOPPED with in few seconds I start my whats app kindly suggest the solution
  • SergeyPRKL 1
    SergeyPRKL Oct 13, 2017 Link to comment
    I have this issue that mu ANdroid phone, Nokia 6, with 7.1.1 android shuts down whatsapp and i dont get messages. I cant find anything that shuts it down, its not listed on powersaving etc, what to do?
    Leandro Barriga Sep 17, 2017 Link to comment
    I didn't receive an activation code, I also requested a phone call that never came through, I checked my number and the Spanish Country code are all correct. I need some direct service to fix this problem please. My cell number is +34698495964. Thank you
    David Elazar Sep 13, 2017 Link to comment
    When i try to save picture from WHATSaPP by clicking "SHArE" and choosing "ES save to" (or any other file explorer app) to save the picture to android storage/memory/ExtSD, i get :
    "This operation is not supported".
    It used to work.
    I also tried "Factory reset", and reinstall Whatsapp and file explorer apps like ES file explorer.
    Didnt help.
    Thanks
  • Ishrat Parween 1
    Ishrat Parween Aug 29, 2017 Link to comment
    i m using my whattsapp from yesterday when i open some group/individual chat box app closes automaticallt and comes back to home page i m using lyf LS-5016 android mobile using jio network.please help to sort it out
  • Ishrat Parween 1
    Sun Yeo Aug 29, 2017 Link to comment
    Hi how do I solve this problem in whatsapp of "couldn't load this photo. Please try again " when I click Done after I cropped or rotated a photo shared directly from my gallery? Doodling the photo is fine. And only happens when I shared from gallery. It's fine if i attach the photo in whatsapp.
    Eileen Embley Aug 23, 2017 Link to comment
    Ihave a down arrow alongside the latest message from one of my whatsapp contacts that prevents me from scrolling up or down to see the end of the message they have sent. All other contacts are fine and do not have this arrow within a circle. Can anyone help please?
  • Thomas Hartley 1
    Thomas Hartley Aug 12, 2017 Link to comment
    Please i cant get the activation code have waited and waited for days i cant get it
      Did you check your spam folder?
    Julie Docker Aug 9, 2017 Link to comment
    I've just installed Whats App after not using it for a while, but it isn't learning anything. I have to correct every single mistake I make myself. It's really frustrating. Please, what do I do?
  • Chandrika Sharma 1
    Chandrika Sharma Aug 6, 2017 Link to comment
    I can't open my WhatsApp..whenever I open it works automatically...if i want to open one contact..other contact opens automatically..even if i want to share something than it goes to everyone
    Kelvinsjw Jul 10, 2017 Link to comment
    Having trouble updating whatsapp for infinix hot note 3. Followed the instructions I read online with little help. Don't know what to do.
      Kelvinsjw Aug 5, 2017 Link to comment
      Try reset the device to factory default and try again.
  • Francis Kiong 1
    Francis Kiong Jun 11, 2017 Link to comment
    All of a sudden my messages from all my whatsapp contacts are muted. Some more I can find any whatsapp videos or images in my gallery. Why?
  • Marta Ramirez (Mystical StarSylph) 4
    Marta Ramirez (Mystical StarSylph) Apr 27, 2017 Link to comment
    Whatsapp chats are automatically deleted after a day on huwaei phone
    Madhav Adya Apr 27, 2017 Link to comment
    I have HTC one M8, many times while chating, my whatsapp blacks out, a black screen appears, whatsapp restarts automatically and takes me to whatsapp home screen. Once this starts, I can't chat again till I clear cache, clear data and restart my phone or sometimes reinstall. Its happening very frequently now and its annoying.
    Mia Terry Apr 15, 2017 Link to comment
    Hi, I have the Huawei p9 and when a want to send an audio file from my music it gives me a blank, and when I go to my music and try to send or share it from there it doesn't even give me that option. My question is how do I send an audio file via whatsapp if my whatsapp give me a blank if I want to send an audio because all the other icons work like location, gallery ect. Please help.
  • Shalini Sharma 1
    Shalini Sharma Mar 29, 2017 Link to comment
    I have changed my whatsapp number just for a hour then again i change it with my old number but now i am not able to see few of my contacts dp ..
    Rob Niemeyer Mar 16, 2017 Link to comment
    My problem is that I do not get immediate notification for most of my incoming Whatsapp messages. On my HisenseU972 running Android 5.1, I have made the following settings : I have made Whatsapp a priority app; under data usage background data is accepted. Within Whatsapp notifications, the setting is 'always show popup'. Under data usage, all four options are ticked.
    Some messages come through correctly. For the rest, I have to go into Whatsapp. After waiting about 30 seconds, the messages pop up. Looking at the date/times, messages can be hours or days late.
  • Maj Rocco 1
    Maj Rocco Mar 6, 2017 Link to comment
    Hey I'm running a BlackBerry DTEK50 and Android 6.0.1 and I have a Whatsapp issue... the only status that shows up is mine. I've allowed all contacts to be viewed, and other people can see my status, but I can't see anyone else's.
    Little help? Thx
    Padma joshi Mar 5, 2017 Link to comment
    I have croma tablet model CRXT 1131 version 4.4.2 . in my whatsapp the 3 vertical dots on right side are not opening. What to do? Pl help. I have reliance network.
  • Mohit Raval 1
    Mohit Raval Feb 27, 2017 Link to comment
    I am more from India, Recently from last 2 -3 days I am facing problem in sending video to my contacts in whatapp, when ever i send video the video of video become automatic fast , example I have take 60 Sec Video from my camera Phone and no when i upload it to my whatapp contact it automatly become 30 sec with fast forward, my contact can see full leanth video but in fast forward mode. The same problem is coming in old video which i have sent properly 2-3 before.
    • Rahul Krishna Agarwal 1
      Rahul Krishna Agarwal Mar 14, 2017 Link to comment
      I have also noticed similar behaviour today. A video of 21 sec duration became 14 seconds duration on whatsapp creating fast motion.
      Rthi Mar 26, 2017 Link to comment
      I do have same problem... Did you get some solution?
  • Dobermann Soeurs 1
    Dobermann Soeurs Feb 27, 2017 Link to comment
    Is there a way to stop sending my video in a whatsapp call?
    Namita Gupta Feb 24, 2017 Link to comment
    i got new version of whatsapp but i dont see the status of my contact how i view the status of my contact this is not beneficial update i don't like this update
  • Stephania Done 3
    Stephania Done Feb 23, 2017 Link to comment
    To transfer whatsapp message from android to iphone, here are the easier way yo help you finish the transfer process.
    Method1. Using Email Chat
    Method2. Using WhatsApp Backup
    Method3. Using iPhone Data Recovery Toolkit
  • Marlene Shehadeh 1
    Marlene Shehadeh Feb 8, 2017 Link to comment
    hi ,
    since about 3 weeks ago i can't access gallery when wantimg to attach an image/video in any conversation.
    i click the paper clip then gallery then get the "unfortunetly whatsapp has stopped" error. any help is welcome
    Elijah walls Feb 6, 2017 Link to comment
    I have been using video chat with my friends all was well but now they cannot see me anymore as a live feed just a contact pic shows any solutions to this problem ?
      Dobermann Soeurs Feb 24, 2017 Link to comment
      I am having the same problem, I can receive video from callers but not sending I can see my video in the PIP on my screen...help please...
        just update ur whatsapp and use 4g connection or wifi using whatsapp call
        I updated my whatsappand am using wifi, can you explain what you mean by whatsapp call?
    aakash abhinav Jan 28, 2017 Link to comment
    Having this weird issue. "Verification through call" calls from WhatsApp are having no audio. Happened twice now, waiting for the sms counter to reset.
  • Dusan V. 12
    Dusan V. Jan 27, 2017 Link to comment
    I don't use WhatsApp anymore. And few years ago it was my number one choose.
    Regidor Cruz Jan 26, 2017 Link to comment
    Agree
  • shivam Rayjada 1
    shivam Rayjada Jan 17, 2017 Link to comment
    REGARDING NOT HAVING VERIFICATION.As i mentioned when i installed watsapp after formating my cell,i installed again watsapp but after verification process an error is coming that"WRONG PASSCODE" I tried many a times the whole process again with correct passcode as got in my sms still the same.Also tried call me option,entered again the passcode but still the same error appears.Please its a humble request to solve this and help me in this problem.waiting for a positive response.Please help its a request.I tried many a times but still the same error
    Thanks and waiting for replies from valuable viewers...please
    Penelope Castillo Jan 11, 2017 Link to comment
    I wondered if someone could help I have tried contacting Whatapp customer support and they only send automated emails. I have verified my number too many times and now it says I have to contact support.... which I have tried doing but they are not responding. Do you know how I can verify my number again? There isnt even a count down time it wont even let me try and verify.
    Annie Nov 2, 2016 Link to comment
    My partner lives in Spain and I can ring and message him no problem and he can message me both text and voice no problem. But when he tries to call me the call gets declined straight away and I get a missed call notification but the phone never even rings..... any ideas what the problem might be ????
    Andy L
      Andy L Nov 22, 2016 Link to comment
      I have the exact same issue with missed calls. Did you ever find a solution?
      Dominique Zen-Ruffinen Aug 5, 2017 Link to comment
      had the same problem with Whatsapp pre-installed on the Samsung Galaxy S6, after hours calling my provider in Switzerland and Samsung help desk there was no answer. Almost giving up I decided to reset to factory, this time not installing AVG Anti virus!!!! and it works now perfectly. It seems that Whatsapp preinstalled does not like antivirus apps!!! but extremely sad that neither the provider nor Samsung helpdesk could solve the problem
  • Thomas Biju 1
    Thomas Biju Nov 2, 2016 Link to comment
    I cant download or upload images,videos,audios in my whatssapp.I tried reinstalling and its not working. Plz help me.
    nizam Oct 29, 2016 Link to comment
    Dear Team, am not receiving whatsapp notification and new messages while my screen is locked/off. When i manually enter the whatsapp that time only i am receiving notification .so plz help what is issue ?
    Dear Team, am not receiving whatsapp notification and new messages while my screen is locked/off. When i manually enter the whatsapp that time only i am receiving notification and messages. I checked my device completely all notifications was enabled condition only even i checked whatsapp notification settings also there also al notification was enabled only. yesterday i downloaded and installed the new version of whatsapp but still notification was not receiving.
  • Sooraj Gurjar 1
    Sooraj Gurjar Sep 27, 2016 Link to comment
    sir i have one problam yesterday i install whtsapp and there was pending sms but its showing so can u please resolve my problam its a humble request please solve it
  • Aqilah Ali 1
    Aqilah Ali Sep 7, 2016 Link to comment
    Hi.
    The sole admin for our family group Whatsapp previously was my father. After his SIM card is not working good, he changed to another number and now the group is left without any other admin. Please let me know if you have solution for this problem.
    We can't add new members to this group for a while already :(
    Анна Мороз Jun 28, 2016 Link to comment
    WhatsApp is blocked in UAE, when I was there I used Sahrzad service and it worked fine.
  • Ihtasham Ali 1
    Ihtasham Ali Jun 22, 2016 Link to comment
    how to solve this problem wheni open a whatsapp its syes unfortunately, whatsapp no longer supports this phone please switech to a supported phone................
    keryy Jun 5, 2016 Link to comment
    hey can someone please help me i am a Jamaican.. i was looking for some space on my phone i click clear all data from whats app it happens to log me out of whats app now am trying to get back in and i cant every second i click send me an sms it says wait one hour so many hours have passed and i try again and again still not logged in same thing goes for call me, then it has a sentence at the top saying (waiting to automatically detect an SMS to this number to this number .. it has been four days now someone please help i use whats app to do my work.. thank you for your help please....
      have you tried restarting your phone?
  • 12
    Emma William Jun 4, 2016 Link to comment
    I have a issue with my whatsapp account.
    I have a whatsapp group and i am the one admin of that group. unfortunately i left the group which i am the only one admin of the that group. still that group running but no admin.please help friends.
    Ava James
    dilip kumar May 30, 2016 Link to comment
    when i send a picture on my whatsapp chat group all the members cannot view them, please advise why is this problema on my Smartphone. thanks
    Marais Olivier May 27, 2016 Link to comment
    I have installed the latest version of WhatsApp, but now I can't get past the Google Drive backup when I try to open the app. I select my Google Account but when I press "Done" I still get a message that reads "Choose a backup frequency to continue". Please help
  • Hafiz Pijol 1
    Hafiz Pijol May 7, 2016 Link to comment
    I want regist my whatsaap buat that number is gone
  • Charlie Carr 2
    Charlie Carr Mar 18, 2016 Link to comment
    My only issue is that not enough people that I know use the app!
    • Alex 17
      Message them all using WhatsApp so that they all know that you are using it.
  • PocketAppZ 2
    PocketAppZ Mar 18, 2016 Link to comment
    Please write an article highlighting the best SMS/MMS apps that do not require a phone number. Obviously, Whatsapp would not fall into this category.
    There are plenty of messaging apps out there but it would be nice if users could send and receive SMS messages without the hassle of needing a phone number. What am I supposed to do if I want to text people using my tablet that has no number?
  • 12
    lianne john Mar 17, 2016 Link to comment
    Bang on, just something I was in need of:)
  • Sonam Khatri 1
    Sonam Khatri Mar 13, 2016 Link to comment
    hello, do you know any way to implement whatsapp contact on my website nokre.in ??? i want my visitors to send me message on my mobile using whatsapp in my website, i mean any form like that? please help! thanks
  • Mudassir Akhoon 1
    Mudassir Akhoon Mar 9, 2016 Link to comment
    sir my whatsapp problem is this me in saudi arabia nd i need pakistan no in whatsapp so code is not coming so plz give me a solotion
    Dorothy S. Mar 9, 2016 Link to comment
    just go to Telegram
    much better
    George Vasiliadis Mar 6, 2016 Link to comment
    What l hate about WhatsApp
    1. You cannot set it up on a 2nd device
    2. You cannot set up a chat with 3 or more peple
    Sticking with Skype, maybe 1day they may catch up
  • Parvind Chahal 21
    Parvind Chahal Mar 5, 2016 Link to comment
    u r messing things now.....u should write new article
  • Anup 1
    Anup Jan 17, 2016 Link to comment
    You may also organize or label whatsapp chat messages using Bag A Chat app. Or create analytical reports based on chat messages.
  • MARY SHADE 1
    MARY SHADE Jan 15, 2016 Link to comment
    I love whatsapp but lately when I use my laptop to chat with someone, they don't get my messages and I don't get theirs. It's very sporadic, but annoying when it does happen. Is there a solution to this issue or is it some kind of glitch in the program?
  • subbu 1
    subbu Jan 6, 2016 Link to comment
    Why smiles in whatsapp is not getting updated from long time...? The smiles are boring to use..!!! Also I am not getting notification for incoming messages when my phone is locked. I am using version 2.12.367.
    corazon aloot Jan 6, 2016 Link to comment
    this is about my messenger, if someones calling me i need to click first use data before it will ring. how can i change this i want to hear the ringtone immediately. i hope u can help me to solve this
    debanjana mandal Jan 5, 2016 Link to comment
    I have seen sombody changing his dp but my msg didnt delivered to his device,dats why i m asking how can this possible?
    is that possible as he is using whatsapp from two device through only one contact no.?
    Donaldson Kurbah Jan 4, 2016 Link to comment
    Thank you so much for your sharing.
  • Dusan V. 12
    Dusan V. Jan 3, 2016 Link to comment
    I stopped using it few months ago. I use Viber so don't see the point keeping them both to overkill battery.
  • Parvind Chahal 21
    Parvind Chahal Jan 3, 2016 Link to comment
    nice article
  • Parvind Chahal 21
    go to settins apps downloaded then go in whatsapp and clear data....ur all problems are solved n put u no. and enjoy....and dont forget to correct ur phone date and time
    Chenna Veera Bhadra Rao Jan 3, 2016 Link to comment
    whats app calling is not working in my phone
  • Bag A Chat 2
    Bag A Chat Dec 14, 2015 Link to comment
    To use WhatsApp conveniently, use BagAChat app along with WhatsApp. Life is much more simple then. try it out friends.
    Anup
    Milkah Wanjiku Nov 25, 2015 Link to comment
    My WhatsApp is not loading and downloading also when my friend send me audio it not working at all please help me to solve this problem
    Salah Almahmeed Nov 1, 2015 Link to comment
    I have Android version 5.0. After watching any received video through WhatsApp and when I click the device back key, the device stays showing black screen for few seconds then reports "WhatsApp isn't responding, Do you want to close it, Wait/Report/OK"
      Wait
    Mike Storr Oct 31, 2015 Link to comment
    When I try to text using Whatsapp, in the text balloon is a telephone and when i press to text, it rings the number instead...... how do I clear the text balloon
  • Gbibig Kajal 1
    Gbibig Kajal Oct 24, 2015 Link to comment
    MY NO. HAS BEEN BANNED TO USE THE WHATSAPP
    Visenya Álvarez Oct 12, 2015 Link to comment
    Hi,
    What if WhatsApp has stopped working after an update? What should I do?
    Alberta adjei-mensah Oct 4, 2015 Link to comment
    Pls my phone got stolen, so I don't have the chance to delete the app from my phone. The problem is that the people who stole my phone are using my whatapp. How do I get to delete my account since i don't have my phone.
    Paula Coull Sep 21, 2015 Link to comment
    I can't block a contact on whatsapp anyone know why? I've gone into settings /account/privacy/blocked/ and every time i click on blocked it just takes me back to the home page on my iphone help anyone?
    arjun vignesh k Sep 21, 2015 Link to comment
    When i send message whatsapp has been stopped why?????
    Firestone Sep 18, 2015 Link to comment
    Hey all, I am using Samsung phone and i wanted to update the latest version, however this is the msg i have received
    "WhatsApp Messenger" is not able to download update due to following error. (While downloading info from the server error detected.[RPC:S-7:AEC-7AC3E-XULB-YYMB4])
    Anyone any thoughts why i am experiencing this? Any advise appreciated! Thank you!
      Ng hf Nov 13, 2015 Link to comment
      Hi, u can remove google accounts and delete / clear the cache data in play store , Google service framework... And adding gmail account again. My friend tried. Is working
    Saif Ghole Sep 17, 2015 Link to comment
    Are you bored with the default green color of whatsapp.. wh=ant some new color..
    then change it by your self..
    Check the procedure here.. www.mytechalbum.com/how-to-change-the-default-green-colour-of-whatsapp/
    Hemanshi Gandhi Sep 16, 2015 Link to comment
    My whatsapp groups show only me as a group participant and my messages don't reach them as well. What do I do?
    Riyaz saifi Sep 11, 2015 Link to comment
    Hi androidpit i m use whts app masenger
    My isseu is any media file cant downloading error unnable to download
    How to fix
    I tryed reinstall the app but problem not solve
    Ankit Gupta Sep 9, 2015 Link to comment
    My messages are not being sent to the contacts but I can receive the messages, media and everything.
    Please help if anyone can.
    Celine Whong Sep 9, 2015 Link to comment
    the phone has power off since last night but i still see the whatapps status running actively this morning, from 9:27am, 11:57pm...
    what is happening now?
    Juned kazi Sep 8, 2015 Link to comment
    I m using iphone4.. And I m able to send or recieve voice chat to all my friends of using anroide as well iphone... Butfrom one frnd I m getting voice chat SMS but it's not playing what might b the solution of my problem ...
    Alexandre Njoto Sep 8, 2015 Link to comment
    My whatsapp is not working only showing single tick. My friends can see me online, and I also saw them online but my messages cant be delivered. This happened approx 12 hours ago
    Try to reboot, switched on and off airplane mode, even delete and reinstall but still the same result.No problem with APN since it never changed
    Can anyone assist?
    • rohan vance 1
      rohan vance Sep 8, 2015 Link to comment
      Same problem with me as well
      • Ricky Li 2
        Ricky Li Sep 8, 2015 Link to comment
        Same, just happened around 15-20 hours ago!
  • Tarun Gupta 2
    Tarun Gupta Sep 7, 2015 Link to comment
    Hi my whatsapp is not working unable to receive incoming messages and call. no incoming messages received. i am able to send the message but it is showing me single tick where it is deliver to my friend. Number : +91-9871418888 please help.
    Vanessa Hon
      Kiko Vallecer Sep 8, 2015 Link to comment
      did u find a solution? i have the same problem
      Vanessa Hon
      • Ricky Li 2
        I have the same problem, I cannot receive ANY message from groups and person, all single tick when I try to send out. Also I have uninstall the apps, clear cache, download from their offical site. The last thing I need to do is erase all data on my phone which I don't want that to happen. I am using a SONY Z3.
        Vanessa Hon
        Kristoforus Sep 9, 2015 Link to comment
        I also have same problem.... just got this problem by today.... any information how to fix it ? I can send, but can't receive...
        Vanessa Hon
        Vanessa Hon Sep 10, 2015 Link to comment
        Me too
        Please tell me too if u have a solution
  • Lorenzo 1
    Lorenzo Aug 21, 2015 Link to comment
    WEIRD problem with Whatsapp: voice notes, randomly, shows the right duration but are cut (example: clip length shown 3:00, actual clip 1:23)
    It's only happening since I've bought a Zenfone 5, with different versions of Whatsapp, and since the first day (so, it's not related to any other app I installed afterwards)
    Any clue?
    • Lorenzo 1
      (BTW, in the example: "actual clip" refers to the audio file actually recorded and sent, which is only a fraction of the full time I spent recording. It's not the correct one.)
    Jagdeep Singh Aug 21, 2015 Link to comment
    Mere whats app account me problm hai ki kabi kabi jab v kisi se chat karta hun to wo online nhi sho hota bt chat hoti rehti hai ya hota kabi kabi hi hai
    kelvin Aug 17, 2015 Link to comment
    Why does the whatsapp message read info time can changes over time? For eg: the info now shown read on 4.20pm but after few hours, the info read time changed to 6.39pm and so on...
    juan barbosa Aug 12, 2015 Link to comment
    hi everyone
    whatsapp wasn't recognizing my contacts after i updated to the latest version so i uninstalled it and reinstall it again but now after I check my phone number and my profile name it starts to load and it keeps like that for a long time until the app stops.
    i've tried several times but it doesnt work
    please if any of you can help me I would appreciate it
    Benjamin Aug 11, 2015 Link to comment
    Links included in Whatsapp messages are not clickeable (Ex: youtube link). But if I send a youtube link, it works fine. I have an S5 mini.
  • Mahmudul Hasan 8
    Mahmudul Hasan Aug 9, 2015 Link to comment
    This is my favorite app.
  • Ashish Gawde 1
    Ashish Gawde Jul 28, 2015 Link to comment
    we have a group of our college allumini . now mebers are 100 but we want to add more members. how is it possible?plz help
    mike davies Jul 27, 2015 Link to comment
    whatsapp problem. ALL calls (local & internat) speech delay and reciever has echo.
    O2 network. phone is Galaxy ACE GT-S5830 (Android version 2.2.1 ) ........... 3G.
    ALL the people I call use whatsapp to other people no problem........... Just me.
    Any suggestions please ............ have tried re-installing .... same problem
    Thanks .... Mike
  • Wayne Downey 1
    Wayne Downey Jul 24, 2015 Link to comment
    hi, when i try to open WhatsApp i get this message "unfortunately whatsapp has stopped". i can see messages come in but cant open to read them. could you please help me solve this problem?
    • Er. Aakash software expert 2
      Er. Aakash software expert Aug 9, 2015 Link to comment
      your current version of watts app is no longer compatible now ... so first make backup of your complete wattsapp by copy wattsapp folder to sd card and delete folder from internal than uninstall the app and install the latest app from store than copy back to internal ... that's it open app and it automatically backup your data ... in working condition !! if problem solved like follow ask again bye Thanks!!
    Roya Jul 21, 2015 Link to comment
    Hi, I have a question for you. I reinstalled whatsapp on my phone but when I tried to register and get the verification code it didnt send me any messages and when I tried voice verification this message showed up : (you have tried voice verification too many times. Please contact support for assistance). Please help me ....
      Low Bun Him Nov 4, 2015 Link to comment
      me same got this message..pls help
  • Basit Abbasi 1
    Basit Abbasi Jul 19, 2015 Link to comment
    Thanks for the help, I was trying to connect whatsapp while my phone was switched off.
    akecia Jul 16, 2015 Link to comment
    I sent a few messages like two hours ago and they all still only have one check by them. How can i fix this?
      The second check comes when your message is received on other end (whom u sent ) once he open wattsapp and read than it turns blue !! Thnx like follow ask again bye!!
    So i sent a few messages a few hours ago and they all still only have one check next to them. How do i fix this problem?
  • uche oji 1
    uche oji Jul 14, 2015 Link to comment
    The unanswered question: how to maintain my WhatsApp life when changing phones - easily?
    Nirel Didi Jun 30, 2015 Link to comment
    There is a Huge Update for Disable Whatsapp Calls app! please update the post!
    a lot of languages added and support to 4.0!!
    Didi Proudcts.
    Jiry Danyel Jun 30, 2015 Link to comment
    On my whatsapp messenger, it keeps notifying me that I have unread messages even if all messages have been read. In the past when this happens, I uninstall the app and reinstall to fix it, but now, it doesn't work anymore. Is some hacker doing some phishing on my device or something? Please help as this is simply annoying. Thanks in advance for your response.
    • Denis Gregory 1
      Denis Gregory Jul 5, 2015 Link to comment
      Hi, I had the same problem.
      Go to Settings, Application Manager, All. Look for BadgeProvider, Clear Cache and Clear Data.
      This fixed it for me on Samsung S4.
      You may need to restart phone.
    Akshat Jun 29, 2015 Link to comment
    2- 3 Days back I've updated my Whatsapp to new version 2.12.124. but unfortunately now phone is unable to send/receive data on 2G. Once it is connected to broadband connection via Wi-fi it is working fine. Please suggest...
    Ajit Van Jun 27, 2015 Link to comment
    Repeated 'Unfortunately whatsapp has stopped ' so many times i reinstalled it but same things happening .
      Jhordania Johnson Jul 13, 2015 Link to comment
      I am having a similar issue it displays "Whatsapp has a problem and it needs to be installed again. Tap on the button below to go o the play store, uninstall whatsApp and install it again". Was your problem resolved and how?
      Joshua Garikapatinusayhah
        nusayhah Jul 13, 2015 Link to comment
        Im having the same problem.. it aso displays that whatsapp has some problems and it need to be installed again.. i unistall it and re installed it several times but still it does not work.. please if you have the solution., email me on nuz58633@gmail.com
    Harry Makaveli Jun 26, 2015 Link to comment
    Hey fellows.
    I can't download any received photos on my watsapp or view someone's profile pic . it say please try again later"
    damtekhojol Jun 25, 2015 Link to comment
    I have already for email address but he always say you don't have an email address what would I do?!
    Nirel Didi Jun 24, 2015 Link to comment
    if you dont like Whatsapp Calls, you can use my app, "Disable Whatsapp Calls" - an app that disable your whatsapp calls in one super-easy click, you can try it - search for "Disable Whatsapp Calls" in the Play Store, no Root needed!
    Asha Rani Jun 14, 2015 Link to comment
    I am using Karbon S5titanium .I have problem in contact savings.if I have saved 1 number in contact list.automatically other number of what's up is linking
    Malapo 99 Feb 24, 2015 Link to comment
    i cant install Whatsapp after i have uninstalled it on my samsung galaxy s4,i bilif i ddnt uninstall it properly,it pops up a message saying whatsapp already installed on your device,what can i do to install it.pls help
    Girish Feb 23, 2015 Link to comment
    Hi,
    My samsung S3 phone has the message "Unfortunately, the process whataap has stopped" displayed everytime it connects to wifi or mobile data network and after that the phone hangs for exactly a minute. Nothing else seemed to change henceforth in the usage of phone, Its very frustrating that I have tried everything related to app store... I've cleared cache, cleared data, force stopped it, restarted...but nothing works
    Sohaan Pattanayak Jan 9, 2015 Link to comment
    I am Recieving a friend message but not able to send message to only a friend
    Veera Kumar Dec 30, 2014 Link to comment
    unable to send messages to Group from watsup due to not used from longtime
    ali awali Dec 27, 2014 Link to comment
    When i put my number to confirm it in whatsapp the answer always ur phone number is no longer to use our service
      Abdullah Bin Hassan Hadier Feb 9, 2015 Link to comment
      Dear Urs issue is solved or not I have face same problem if u know plz shear with me my number is 00923213333881
      Thanks
    Manikandan Dec 15, 2014 Link to comment
    that was a good piece of notification which i already know thanks..
    nethra Dec 3, 2014 Link to comment
    Hello All,
    I am using Samsung Duos 2 phone and below are details,
    Device Name: GT-S7582
    Android Version: 4.22.2
    Whenever I use clear button while typing in the What’s app, my phone gets restart.
    This I have observed very frequently.
    Kindly find the reasons why it is happening.
    One of my friend is also facing the same issue and his phone is Motorola.
    Thanks,
    Nethra P
    nysujit Nov 24, 2014 Link to comment
    I am facing slow internet connection when I use whatsapp.
    mobile- Lenovo P780
    Poonam Mevada Sep 25, 2014 Link to comment
    how i send gif image without converting anyother format in whatsapp
    Dan Cedar Sep 23, 2014 Link to comment
    How can I make WhatsApp respect my S4's profile, having to go inapp to turn vibrate on and off is stupid. Is there a solution? I've emailed their support twice with no reply.
    ANKIT Aug 25, 2014 Link to comment
    Hello, this [problem can be solve by using VPN SOFTWARE LIKE : supervpn: check this on google play store...after connecting to wifif use this simple app...
    Javed Abdul Aziz Feb 28, 2014 Link to comment
    Whenever i open whatsapp it asks me to adjust the date even though the date is correct.i have reinstalled it many time still i cant use whatsapp bcoz of same reason .plz someone help
    Shikha Shrivastav Sep 10, 2013 Link to comment
    some other issues happened in whatsapp just look at here,,,
    MOd Edit: No external links
    solutions of problems are also available here,,,
    hope you like it,,,
    Atcharaporn Kamma Jul 5, 2013 Link to comment
    free
    Anonymous Jun 27, 2013 Link to comment
    hey I want to know if a person is online and m jst looking up chat window then what will it be shown to him\her..will it be typing written? please help
        I have already email address but always say you don't haven't email address what would I do? Please tell me
