- Forum posts: 35
Aug 24, 2018, 7:17:37 AM via Website
Aug 24, 2018 7:17:37 AM via Website
Sp Flash Tool
*A Complete Solution To Flash Your Android Device*
Hello Android users, Welcome to my Sp Flash Tool Tutorial. Here I am going to tell you about Sp Flash Tool. Keep reading and add some valuable info for your future flashing procedures.
What is Sp Flash Tool
Sp Flash Tool is the application that is provided and developed by MediaTek company to improve the performance of their processors. Meditek is world famous IC designer for smartphones, tablets, consumer goods and many more.
Features Of Sp Flash Tool
- Working ability on both Linux and Windows computer
- Faster performance
- Ability to flash both Stock and Custom ROMs
- Ability to flash Custom recovery
- Checking and verifying the external RAM memory
- Formatting the device
What You Need To Use Sp Flash Tool
Since Sp Flash Tool is a PC based utility software you need a Windows
Or a Linux computer (32 or 64-bit)Original USB cable of your device
MediaTek USB-VCOM drivers Firmware file you are going to flash along
with the scatter file
Scatter file contains the information of device structure and the memory map of the image file. Since sp flash tool is scatter based always check if the firmware file contains the scatter file.
Downloads
Direct links for Latest SP Flash Tool Download And drivers
Installing MediaTek USB-VCOM drivers on Windows computer
Sometimes MediaTek drivers are not allowed to install on Windows computer. In the situation like that follow Disable signature verification enforcement process
- Click Start > Settings>Update & security > Recovery
- Advanced Startup > Restart Now
- Troubleshoot > Advanced options> Start Up settings > Restart
- Then the computer will restart with the startup setting screen
- To Disable signature verification enforcement until next restart
press F7 - After restarting the computer, you can go forward with MediaTek
USB-VCOM drivers
How To Flash Stock ROM Using Sp Flash Tool
Download Sp Flash Tool and extract it
Download Stock Firmware you wish to flash and extract it
Switch off your smart device
Now click "Flash_exe" to launch the Sp Flash Tool
Click download tab and click the scatter loading button to load
scatter fileScatter file is located in the firmware file
Click on the "download icon" to launch the flashing process
Then connect your smart device and click volume up or down button to
ease the computer to recognize the smart deviceWait for about 10 minutes, after a successful operation a message
will be displayed along with a green circle.
How To Flash Custom ROM Using Sp Flash Tool
Download the relevant Custom ROM for you android MediaTek device
Unzip the folder
Start your computer in “Device driver signature disabled” mode
Install MediaTek USB-VCOM drivers
Launch Sp Flash Tool in “Administrator Mode”
Next, click “Scatter-loading” and load the scatter file that is
located in the firmware fileNow select the “Download Agent” go to the Sp Flash Tool folder and
select “MTK_AllInOne_DA.bin”After the above steps go to the”Format” tab and check the validation
Now switch off your device and connect
Then click start and to format the device
Next, disconnect the device and click on the download button under
the download tabAgain connect the device
Then the custom ROM installation will begin and wait for about 10
minutes A green tick will appear after successful installation
Hope this guide would be helpful to you.
Source - https://spflashtool.com/
— modified on Aug 24, 2018, 7:23:02 AM
