Common Huawei Mate 9 problems and their solutions
![Common Huawei Mate 9 problems and their solutions AndroidPIT huawei mate9 0438](https://fs.npstatic.com/userfiles/6727621/image/2016/huawei-mate-9/AndroidPIT-huawei-mate9-0438-w810h462.jpg)
![Brittany McGhee](https://fs.npstatic.com/user/43/86/724386-w155h167.jpg)
The Huawei Mate 9 is a fantastic device, but it's not without its share of issues. Users have reported problems with the touchscreen responsiveness, volume control, battery drain, notification delays and third-party launchers. If you've experienced any of these, we've got you covered. Check out the details on the Mate 9's most common problems, and their solutions, here.
Huawei Mate 9 Problems
Touchscreen not responding | No volume control on lock screen |
Battery drain issue | Third-party launcher reverts to default |
Delayed notifications |
Huawei Mate 9: Touchscreen not responding
Some users have reported issues with their Mate 9's touchscreen. Namely, the display is unresponsive or registering taps unnecessarily on the right and left sides. Luckily, this annoying issue has been fixed by a software update that rolled out last December. If you're still experiencing the problem, make sure you've got the latest software update by going to Settings > About phone > System updates.
![AndroidPIT huawei mate9 0162](https://fs.npstatic.com/userfiles/6727621/image/2016/huawei-mate-9/AndroidPIT-huawei-mate9-0162-w782.jpg)
Huawei Mate 9: No volume control on lock screen
If you're listening to music on your phone, you expect to be able to control the volume using the buttons on the side when the screen is locked. But, users report that their Mate 9 requires you to unlock the screen to adjust the volume. For some reason, this happens when using Spotify or some other music apps. This issue may be addressed in the future with a software update, but for now, the solution is more of a workaround. Huawei has told Digital Trends that only two apps are supported: Huawei Music and Google Play Music. That's bad news for Spotify users, who will have to switch apps, but at least there's some way around this problem.
![huawei mate 9 volume music](https://fs.npstatic.com/userfiles/7421491/image/huawei-mate-9-volume-music-w782.png)
Huawei Mate 9: Battery drain issue
Users have reported that, in spite of the Mate 9's good battery life, their particular devices are draining battery at an unusual rate and even overheating in some cases. Huawei told Digital Trends that is plans to provide enhancements to fix these issues in a future update, so make sure you've updated your software. If that doesn't fix the problem, check to make sure your apps are optimized. Go to the Battery section of your Mate 9's Settings, the go to the Battery usage details page to find out if any apps are taking up too much battery. If there's an app that's behaving strangely, get rid of it, or simply update it to try to fix the problem. Also, you'll want to use the Mate 9's Optimise tool to make your battery last longer.
![huawei mate 9 battery](https://fs.npstatic.com/userfiles/7421491/image/huawei-mate-9-battery-w782.png)
Huawei Mate 9: Third-party launcher reverts to default
Particularly bothersome for those that like to use custom launchers like Nova, the Mate 9 tends to revert back to the default EMUI launcher whenever an app is closed. That means, the only way to get the alternative launcher to work is to re-enable it over and over again. There are some workarounds when you want to use third-party launchers, but they're not perfect. You can try locking your launcher to the Recent Apps list by going to the Recent Apps' Settings menu and tapping the lock icon for the launcher - after you've recently opened it of course. You can also try disabling Bluetooth on the device, or enabling the 'aggressive desktop' feature of launchers like Nova to see if that helps.
Huawei Mate 9: Delayed notifications
A lot of users, as evidenced by this dramatically long XDA Developers forum thread, haven't been receiving app notifications as they should. They're either not getting them at all, or they're delayed, though the badges still appear on the app icons on the home screen. An update was released to fix this problem, but if that doesn't quite do it for you, there's more you can do. Check to be sure that Do Not Disturb is disabled. Next, try going to the Phone Manager app, then to the Mobile Data section. Once there, scroll down to the bottom and tap Data Saver. Then you can allow unrestricted data access to specific apps which you want to get notifications from that require a data connection (like email or WhatsApp).
![huawei mate 9 data notifications](https://fs.npstatic.com/userfiles/7421491/image/huawei-mate-9-data-notifications-w782.png)
Have you been experiencing any other issues with your Mate 9 that we can help you with? Did these solutions work for you? Let us know in the comments!
Source: Digital Trends
How about a fix for Huawei stripping out google's SmartLock except for BT. Also bothersom for me is no raise to wake, no doubletap to wake (even though it is there you have to root to enable). So as the phone sits on my desk the only way I have to wake it up is hard pressing the powerkey, unless I want to actually pick it up and unlock with FP. The software is so funky it even keeps other apps like Glimpse notifications from working. So yes, even though I like the hardware I returned it and spend additional money on a true flagship that gives me what I want and need.
