[GUIDE] Extend android applications trial period
  • Forum posts: 770
Jun 11, 2014, 6:50:58 PM via Website
Trick to extend android app trial version
This trick does not extend the trial period but will delete the app data to use the trial again
HERE I AM USING SWIFT KEY also works with any other app
1) DOWNLOAD SWIFT KEY FROM MARKET INSTALL IT
SC20130526 130859 SC20130526 131300
2)I INSTALLED IT ON MAY 26 AND THE TRIAL VERSION WILL EXPIRE ON JUNE 25 -
SC20130526 131339
3) TO TEST THE TRICK I JUST CHANGE THE DATE TO JULY 26
SC20130726 131406
4) NOW THE TRICK, JUST GO TO MANAGE APPLICATION AND SELECT THE SWIFT KEY APP -
SC20130726 131536
5) NOW CLEAR DATA AND CACHE
SC20130726 131542
6) THE TRICK WORKS.YOU NEED TO DOWNLOAD THE LANGUAGE PACK AGAIN
SC20130726 131619
Ready To Help You.
Francisco Argueso
laurakelly
  • Forum posts: 18
Sep 9, 2014, 1:09:37 PM via Website
Superb app...I really love to use this app...
Thanks for share it.
Great work.
Francisco Argueso
Plumillon
Sep 9, 2014, 2:36:31 PM via Website
Don't hesitate to buy this app, you won't be deceive for the mony spent
Lalit
  • Forum posts: 2,324
Sep 9, 2014, 5:38:45 PM via App
Well, that's a great trick to test paid app for free :) Good one though I wonder this trick isn't going to work with every.... but I must say good share to play with swiftkey. I don't use swift key but I guess swiftkey developer has made the application available for free over the playstore. But yes swift key legacy isn't available for ......
— modified on Sep 9, 2014, 5:41:05 PM
  • Forum posts: 770
Sep 9, 2014, 7:13:45 PM via Website
John F.
Swiftkey is free now, there is no point in doing this method. (yawn) :D
Ready To Help You.
