How to improve sound quality and boost volume on Android
AndroidPIT Jessica LG V30 0633
Not all smartphones have the speaker quality or volume levels to make your stereo envious. These two issues—along with poor speaker placement—can get in the way of you enjoying the sound. Here are a few tips to help you improve sound quality and increase volume on Android. You can try a speaker booster or volume booster app, but plenty can be improved with a little audio know-how.
Jump to a solution:
Check your settings
You could optimize your Android audio experience through the settings. Not all Android UIs have this feature, however, so it won't work for everyone. If your device has it, the procedure is easy, though. And once you've done it for the first time you will be able to quickly enhance your audio settings in the future.
For Samsung devices you need to plug in whichever audio device you want to use (if you're using one) and do the following:
  1. Enter Settings and tap Sounds and vibration.
  2. From there hit Sound quality and effects. You should have a series of options to enhance your audio experience.
MIUI from Xiaomi has an enhancer for headphones. Just toggle it on and pick the type you're using. You should have a choice between in-ear and normal headphones.
Xperia UI allows you to use the ClearAudio setting and has an equalizer. You can get to it through the settings.
With HTC's Sense UI you can toggle BoomSound but there's really no reason to turn it off, as the audio is terrible without it on. You can't optimize your audio settings from Oxygen, LG UI, or Stock Android.
AndroidPIT sony xperia x performance 1180
Get the most out of your Android audio experience. / © NextPit
Download a new music app
You have the option of replacing the stock music app with one that includes more audio control. We recommend Poweramp or PlayerPro as our top music apps for Android. Both are jam-packed with audio tweaks, presets, bass boost, and more. Just make sure your music folders are checked in the app settings.
Poweramp offers a 10-band EQ for serious tuning. You'll have to pay a couple of bucks to access all the best features but once you do you'll never look back.
Poweramp
Sometimes all you need is a better music player app. / © NextPit
Several of our readers have also recommended PlayerPro as an alternate music app. The software offers advanced audio configuration options as well as many ways to customize the visual experience too. PlayerPro costs $3.99 but there's also a free trial version available for the curious.
For more options on the best apps for your favorite jams on Android, check out our article for more music player apps:
Use a speaker booster/volume booster app
Music player apps like the above are great, but of course, it only works from within the app. So what if you want to boost speaker sound overall? This is a little controversial because the fact is that even though there are many apps on the Play Store that claim to do this, compatibility is iffy, and using an app to force your speakers past their default max can actually damage your phone's hardware.
So while you may find the right volume booster app for your device and OS, it may take some digging, and while testing this, don't crank it all the way up straight away!
Download an Equalizer app
The default audio controls on most phones are not exactly comprehensive. Some include a basic EQ but it often only works within the default music app and provides no control over audio not played through the music player.
It's important to note that no app works miracles when the hardware is not working properly but with a couple of simple adjustments your sound quality can be improved significantly. So hit the Play Store and get yourself a decent EQ. We can recommend both Music Volume EQ and Bass Booster.
Know your speaker placement
It may seem silly, but the first thing you need to know is where the sound is coming from on your smartphone. Lots of phones have twin speaker grills, but often only one of them produces any sound. If your speaker is blocked then the sound quality will be low or non-existent.
Test out where your sound is coming from by playing some tunes and covering the various holes on your phone until you know exactly where the audio is coming from. There shouldn't be too many places for a speaker to hide and, once you've found them, you can get started on finding the problem.
Razer 2 11
Multimedia-focused devices like the Razer Phone 2 have big, loudspeakers. / © NextPit
Once you know whether your speakers are front-facing, bottom-mounted or on the back, you can make more intelligent decisions about how to position your smartphone to give speakers the best chance to shine.
Don't block the speakers when holding your phone (a common mistake when gaming with bottom-mounted speakers) and point the speakers towards you, not away from you.
Check if your case is blocking a speaker
If your phone has a protective case or cover, it will affect the quality of the sound you get from the speakers. All those vibrations coming from inside your phone will be muffled by the additional layer of plastic or rubber that the manufacturer won't have taken into account when designing its speaker system.
Not all case makers understand the subtleties of your device. Some cases block essential parts of the phone like the audio jack, microphone or speaker. Before you buy a case be sure that you check to see that it won't block anything.
htc speaker
Not all phones have speakers this good, so don't muffle them with a case. / © NextPit
Use headphones
The simple fact is that most smartphone speakers are simply not good enough to get decent sound quality out of, even with a fancy music app or EQ. This is where a decent pair of headphones can help (some audio settings in your phone won't even work without headphones plugged in).
Check out our list of the best headphones and see how much of a difference a serious set of headphones can make to your smartphone audio. Not all headphones are created equal and there are different types for various situations. Make sure you look through and find the one that best suits you.
AndroidPIT Headphones eardrops 2
Buy some good headphones or even just use the ones that came with your phone. / © NextPit
Use a smart speaker
Headphones are great on the go, but what about at home? Nowadays many prefer to put the phone down when they get to the house and use a voice assistant to manage their daily tasks and that includes entertainment such as music. Now accessing your favorite playlists is as simple as asking into the air.
Not only do the original smart speakers such as Google Home and Amazon Echo also double as music speakers (at least, the larger ones), but audio specialists such as JBL and Sonos are offering their own smart speakers with Alexa or Google Assistant for audiophiles who want to go with their favorite brand.
Check out our reviews to see which smart speaker may be best for you:
Boost speaker volume
If you are rooted, there are plenty of app options out there that can bypass the max volume of the Android system with a few simple tweaks. Check out our ultimate guide on how to root Android for more details. If you don't want to root your phone or simply aren't convinced by the distortions that most volume-booster apps in the Play Store end up producing, then there are still a few things you can do.
Get to know a little about sound waves. If you position your phone in a corner and fire the speaker's output towards it, you'll get a louder, 'bassier' reverberation than if it was just shooting out into the room. The same logic applies to any object: put your phone in a box, against a bowl or in a glass (empty, of course) and you might be amazed to hear how much louder your speaker suddenly is.
How do you improve the sound quality on your phone? Have you found any reliable volume booster apps? Let us know in the comments.
Go to comment (75)
75 comments
    takasumi May 23, 2020 Link to comment
    I use volume booster to increase the volume on chrome and listen to music with higher sound.
  • Guy Deridet 13
    Guy Deridet May 20, 2020 Link to comment
    I use Goodev Volume Booster on my Huawei P30 Pro and my Chromebook in Android mode. Works perfect. I've tried a lot and it's the only one which really improves the volume without distorting sounds, at a reasonable level, of course.
    venkat Nov 25, 2019 Link to comment
    I want headphone only for talking on phone ( not for music). that means it should have mic (preferably more than one on both ear pieces). prefer wired headphone. any suggestions.
    Sorin
    mahikhan Aug 12, 2019 Link to comment
    The volume boosters I have tried are snake oil. An equalizer does the trick
    Sorin
  • Konstantinos Daglaroglou 8
    Konstantinos Daglaroglou Aug 11, 2019 Link to comment
    There is no easy (=cheap) way to boost sound quality on a smartphone.
    -Buy an external DAC/Amp, like Creative labs Super X-fi AMP or Dragonfly.
    -Buy a good headphone set, I chose Beyerdynamic DT 770 pro 80 Ohms
    -Buy the best android player app, USB Audio Player pro.
    We are talking about $250 here, but it's worth the cost.
    Sorinstorm
      Samel_89 Sep 21, 2019 Link to comment
      It was an easy way to have it built-in one mobile -> Alcatel Idol 4 with Waves Maxx Audio,
      Equalizer should stay unchanged but Waves provided to users such a thing ->
      BassBoost
      TrebleBoost
      Revive (Reverb)
      Virtualization
      That is what I called MUSIC for a fan of shoegaze or any WALL OF SOUND genre it was amazing... but the phone got broken and I think that I will get the same one... Even the times have changed well that quality of music is incomparable to anything else...
      Sorin
  • marco sarli 39
    Aug 10, 2019 Link to comment
    Sorin
  • 16
    Deactivated Account Sep 13, 2018 Link to comment
    for anyone with root and unlocked bootloader, the only way to go is ARISE sound mod. totally modular and contains every sound mod you could ever want. it takes a bit of getting used to when installing, but once installed can totally change the way you view (hear) your device.
    Sorin
  • 21
    Peter Harwood Sep 11, 2018 Link to comment
    One way of ruining your phones speakers is to download an app which supposedly boosts sound?
    ElfynSorinitprolonden
  • Dean L. 34
    Dean L. Jan 18, 2018 Link to comment
    I use an LG tone wireless headset and like it. But for true sound quality I love using my wired Sennheiser on the ear headphones.
    Sorin
  • 20
    Reg Joo Jan 17, 2018 Link to comment
    This comment is for people that root. Watch out for some rooted apps, if you’re rooted. A combination of two sound apps in magisk(plus deep buffer remover), made me have to flash back to stock(my one and only time on this phone). Do your homework first, get info on possible problems, just like you’d do with medicine, or your phone will get very sick!
    SorinDean L.
  • Albin Foro 30
    Albin Foro Jan 15, 2018 Link to comment
    No real problems with sound output, though had a headscratcher once where the media slider was off while others were working - couldn't find it. I almost never listen to device speakers - outdoors its some good but not extravagant headphones, they just keep breaking and ambient city noise fuddles acoustic snobbery. At home a "male / male" input cable connects devices to either the living room stereo "Aux" jack, or decent peripheral speakers attached to a PC. Much better to listen to streaming services or Youtube videos that way or via chromecast: more comfortable and far better speakers and screens.
    Update 180911 - My new (Lenovo) tablet came with Dolby sound preinstalled, surprisingly configurable and effective. Worth checking for.
    SorinDean L.
    alexwild Jul 18, 2017 Link to comment
    i haven't found an equalizer that actually works with my Samsung J7 only things that do work are bass boost & virtualizer. Does anyone have suggestions of any that actually work please ?
  • Mark G. 28
    Mark G. Jun 21, 2017 Link to comment
    Without doubt the best music app is the excellent Playerpro - it has an additional add on DSP pack which provides enhanced audio features - resampler 48khz - dithering method - 32 bit output - full high end equaliser - bass boost/virtualizer - reverb effect gain - reply gain - pre-amplification - clipping prevention.
    It provides a high quality music player with Artist/album artwork (fully customisable) - fully editable ID3 tags - download skins - lyric finder (musixmatch/Internet/quick lyric) - lock screen & widgets.
    I don't normally promote one app over the next, but if you are a music fan and enjoy high quality then I highly recommend Playerpro.
    Peace ??
    SorinDean L.
    • Dean L. 34
      Thanks for the app recommendation Mark G. I'll have to look into it.
      SorinMark G.
      • Mark G. 28
        Mark G. Jan 19, 2018 Link to comment
        I must admit there were certain settings and features that I was unsure about, if you get the mixture wrong you'll certainly know about it, but after reading one or two articles it becomes clearer. I would certainly recommend playing around with it to suit your own audio preferences
        Peace ?
        SorinDean L.
  • 10
    parayil h. Jun 21, 2017 Link to comment
    Volume booster Apps in Google play store do nothing for unrooted devices, and in rooted devices God knows.
    Only waste the time and finishing your battery.
  • 26
    Andrew Burgin Jun 21, 2017 Link to comment
    Ever since i found my best music application on Android,i have been using PlayerPro,which offers a Dsppack,which really helps you set the volume on this Super music player,it so easy to set up,and offers you searching on the internet to Find the correct Album image for any music you add to the player,but the reason i do like Playerpro as it offers the Exit function once you finished using the music player
    shreeram kcMark G.
  • Mark Pedzinski 3
    Mark Pedzinski Jan 19, 2017 Link to comment
    What a stupid Google search response I've got? I mean dang, my phone is rooted, and I amplifications from apps! Now, I want to go into my system settings and make no limit to volume control. This dude who wrote this article should be shot
    shreeram kcMai Xwb Thao
    Stoff Jan 10, 2017 Link to comment
    I invite you to try my new Volume Booster for Android devices. Just add the following to google play url (/store/apps/details?id=mobapps.tool.sound.speakervolumeboosterpro)
Show all comments
